path: root/configs/mx7dsabresd_secure_defconfig
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-07-28mx7dsabresd_secure_defconfig: Use CONFIG_ARMV7_BOOT_SEC_DEFAULTFabio Estevam
There is no need for introducing MX7_SEC, as there is the CONFIG_ARMV7_BOOT_SEC_DEFAULT option for this purpose. Switch to CONFIG_ARMV7_BOOT_SEC_DEFAULT and get rid of MX7_SEC. Tested by booting a 4.1.15 NXP kernel with mx7dsabresd_secure_defconfig target. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-07-28Fix build for mx7dsabresd (secure config)Stefano Babic
After moving CONFIG_USB_EHCI_MX7 to Kconfig, the flag must be set in defconfig for mx7dsabresd. It is already for the not secure config, it is missing in the secure configuration. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-12mx7dsabresd: Fix the boot of a NXP kernelFabio Estevam
Booting a NXP kernel with mainline U-boot leads to the following kernel crash: caam: probe of 30900000.caam failed with error -11 Unable to handle kernel NULL pointer dereference at virtual address 00000004 pgd = 80004000 [00000004] *pgd=00000000 Internal error: Oops: 805 [#1] PREEMPT SMP ARM This happens because NXP kernel expects MX7 to boot in secure mode, so introduce mx7dsabresd_secure_defconfig that selects CONFIG_MX7_SEC and allows booting a NXP provided kernel successfully. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
