using it
When booting from a non-MMC device, the MMC sub-system may not be
initialized when the environment is first accessed.
We need to make sure that the MMC sub-system is ready in even a non-MMC
boot case.
Therefore, initialize mmc before loading environment from it.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
When saving the environment on a platform which has DMA alignment
larger than the natural alignment, env_fat_save triggers a debug
message in file_fat_write:
Saving Environment to FAT... writing uboot.env
FAT: Misaligned buffer address (9df1c8e0)
OK
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
For multiple env drivers to correctly implement fallback when
one environment fails to load (e.g. crc error), the return value
of env_import has to be propagated by all env driver's load
function.
Without this change, the first driver that succeeds to load an
environment with an invalid CRC return 0 (success) and no other
drivers are checked.
Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Since we have global messages to indicate what's going on, the custom
messages in the environment drivers only make the output less readable.
Make FAT play a little nicer by removing all the extra \n and formatting
that is redundant with the global output.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The load() methods have inconsistent behaviour on error. Some of them load
an empty default environment. Some load an environment containing an error
message. Others do nothing.
As a step in the right direction, have the method return an error code.
Then the caller could handle this itself in a consistent way.
This variable is declared as a global in most environment location
drivers. But it is not used outside the drivers and most of the
declarations are unnecessary.
Also some drivers call free() on env_ptr which seems wrong since it is
not in the heap.
Drop the variable where possible, and all calls to free().
Add a name to the driver and use that instead of the global variable
declared by each driver.
Most of the init() implementations just use the default environment.
Adjust env_init_new() to do this automatically, and drop the redundant
code.
Move over to use a the master implementation of the location drivers, with
each method calling out to the appropriate driver.
Set up a location driver for each supported environment location. At
present this just points to the global functions and is not used. A
later patch will switch this over to use private functions in each driver.
There are several special cases here in various drivers to handle
peculiarities of certain boards:
1. Some boards define CONFIG_ENV_IS_IN_FAT and CONFIG_SPL_ENV_SUPPORT but
do not actually load the environment in SPL. The env load code was
optimised out before but with the driver, it is not. Therefore a special
case is added to env/fat.c. The correct fix (depending on board testing
might be to disable CONFIG_SPL_ENV_SUPPORT.
2. A similar situations happens with CONFIG_ENV_IS_IN_FLASH. Some boards
do not actually load the environment in SPL, so to reduce code size we
need to drop that code. A similar fix may be possible with these boards,
or it may be possible to adjust the environment CONFIG settings.
Added to the above is that the CONFIG_SPL_ENV_SUPPORT option does not
apply when the environment is in flash.
Obviously the above has been discovered through painful and time-consuming
trial and error. Hopefully board maintainers can take a look and figure
out what is actually needed.
At present we have three states for the environment, numbered 0, 1 and 2.
Add an enum to record this to avoid open-coded values.
About a quarter of the files in common/ relate to the environment. It
seems better to put these into their own subdirectory and remove the
prefix.
