path: root/include/configs/eco5pk.h
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2012-10-30eco5pk: Add new board and default configRaphael Assenat
Signed-off-by: Raphael Assenat <raph@8d.com> [trini: Squash boards.cfg / MAINTAINERS change into main patch] Signed-off-by: Tom Rini <trini@ti.com>
