path: root/configs/spear300_usbtty_defconfig
2016-09-16spear: Use upper case for CONFIG optionsSimon Glass
There are a few options which use lower case. We should use upper case for all CONFIG options. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Add usbtty/nand hunk to include/configs/spear3xx_evb.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-17i2c: config: Move SYS_I2C_DW to KconfigStefan Roese
This patch moves all appearances of CONFIG_SYS_I2C_DW from the config header to the defconfig files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Alexey Brodkin <abrodkin@synopsys.com>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
