path: root/common/spl/spl_fat.c
2016-10-06spl: Update spl_load_simple_fit() to take an spl_image paramSimon Glass
Upda the SPL FIT code to use the spl_image parameter. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Update fat functions to take an spl_image parameterSimon Glass
Update the fat loader to avoid using the spl_image global variable. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Add a parameter to spl_parse_image_header()Simon Glass
Instead of using the global spl_image variable, pass the required struct in as an argument. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-22spl: Fix compilation warnings for arm64Michal Simek
Make code 64bit aware. Warnings: +../arch/arm/lib/spl.c: In function ‘jump_to_image_linux’: +../arch/arm/lib/spl.c:63:3: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] +../common/spl/spl_fat.c: In function ‘spl_load_image_fat’: +../common/spl/spl_fat.c:91:33: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-27spl: Support loading a FIT from FAT FSLokesh Vutla
Detect a FIT when loading from a FAT File system and handle it using the new FIT SPL support. Tested-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-05-23SPL: fat: Fix spl_parse_image_header() return value handlingTom Rini
The spl_parse_image_header() can return 0 and it is not an error. Only treat non-zero return value as an error. Signed-off-by: Marek Vasut <marex@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Peng Fan <van.freenix@gmail.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-17SPL: Let spl_parse_image_header() return valueMarek Vasut
Allow the spl_parse_image_header() to return value. This is convenient for controlling the SPL boot flow if the loaded image is corrupted. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Peng Fan <van.freenix@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@konsulko.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-11-18spl: mmc: remove #ifdef CONFIG_SPL_OS_BOOT checkNikita Kiryanov
Implement default versions of falcon mode functions to make the CONFIG_SPL_OS_BOOT check in spl_mmc_load_image() unnecessary, thus reducing its #ifdef complexity. No functional changes. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Paul Kocialkowski <contact@paulk.fr> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Suriyan Ramasami <suriyan.r@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2014-10-27spl: do not hang in spl_register_fat_device but return error value. It ↵Guillaume GARDET
allows to use both CONFIG_SPL_FAT_SUPPORT and CONFIG_SPL_EXT_SUPPORT. Do not hang in spl_register_fat_device but return an error value. It allows to use both CONFIG_SPL_FAT_SUPPORT and CONFIG_SPL_EXT_SUPPORT. If FAT load fails, then EXT load is tried. Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-10-27Rename some defines containing FAT in their name to be filesystem genericGuillaume GARDET
Rename some defines containing FAT in their name to be filesystem generic: MMCSD_MODE_FAT => MMCSD_MODE_FS CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-04-17spl_mmc/CONFIG_SPL_OS_BOOT: Allow environment to determine what to bootTom Rini
We add two new environment variables, falcon_args_file and falcon_image_file, which when set will override the compiled in default values for falcon mode. Signed-off-by: Tom Rini <trini@ti.com>
2014-01-24spl: common: Support for USB MSD FAT image loadingDan Murphy
Add SPL support to be able to detect a USB Mass Storage device connected to a USB host. Once a USB Mass storage device is detected the SPL will load the u-boot.img from a FAT partition to target address. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2014-01-24spl: common: Move FAT funcs to a common fileDan Murphy
Move the FAT functions to a common location for reuse. Signed-off-by: Dan Murphy <dmurphy@ti.com>
