path: root/configs/MPC837XEMDS_defconfig
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-21mpc83xx: Migrate CONFIG_LCRR_* to KconfigMario Six
Migrate the CONFIG_LCRR_* settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate SPCR to KconfigMario Six
Migrate the SPCR setting to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate arbiter config to KconfigMario Six
Migrate the arbiter configuration to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate HID config to KconfigMario Six
Mirate the HID configuration settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_SYS_{BR, OR}*_PRELIM to KconfigMario Six
Migrate the BR/OR settings to Kconfig. These must be known at compile time, so cannot be configured via DT. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate LBLAW_* to KconfigMario Six
The LBLAW_* values determine the window configuration of the memory controller. Hence, they must be known at compile time, and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate BATS config to KconfigMario Six
The BATs (block address translation registers) determine the initial memory window mappings. Hence, they must be known at compile time and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21powerpc: Migrate HIGH_BATS to KconfigMario Six
Migrate the CONFIG_HIGH_BATS variable to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Kconfig: Migrate HRCW to KconfigMario Six
The HRCW (hardware reset configuration word) is a constant that must be hard-coded into the boot loader image. So, it must be available at compile time, and cannot be migrated to the DT mechanism, but has to be kept in Kconfig. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_83XX_CLKINMario Six
MPC83xx uses CONFIG_83XX_CLKIN instead of CONFIG_SYS_CLK_FREQ to set the system clock. To migrate the architecture, we can replace CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ. To do this * replace all occurrences of CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ * set CONFIG_SYS_CLK_FREQ to the old value of CONFIG_83XX_CLKIN in all MPC83xx config files Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
