path: root/include/configs/gose.h
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2015-07-01defconfig: Move CONFIG_SPI_FLASH_BAR from configsJagan Teki
This commit moves: - CONFIG_SPI_FLASH_BAR from include/configs/*.h into configs/*_defconfigs Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-02-25arm: rmobile: gose: Add support SDHINobuhiro Iwamatsu
Gose board has three SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: gose: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Gose board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-05arm: rmobile: rcar: Stop clock prior to booting kernelNobuhiro Iwamatsu
This stops clock except INTC-RT, MSIF, INTC-SYS, IRQC and SCIF before kernel boots. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-17arm: rmobile: replacement of common parts of config by rcar-gen2-common.hNobuhiro Iwamatsu
Common part of config for lager, koelsch, alt and gose board will be able to replace rcar-gen2-common.h. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: Move sh-i2c of the address defined to common headerNobuhiro Iwamatsu
R-Car SoCs of rmobile have same IP of sh-i2c, and have same address. This moves sh-i2c of the address defined to rcar-base.h as common header of R-Car SoCs, and headers of each SoCs. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: gose: Add VFAT file system supportNobuhiro Iwamatsu
2014-11-10arm: rmobile: gose: Add USB supportNobuhiro Iwamatsu
Gose board has two USB ports, and can use USB EHCI HCD driver of rmobile. This adds driver settings in order to use this driver. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: gose: Add Ethernet supportNobuhiro Iwamatsu
Gose board has one ether port, this works using sh-ether driver. This adds GPIO settings and driver settings in order to use the sh-ether. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: Add support gose boardNobuhiro Iwamatsu
The gose board has R8A7793, 1GB DDR3-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - DDR3-SDRAM - SCIF - QSPI - SPI Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
