path: root/drivers/mailbox/Makefile
2016-06-19mailbox: add Tegra186 HSP driverStephen Warren
Tegra186's HSP module implements doorbells, mailboxes, semaphores, and shared interrupts. This patch provides a driver for HSP, and hooks it into the mailbox API. Currently, only doorbells are supported. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-26mailbox: implement a sandbox testStephen Warren
This adds a sandbox mailbox implementation (provider), a test client device, instantiates them both from Sandbox's DT, and adds a DM test that excercises everything. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> # v1
2016-05-26Add a mailbox driver framework/uclassStephen Warren
A mailbox is a hardware mechanism for transferring small message and/or notifications between the CPU on which U-Boot runs and some other device such as an auxilliary CPU running firmware or a hardware module. This patch defines a standard API that connects mailbox clients to mailbox providers (drivers). Initially, DT is the only supported method for connecting the two. The DT binding specification (mailbox.txt) was taken from Linux kernel v4.5's Documentation/devicetree/bindings/mailbox/mailbox.txt. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
