path: root/drivers/core
2016-10-24Fix codying style broken by recent libfdt syncMasahiro Yamada
Commit b02e4044ff8e ("libfdt: Bring in upstream stringlist functions") broke codying style in some places especially by inserting an extra whitespace before fdt_stringlist_count(). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: core: Add a function to get a uclass nameSimon Glass
It is useful in debug() statements to display the name of the uclass for a device. Add a simple function to provide this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-09-21dm: syscon: Provide a generic syscon driverPaul Burton
Provide a trivial syscon driver matching the generic "syscon" compatible string, allowing for simple system controllers to be used without a custom driver just as in Linux. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-09-21dm: core: Match compatible strings in order of priorityPaul Burton
Device model drivers have previously been matched to FDT nodes by virtue of being the first driver in the driver list to be compatible with the node. This ignores the fact that compatible strings in the device tree are listed in order of priority - that is, if we have a node with 2 compatible strings & a driver that matches each then we should always probe the driver that matches the first compatible string. Fix this by looping through the compatible strings for a node when attempting to bind it in lists_bind_fdt and checking each driver for a match of the first string, then each driver for a match of the second string etc. Effectively this inverts the loops over compatible strings & drivers. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-09-21dm: regmap: Implement simple regmap_read & regmap_writePaul Burton
The regmap_read & regmap_write functions were previously declared in regmap.h but not implemented anywhere. The regmap implementation & commit message of 6f98b7504f70 ("dm: Add support for register maps (regmap)") indicate that only memory mapped accesses are supported for now, so providing simple implementations of regmap_read & regmap_write is trivial. The access size is presumed to be 4 bytes & endianness is presumed native, which are the defaults for the regmap code in Linux. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-12fdt: allow fdtdec_get_addr_size_*() to translate addressesStephen Warren
Some code may want to read reg values from DT, but from nodes that aren't associated with DM devices, so using dev_get_addr_index() isn't appropriate. In this case, fdtdec_get_addr_size_*() are the functions to use. However, "translation" (via the chain of ranges properties in parent nodes) may still be desirable. Add a function parameter to request that, and implement it. Update all call sites to default to the original behaviour. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Squashed in build fix from Stephen: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-27dm: Convert users from dm_scan_fdt_node() to dm_scan_fdt_dev()Simon Glass
This new function is more convenient for callers, and handles pre-relocation situations automatically. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-27dm: core: Add a function to bind child devicesSimon Glass
We currently use dm_scan_fdt_node() to bind devices. It is an internal function and it requires the caller to know whether we are pre- or post- relocation. This requirement has become quite common in drivers, so the current function is not ideal. Add a new function with fewer arguments, that does not require internal headers. This can be used directly as a post_bind() method if needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-25dm: core: Add a way to find a device by its driverSimon Glass
Some SoCs have a single clock device. Provide a way to find it given its driver name. This is handled by the linker so will fail if the name is not found, avoiding strange errors when names change and do not match. It is also faster than a string comparison. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14dm: core: Add an implementation of regmap_init_mem_platdata()Simon Glass
Add an implementation of this function which mirrors the functions of the automatic device-tree implementation. This can be used with of-platdata to create regmaps. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14dm: core: Move regmap allocation into a separate functionSimon Glass
We plan to add a new way of creating a regmap for of-platdata. Move the allocation code into a separate function so that it can be shared. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14dm: core: Expand platdata for of-platdata devicesSimon Glass
Devices which use of-platdata have their own platdata. However, in many cases the driver will have its own auto-alloced platdata, for use with the device tree. The ofdata_to_platdata() method converts the device tree settings to platdata. With of-platdata we would not normally allocate the platdata since it is provided by the U_BOOT_DEVICE() declaration. However this is inconvenient since the of-platdata struct is closely tied to the device tree properties. It is unlikely to exactly match the platdata needed by the driver. In fact a useful approach is to declare platdata in the driver like this: struct r3288_mmc_platdata { struct dtd_rockchip_rk3288_dw_mshc of_platdata; /* the 'normal' fields go here */ }; In this case we have dt_platadata available, but the normal fields are not present, since ofdata_to_platdata() is never called. In fact driver model doesn't allocate any space for the 'normal' fields, since it sees that there is already platform data attached to the device. To make this easier, adjust driver model to allocate the full size of the struct (i.e. platdata_auto_alloc_size from the driver) and copy in the of-platdata. This means that when the driver's bind() method is called, the of-platdata will be present, followed by zero bytes for the empty 'normal field' portion. A new DM_FLAG_OF_PLATDATA flag is available that indicates that the platdata came from of-platdata. When the allocation/copy happens, the DM_FLAG_ALLOC_PDATA flag will be set as well. The dtoc tool is updated to output the platdata_size field, since U-Boot has no other way of knowing the size of the of-platdata struct. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14dm: core: Rename DM_NAME_ALLOCED to DM_FLAG_NAME_ALLOCEDSimon Glass
