path: root/drivers/spi/sh_qspi.c
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-27spi: sh_qspi: Use BIT macroJagan Teki
Replace numerical bit shift with BIT macro in sh_qspi :%s/(1 << nr)/BIT(nr)/g where nr = 0, 1, 2 .... 31 Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2014-01-16spi: sh_qspi: Add header file that defines the address of registersNobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-12-18spi: Add support SH Quad SPI driverNobuhiro Iwamatsu
This patch adds a driver for Renesas SoC's Quad SPI bus. This supports with 8 bits per transfer to use with SPI flash. Signed-off-by: Kouei Abe <kouei.abe.cp@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
