Using linux,usable-memory the board code carves out 1MiB of memory
for the Cortex-M4 core at the end of the 256MiB block. However,
in case a board has 256MiB of memory (Colibri iMX7S), that is the
area where U-Boot gets relocated to... Use board_get_usable_ram_top
to avoid using that area as relocation target.
i.MX 7's Cortex-M4 core can run from DDR and uses DDR memory for
the rpmsg communication. Both use cases need a fixed location of
memory reserved. For the rpmsg use case the reserved area needs
to be in sync with the kernel's hardcoded vring descriptor location.
Use the linux,usable-memory property to carve out 1MB of memory
in case the M4 core is running. Also make sure that the i.MX 7
specific rpmsg driver does not get loaded in case we do not carve
out memory.
This reverts commit 34fcaeec51fa3f519a13eb8d127abea1853e77e5.
If you have this version of U-Boot running, the change we warned
about has already been applied. No need to warn anymore.
We plan to no longer support the work-around for errata e9609 since
it does not allow to detect factory bad blocks. Print a warning to
prepare customers of the upcoming change.
Disable DCDC2 discharge as this leads to higher power consumption when
turning off DCDC2 on Colibri iMX7S. This is likely due to backfeeding
the DCDC2 through the VFB2 pin.
Configure sleep slots for LDO1 (Ethernet) and ARM CPU rail. This
makes sure the rails get disabled when the SoC enters sleep mode.
To properly reset a Colibri iMX7 the PMIC reset capabilities need
to be used.
The i.MX 7Solo only has one USB controller. Do not enable USB_PEN
but return a -ENODEV return code instead. This allows "usb start"
to work properly on Colibri iMX7S modules.
Configure the Ricoh PMIC RN5T567 at startup to reset the board
without delay.
Used during manufacturing for setting the boot fuses.
While at it fix whitespace issue.
While at it remove unusable boot modes from the list.
Add pinmux and I2C setup call to register the Colibri I2C bus.
The fourth (I2C4) instance is used for the I2C bus defined in the
standard Colibri pinout. Use i2c dev 3 to switch to this bus.
HW patch required. Connect RMII_CRS_DV - ENET1_RXC, remove R166
Output 50MHz reference clock works, sending works but no reception.
Use get_ram_size() to autodetect up to 2Gbyte of RAM on rank 0.
If chips with two ranks would get stuffed one would have to set the size
of one rank in DDRC_ADDRMAP0.
The Colibri iMX7 uses a different pmic
