path: root/common/env_common.c
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-06-06env: Setup GD_FLG_ENV_DEFAULT flag when default environment are usedMichal Simek
Setup flag when default environment are used to be able to rewrite default distro boot variables based on SoC boot mode. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2014-07-22Add option -r to env import to allow import of text files with CRLF as line ↵Alexander Holler
endings When this option is enabled, CRLF is treated like LF when importing environments from text files, which means CRs ('\r') in front of LFs ('\n') are just ignored. Drawback of enabling this option is that (maybe exported) variables which have a trailing CR in their content will get imported without that CR. But this drawback is very unlikely and the big advantage of letting Windows user create a *working* uEnv.txt too is likely more welcome. Signed-off-by: Alexander Holler <holler@ahsoftware.de>
2014-07-18common: env_common: make env_get_char_spec __weakJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-03-21env: Implement support for encrypting environmentMarek Vasut
Add function which allows encrypting the whole environment block with AES-128-CBC. The key for the environment is retrieved by env_aes_cbc_get_key() function, which must be implemented on a per-board basis. Signed-off-by: Marek Vasut <marex@denx.de>
2014-03-21env: Add env_export() wrapperMarek Vasut
Implement env_export() wrapper, so that all implementers of saveenv() don't have to call hexport_r(), crc32() etc. sequence . This trims down a bit of code duplication. Signed-off-by: Marek Vasut <marex@denx.de>
2013-08-20spl: env_common.c: make CONFIG_SPL_BUILD contain function env_importYing Zhang
The functionality env_import will be used in the SPL. They had been excluded by ifndef CONFIG_SPL_BUILD. Now, put it into the SPL. Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: York Sun <yorksun@freescale.com>
2012-12-13env: Add support for access control to .flagsJoe Hershberger
Add support for read-only, write-once, and change-default. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add environment variable flagsJoe Hershberger
Currently just validates variable types as decimal, hexidecimal, boolean, ip address, and mac address. If the entry is not found in the env ".flags", then look in the static one. This allows the env to override the static definitions, but prevents the need to have every definition in the environment distracting you. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Use getenv_yesno() more generallyJoe Hershberger
Move the getenv_yesno() to env_common.c and change most checks for 'y' or 'n' to use this helper. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Refactor apply into change_okJoe Hershberger
Move the read of the old value to inside the check function. In some cases it can be avoided all together and at the least the code is only called from one place. Also name the function and the callback to more clearly describe what it does. Pass the ENTRY instead of just the name for direct access to the whole data structure. Pass an enum to the callback that specifies the operation being approved. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Refactor do_apply to a flagJoe Hershberger
Use a flag in hsearch_r for insert mode passed from import to allow the behavior be different based on use. Now that "do_check" is called for all imports, ensure console init is complete before updating the console on relocation import Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-19env: cosmetic: Consilidate the default env definitionJoe Hershberger
There used to be a huge structure duplicated 3 times in the source. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-01OMAP: networking support for SPLIlya Yanok
This patch adds support for networking in SPL. Some devices are capable of loading SPL via network so it makes sense to load the main U-Boot binary via network too. This patch tries to use existing network code as much as possible. Unfortunately, it depends on environment which in turn depends on other code so SPL size is increased significantly. No effort was done to decouple network code and environment so far. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-18env: make "env default" selective, check and applyGerlando Falauto
Change the syntax (user API) for "env default": -f: override write-once variables var... : accept individual variable(s) -a: all (resetting the whole env is NOT the default behavior) Enable variable checking and make changes effective by enabling do_apply argument to himport_r(). Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
2012-09-18env: add check/apply logic to himport_r()Gerlando Falauto
Change hashtable so that a callback function will decide whether a variable can be overwritten, and possibly apply the changes. So add a new field to struct hsearch_data: o "apply" callback function to check whether a variable can be overwritten, and possibly immediately apply the changes; when NULL, no check is performed. And a new argument to himport_r(): o "do_apply": whether to call the apply callback function NOTE: This patch does not change the current behavior. Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Reviewed-by: Marek Vasut <marex@denx.de>
2012-09-18env: make himport_r() selective on variablesGerlando Falauto
Add 2 new arguments to himport_r(): o "nvars", "vars": number and list of variables to take into account (0 means ALL) NOTE: This patch does not change the current behaviour. Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Reviewed-by: Marek Vasut <marex@denx.de>
2012-09-18env_common: Add missing ethprimeBenoît Thébaudeau
The ethprime env var was missing from env_common. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Wolfgang Denk <wd@denx.de>
2012-07-09Add env vars describing U-Boot target boardStephen Warren