This is a flag. Adjust the name to be consistent with the other flags. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14dm: syscon: Add support for of-platdataSimon Glass
Provide a new function which can cope with obtaining information from of-platdata instead of the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14dm: regmap: Add a dummy implementation for of-platdataSimon Glass
Add a placeholder for now so that this code will compile. It currently does nothing. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14dm: core: Don't use device tree with of-platdataSimon Glass
When CONFIG_SPL_OF_PLATDATA is enabled we should not access the device tree. Remove all references to this in the core driver-model code. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-09dm: core: implement dev_map_physmem()Vignesh R
This API helps to map physical register addresss pace of device to virtual address space easily. Its just a wrapper around map_physmem() with MAP_NOCACHE flag. Signed-off-by: Vignesh R <vigneshr@ti.com> Suggested-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-06-19dm: add manual relocation for devicesAngelo Dureghello
Some architectures as m68k still need to use CONFIG_NEEDS_MANUAL_RELOC, and are not still using the device tree. Signed-off-by: Angelo Dureghello <angelo@sysam.it> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-26dm: allow setting driver_data before/during bindStephen Warren
This will allow a driver's bind function to use the driver data. One example is the Tegra186 GPIO driver, which instantiates child devices for each of its GPIO ports, yet supports two different HW instances each with a different set of ports, and identified by the udevice_id .data field. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-25fdt: Support for ISA bussesPaul Burton
Support ISA busses in much the same way as Linux does. This allows for ISA bus addresses to be translated, and only if CONFIG_OF_ISA_BUS is selected in order to avoid including the code in builds which won't need it. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-24drivers: core: device: add support to check dt compatible for a device/machineMugunthan V N
Provide an api to check whether the given device or machine is compatible with the given compat string which helps in making decisions in drivers based on device or machine compatible. Idea taken from Linux. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2016-05-17dm: core: Allow device names to be freed automaticallySimon Glass
Some devices have a name that is stored in allocated memory. At present there is no mechanism to free this memory when the device is unbound. Add a device flag to track whether a name is allocated and a function to add the flag. Free the memory when the device is unbound. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17fdt: fix dev_get_addr_name node offsetStephen Warren
Use the device's own DT offset, not the device's parent's. Fixes: 43c4d44e3330 ("fdt: implement dev_get_addr_name()") Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: core: allow drivers to refuse to bindStephen Warren
In some cases, drivers may not want to bind to a device. Allow bind() to return -ENODEV in this case, and don't treat this as an error. This can be useful in situations where some information source other than the DT node's main status property indicates whether the device should be enabled, for example other DT properties might indicate this, or the driver might query non-DT sources such as system fuses or a version number register. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-25dm: core: Add dev_get_addr_ptr() to return a pointer to the reg addressStefan Roese
On some platforms (e.g. x86), the return value of dev_get_addr() can't be assigned to a pointer type variable directly. As there might be a difference between the size of fdt_addr_t and the pointer type. On x86 for example, "fdt_addr_t" is 64bit but "void *" only 32bit. So assigning the register base directly in dev_get_addr() results in this compilation warning: warning: cast to pointer from integer of different size This patch introduces the new function dev_get_addr_ptr() that returns a pointer to the 'reg' address that can be used by drivers in this case. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-04-15fdt: implement dev_get_addr_name()Stephen Warren
This function parses the reg property based on an index found in the reg-names property. This is required for bindings that are written using reg-names rather than hard-coding indices in reg. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-04-14dm: device.c: Minor coding-style fixStefan Roese
Fix multi-line comment indentation in device_bind() Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-04-14dm: core: device: set pinctrl state for pinctrl devicePeng Fan
We may have pinmux settings for pinctrl device, like the following example: " &iomuxc { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_hog_1>; imx6ul-evk { pinctrl_hog_1: hoggrp-1 { fsl,pins = < MX6UL_PAD_UART1_RTS_B__GPIO1_IO19 0x17059 /* SD1 CD */ MX6UL_PAD_GPIO1_IO05__USDHC1_VSELECT 0x17059 /* SD1 VSELECT */ MX6UL_PAD_GPIO1_IO09__GPIO1_IO09 0x17059 /* SD1 RESET */ MX6UL_PAD_SNVS_TAMPER0__GPIO5_IO00 0x80000000 >; }; [......] }; " We should not only select pinctrl state for non pinctrl devices, we need also to handle pin mux settings such as pinctrl_log for pinctrl devices. So at the end of probing process of pinctrl device, select the default state of pinctrl device. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-17syscon: Avoid returning a device on failureSimon Glass
If the device cannot be probed, syscon_get_by_driver_data() will still return a useful value in its devp parameter. Ensure that it returns NULL instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-14dm: core: make simple-bus compatible to simple-mfdMasahiro Yamada
Simple MFD devices can bind children without special bus configuration. Like Linux, let's handle "simple-mfd" in the same way as "simple-bus". Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-03-14dm: core: Add uclass_first_device_err() to return a valid deviceSimon Glass
