path: root/include/configs/am335x_sl50.h
2016-10-02config: Remove usage of CONFIG_STORAGE_EMMCAndrew F. Davis
This config option seems to be unused and is probably vestigial. Remove it. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-09-16Convert CONFIG_SPL_YMODEM_SUPPORT to KconfigSimon Glass
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig Move this option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_NET_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_NET_VCI_STRING to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SPL_NET_VCI_STRING Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2015-12-05eeprom: Zap CONFIG_SYS_I2C_MULTI_EEPROMSMarek Vasut
This symbol is no longer used anywhere, remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@konsulko.com> Acked-by: Heiko Schocher <hs@denx.de>
2015-09-11board: Add Toby-Churchill SL50 board support.Enric Balletbò i Serra
Add support for Lightwriter SL50 series board, a small, robust and portable Voice Output Communication Aids (VOCA) designed to meet the particular and changing needs of people with speech loss resulting from a wide range of acquired, progressive and congenital conditions. Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