This can be useful for generic scripts. For example, rather than hard- coding a script to ext2load tegra-harmony.dtb, it could load ${soc}-${board}.dtb and hence not need adjustments to run on multiple boards. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Convert net progress numbers to enumsSimon Glass
This changes over the network-related progress numbers to use enums from bootstage.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Use show_boot_error() for -ve progress numbersSimon Glass
Rather than the caller negating our progress numbers to indicate an error has occurred, which seems hacky, add a function to indicate this. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-01-05env: factor out the env_get_char_spec() functionIgor Grinberg
env_get_char_spec() function is duplicated across multiple environment files. Remove the duplication by providing a default implementation. Add "weak" declaration, so the default implementation can be overridden. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: clean env_common.c checkpatch and code styleIgor Grinberg
Cleanup the env_common.c checkpatch warnings, errors and coding style. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26constify default envMike Frysinger
I can't see any obvious needs for the default environment to be writable, so make it const. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-09env: re-add support for auto-completionMike Frysinger
Currently, only basic completion is supported (no globs), but this is what we had previously. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-12-17hashtable: drop all non-reentrant versionsMike Frysinger
The non-reentrant versions of the hashtable functions operate on a single shared hashtable. So if two different people try using these funcs for two different purposes, they'll cause problems for the other. Avoid this by converting all existing hashtable consumers over to the reentrant versions and then punting the non-reentrant ones. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-12env: don't set to default env twice when use CONFIG_ENV_IS_NOWHERELei Wen
When use the CONFIG_ENV_IS_NOWHERE, I met such issue: DRAM: 256 MiB Using default environment *** Warning - bad CRC, using default environment Signed-off-by: Lei Wen <leiwen@marvell.com>
2010-10-06env: fix cmd_env_sub fct pointers if CONFIG_RELOC_FIXUP_WORKS is not definedHeiko Schocher
commit ea882baf9c17cd142c99e3ff640d3ab01daa5cec introduces a command_sub_table for the "env" command. On arm, avr32, m68k, mips and sparc architectures, relocation needs manual fixups, so add these fixups for this sub command table too. Tested on arm/qong board. mips board (Ben NanoNote) from Xiangfu Liu arm/AT91 board from Reinhard Meyer Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> cc: Xiangfu Liu <xiangfu@openmobilefree.net> cc: Reinhard Meyer <u-boot@emk-elektronik.de> cc: sshtylyov@mvista.com
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-07-17Drop support for GTH boardWolfgang Denk
The board maintainer states: The GTH board is obsolete and has not been manufactured for several years. To my knowledge, no recent U-Boot build has been tested on that card. So drop support for this board. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Acked-by: Thomas Lange<thomas@corelatus.se>
2010-06-23Remove AmigaOneG3SE boardWolfgang Denk
The AmigaOneG3SE board has been orphaned or a very long time, and broken for more than 12 releases resp. more than 3 years. As nobody seems to be interested any more in this stuff we may as well ged rid of it, especially as it clutters many areas of the code so it is a continuous pain for all kinds of ongoing work. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-10-03Conditionally perform common relocation fixupsPeter Tyser
Add #ifdefs where necessary to not perform relocation fixups. This allows boards/architectures which support relocation to trim a decent chunk of code. Note that this patch doesn't add #ifdefs to architecture-specific code which does not support relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-08-09env: kill off default_environment_sizeMike Frysinger
The only environment type that uses this variable is spi flash, and that is only because it is reimplementing the common set_default_env() function. So fix the spi flash code and kill off the default_environment_size in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-18Adds two more ethernet interface to 83xxrichardretanubun
Added as a convenience for other platforms that uses MPC8360 (has 8 UCC). Six eth interface is chosen because the platform I am using combines UCC1&2 and UCC3&4 as 1000 Eth and the other four UCCs as 10/100 Eth. Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_SPI_FLASH in CONFIG_ENV_IS_IN_SPI_FLASHJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_NAND in CONFIG_ENV_IS_IN_NANDJean-Christophe PLAGNIOL-VILLARD
2008-07-10Remove code duplication for setting the default environmentHarald Welte
common/env_common.c (default_env): new function that resets the environment to the default value common/env_common.c (env_relocate): use default_env instead of own copy common/env_nand.c (env_relocate_spec): use default_env instead of own copy include/environment.h: added default_env prototype Signed-off-by: Werner Almesberger <werner@openmoko.org> Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-07-09Change env_get_char from a global function ptr to a functionJoakim Tjernlund
This avoids an early global data reference. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-06-03Add support for environment in SPI flashHaavard Skinnemoen
This is pretty incomplete...it doesn't handle reading the environment before relocation, it doesn't support redundant environment, and it doesn't support embedded environment. But apart from that, it does seem to work. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