A common pattern is to call uclass_first_device() and then check if it actually returns a device. Add a new function which does this, returning an error if there are no devices in that uclass. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-28dm: Remove device_probe_child()Simon Glass
This function is not used as the use case for it did not eventuate. Remove it to avoid confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: syscon: Allow finding devices by driver dataSimon Glass
We have a way to find a regmap by its syscon driver data value. Add the same for syscon itself. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: core: Display the error number when driver binding failsSimon Glass
This is often -96 (-EPFNOSUPPORT) which indicates that the uclass is not compiled in. Display the error number to make this easier to spot. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-21dm: core: Export uclass_find_device_by_of_offset()Simon Glass
It is sometimes useful to be able to find a device before probing it, perhaps to set up some platform data for it. Allow finding by of_offset also. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: core: Don't set pinctrl for pinctrl devicesSimon Glass
There is sort-of race condition when a pinctrl device is probed. The pinctrl function is called which may end up using the same device as is being probed. This results in operations being used before the device is actually probed. For now, disallow pinctrl operations on pinctrl devices while probing. An alternative solution would be to move the operation to later in the device_probe() function (for pinctrl devices only) but this needs more thought. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-20dm: core: Call uclass post_bind() after the driver's bind() methodSimon Glass
At present the uclass's post_bind() method is called before the driver's bind() method. This means that the uclass cannot use any of the information set up by the driver. Move it later in the sequence to permit this. This is an ordering change which is always fairly major in nature. The main impact is that devices which have children will not see them appear in their bind() method. From what I can see, existing drivers do not look at their children in the bind() method, so this should be safe. Conceptually this change seems to result in a 'more correct' ordering, since the uclass (which is broader than the device) gets the last word. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-20dm: core: Provide uclass_find_device_by_phandle() only when neededSimon Glass
This function cannot be used unless support is enabled for device tree control. Adjust the code to reflect that. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-13Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2016-01-13dm: core: Add a new api to get indexed device addressMugunthan V N
Add new api to get device address based on index. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Acked-by: Jagan Teki <jteki@openedev.com> [Rebased on master] Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spl: dm: Add SPL_DM_SEQ_ALIAS config optionNathan Rossi
The Device Model sequence alias feature is required by some Uclasses. Instead of disabling the feature for all SPL targets allow it to be configured. The config option is disabled by default to reduce code size for targets that are not interested or do not require this feature. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Marek Vasut <marex@denx.de> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-12dm: core: Add option to configure an offset for the address translationStefan Roese
Some platforms need to ability to configure an offset to the standard addresses extracted from the device-tree. This patch allows this by adding a function to DM to configure this offset (if needed). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Simon Glass <sjg@chromium.org> Cc: Simon Glass <sjg@chromium.org> Fixed space before tab: Signed-off-by: Simon Glass <sjg@chromium.org>
2015-12-10dm: core: Fix Kconfig text to mention SPL in SPL_OF_TRANSLATEStefan Roese
Add a remark about SPL to this Kconfig option. Otherwise its identitcal to the non-SPL version, which is confusing. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Michal Simek <michal.simek@xilinx.com>
2015-12-07dm: core: Enable SPL_SIMPLE_BUS by defaultMichal Simek
This option is needed for all SoCs which have nodes on bus. Without enabling this drivers are not found and probed. Issue was found on Zynq MMC probe. Enable this option by default. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-12-01dm: core: Add SPL Kconfig for REGMAP and SYSCONhuang lin
Add SPL Kconfig for REGMAP and SYSCON, so REGMAP and SYSCON can remove from SPL stage. Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-19Revert "dm: Export device_remove_children / device_unbind_children"Simon Glass
This reverts commit bb52b367f6ca4a3a918e77737f4ff6a1089912d9. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19dm: core: Add missing entries for manual relocationMichal Simek
Patches: "dm: core: Add a post_bind method for parents" (sha1: 0118ce79577f9b0881f99a6e4f8a79cd5014cb87) "dm: core: Add a uclass pre_probe() method for devices" (sha1: 02c07b3741f1b825934b1a6eb8f23530532dc426) "dm: core: Allow the uclass to set up a device's child after binding" (sha1: 081f2fcbd9a95ba10677065359791f8fea3f8c58) "dm: core: Allow uclass to set up a device's child before it is probed" (sha1: 83c7e434c9dd3ca81f8b763e23c1881b973bcf2f) Adds new entries to struct driver and struct uclass_driver without extending code for manual relocation. This patch fixes it for all architectures which requires MANUAL_RELOC. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-29Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2015-10-29dm: core: Remove unnecessary codes in uclass_pre_remove_device()Bin Meng
dev->uclass->uc_drv->per_device_auto_alloc_size is to be freed in device_free(), so is dev->seq. Remove these unnecessary codes. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
