path: root/drivers/mmc/mxcmmc.c
2016-08-05mmc: use the generic error numberJaehoon Chung
Use the generic error number instead of specific error number. If use the generic error number, it can debug more easier. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2014-03-24mmc: Split mmc struct, rework mmc initialization (v2)Pantelis Antoniou
The way that struct mmc was implemented was a bit of a mess; configuration and internal state all jumbled up in a single structure. On top of that the way initialization is done with mmc_register leads to a lot of duplicated code in drivers. Typically the initialization got something like this in every driver. struct mmc *mmc = malloc(sizeof(struct mmc)); memset(mmc, 0, sizeof(struct mmc); /* fill in fields of mmc struct */ /* store private data pointer */ mmc_register(mmc); By using the new mmc_create call one just passes an mmc config struct and an optional private data pointer like this: struct mmc = mmc_create(&cfg, priv); All in tree drivers have been updated to the new form, and expect mmc_register to go away before long. Changes since v1: * Use calloc instead of manually calling memset. * Mark mmc_register as deprecated. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-03-24mmc: Convert mmc struct's name array to a pointerPantelis Antoniou
Using an array is pointless; even more pointless (and scary) is using sprintf to fill it without a format string. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-03-24mmc: Remove ops from struct mmc and put in mmc_opsPantelis Antoniou
Remove the in-structure ops and put them in mmc_ops with a constant pointer to it. This makes the mmc structure smaller as well as conserving code space (in theory). All in-tree drivers are converted as well; this is done in a single patch in order to not break git bisect. Changes since V1: Fix compilation b0rked issue on omap platforms where OMAP_GPIO was not set. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-03-08mmc: add support for write protectionNikita Kiryanov
Add generic mmc write protection functionality. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12mmc: access mxcmmc from mx31 boardsHelmut Raiger
This patch modifies mxcmmc.c to be used not only by i.MX27 but also by i.MX31 boards. Both use the same SD controller, but have different clock set-ups. The i.MX27 imx_get_XXXclock functions are made static to generic.c and a public mxc_get_clock() function is provided. Pins, base address and prototypes for an i.MX31 specific board_init_mmc() are provided. Some of the i.MX27 clock getters are unused and marked as such to avoid warnings (./MAKEALL -s mx27), but the code was left in for future use. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-08mmc: Implement card detection.Thierry Reding
Check for card detect each time an MMC/SD device is initialized. If card detection is not implemented, this code behaves as before and continues assuming a card is present. If no card is detected, has_init is reset for the MMC/SD device (to force initialization next time) and an error is returned. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Tested-by: Jason Liu <jason.hui@linaro.org>
2011-04-29MMC: make b_max unconditionalJohn Rigby
Make existing field b_max field in struct mmc unconditional and use it instead of CONFIG_SYS_MMC_MAX_BLK_COUNT in mmc_bread and mmc_bwrite. Initialize b_max to CONFIG_SYS_MMC_MAX_BLK_COUNT in mmc_register if it has not been initialized by the hw driver. Initialize b_max to 0 in all callers to mmc_register. Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2010-03-21mxcmmc: fix warnings due to access 32 bit registers with 16 bit accessorsStefano Babic
Some registers of the mxcmmc driver were accessed using 16 bit accessor functions, because only the LSB is significant. This is not needed and generates warnings. Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-08-10Minor coding style cleanup.Wolfgang Denk
2009-08-09mxc-mmc: sdhc host driver for MX2 and MX3 proccessorIlya Yanok
This is a port of Linux driver for SDHC host controller hardware found on Freescale's MX2 and MX3 processors. Uses new generic MMC framework (CONFIG_GENERIC_MMC) and it looks like there are some problems with a framework (at least on LE cpus). Some of these problems are addressed in the following patches. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
