2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2003-03-06 | * Patches by Robert Schwebel, 06 Mar 2003: | wdenk | |
- fix bug in BOOTP code (must use NetCopyIP) - update of CSB226 port - clear BSS segment on XScale - added support for i2c_init_board() function - update to the Innokom plattform * Extend support for redundand environments for configurations where environment size < sector size | |||
2002-08-27 | Initial revision | wdenk | |
