path: root/include/configs/cm-bf537e.h
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-06-01net: Fix NET_RANDOM_ETHADDR dependenciesMichal Simek
NET_RANDOM_ETHADDR depends on lib/rand.c. This patch adds dependency to Kconfig to ensure that library is also compiled. Remove the definitions from Blackfin boards' include/configs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-19net: Remove all references to CONFIG_ETHADDR and friendsJoe Hershberger
We really don't want boards defining fixed MAC addresses in their config so we just remove the option to set it in a fixed way. If you must have a MAC address that was not provisioned, then use the random MAC address functionality. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-11-17blackfin: convert to use CONFIG_SYS_I2C frameworkScott Jiang
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
2014-11-17blackfin: rename bfin-twi_i2c driver to adi_i2cScott Jiang
2014-09-24kconfig: move CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED to KconfigMasahiro Yamada
If this option is enabled, the objects under lib/ directory are compiled with speed optimization, not size optimization. (Currently, only used by some Blackfin boards.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-05-12blackfin: replace bfin_gen_rand_mac() with eth_random_addr()Masahiro Yamada
bfin_gen_rand_mac() uses __DATE__ as the seed for random ethernet address. This makes the build non-deterministic. In the first place, it should not be implemented as a Bfin-specific function. Use eth_random_addr() instead. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com>
2014-03-07kbuild, blackfin: Add CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEEDMasahiro Yamada
Many (but not all) of Blackfin boards give -O2 option to compile under lib/ directory. That means lib/ should be speed-optimized, whereas other parts should be size-optimized. We want to keep the same behavior, but do not want to parse board/*/config.mk again and again. We've got no choice but to invent a new method. CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED, if it is enabled, gives -O2 flag only for building under lib/ directory. Dirty codes which I had marked as "FIX ME" in board/${BOARD}/config.mk have been deleted. Instead, CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED has been defined in include/configs/${BOARD}.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com>
2013-12-16blackfin: fix building error by enlarging the memory sizeSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-11-17Makefile: rename all libraries to built-in.oMasahiro Yamada
2011-07-12Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: enable mmc_spi supportHarald Krapfenbauer
These boards have an mmc/sd slot on them connected over SPI, so enable the driver. Signed-off-by: Harald Krapfenbauer <harald.krapfenbauer@bluetechnix.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: update network settingsHarald Krapfenbauer
These boards can have an addon card plugged onto them, so enable support for it. Signed-off-by: Harald Krapfenbauer <harald.krapfenbauer@bluetechnix.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-03Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: update embedded env settingsHarald Krapfenbauer
The recent commit ea882baf9c1 broke embedding environments in the middle of a sector, so relocate it to the start of the 2nd sector. Signed-off-by: Harald Krapfenbauer <harald.krapfenbauer@bluetechnix.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-19Blackfin: tweak objects specified before embedded environmentMike Frysinger
The partial linking patch changes how objects are specified to the linker and breaks boards with an embedded environment. So we need to tweak the list of objects we specify via the linker script that go in the gap before the embedded env to work with this new behavior. This fixes linker errors for all the boards in question. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: unify default I2C settings for ADI boardsMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2010-04-13blackfin: Move cpu/blackfin/* to arch/blackfin/cpu/*Peter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-17Blackfin: update tiny board settings (voltage/default env)Harald Krapfenbauer
The tinyboards like to run at a little lower voltage than the default, and they prefer to boot over the network. For the latter, extend the common code a little to make this easier. Also fix the cm-bf527 env sector size while we're in here to reflect the flash that is actually in use. Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: tweak embedded LDR env config optionMike Frysinger
Use the common config option for extracting the environment for embedding into LDR files and clarify the LDR-specific option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-23Blackfin: cm-bf527/cm-bf537: increase flash sectorsHarald Krapfenbauer
Newer revisions of these boards have slightly larger flashes, so increase the configured number of sectors so that U-Boot works on all revisions. Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: unify u-boot linker scriptsMike Frysinger
All the Blackfin linker scripts were duplicated across the board dirs with no difference save from the semi-often used ENV_IS_EMBEDDED option. So unify all of them in the lib_blackfin/ dir and for the few boards that need to embedded the environment directly, add a LDS_BOARD_TEXT define for them to customize via their board config file. This is much simpler than forcing them to duplicate the rest of the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: convert specific pre/post config headers to common methodMike Frysinger
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup common Blackfin board defines. The common method now is to use config.h, so convert blackfin-config-post.h to that. Rename the still Blackfin specific blackfin-config-pre.h to config-pre.h so the naming conventions at least line up. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: cm-bf537e: new board portMike Frysinger
