path: root/include/configs/lager.h
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2015-07-01defconfig: Move CONFIG_SPI_FLASH_BAR from configsJagan Teki
This commit moves: - CONFIG_SPI_FLASH_BAR from include/configs/*.h into configs/*_defconfigs Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-02-25arm: rmobile: lager: Add support SDHINobuhiro Iwamatsu
Lager board has two SDHI port as SDHI0 and SDHI2. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: lager: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Lager board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-10arm: rmobile: lager: Add support MMC and MMC commandNobuhiro Iwamatsu
Lager board has been connected to eMMC of 8GB to MMC1 port. This enables MMC1 port and MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-05arm: rmobile: rcar: Stop clock prior to booting kernelNobuhiro Iwamatsu
This stops clock except INTC-RT, MSIF, INTC-SYS, IRQC and SCIF before kernel boots. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-17arm: rmobile: replacement of common parts of config by rcar-gen2-common.hNobuhiro Iwamatsu
Common part of config for lager, koelsch, alt and gose board will be able to replace rcar-gen2-common.h. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: Move rcar-i2c of the address defined to common headerNobuhiro Iwamatsu
R-Car SoCs of rmobile have same IP of rcar-i2c, and have same address. This moves rcar-i2c of the address defined to rcar-base.h as common header of R-Car SoCs. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: lager: Remove board_late_init functionNobuhiro Iwamatsu
Lager board does not use board_late_init function. This removes this function and define of BOARD_LATE_INIT from config. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-04arm: rmobile: lager: Add external RAM bootNobuhiro Iwamatsu
If CONFIG_RMOBILE_EXTRAM_BOOT is enabled, U-Boot is booted from External RAM. The default boot address is 0xB0000000. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-10-09arm: rmobile: lager: Add CONFIG_SCIF_USE_EXT_CLKNobuhiro Iwamatsu
SCIF of lager use external clock mode. This enables external clock mode on lager board. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-10-09arm: rmobile: lager: Fix value of CONFIG_SH_SCIF_CLK_FREQNobuhiro Iwamatsu
The clock of SCIF (serial port) of lager is supplied from External Clock. And value of clock is 14.7456MHz. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-08-30rmobile: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Rmobile board select menu to rmobile/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="rmobile"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-08-09usb: ehci: rmobile: Remove xHCI addressNobuhiro Iwamatsu
echi-rmobile does not support xHCI. This removes xHCI address from address table. And this revise a value of CONFIG_USB_MAX_CONTROLLER_COUNT for lager board and koelsh board. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: lager: Enable CONFIG_SYS_GENERIC_BOARDNobuhiro Iwamatsu
Add CONFIG_SYS_GENERIC_BOARD to use common/board_*.c for lager. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: lager: Add support ext4/fat write commandNobuhiro Iwamatsu
2014-05-21arm: rmobile: lager: Add support command and filesystems of VFATNobuhiro Iwamatsu
2014-05-21arm: rmobile: lager: Add support USB controllerNobuhiro Iwamatsu
Lager board has USB ports. This add support of USB controller of rmobile. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: lager: Enable optimization of thumbNobuhiro Iwamatsu
This adds CONFIG_SYS_THUMB_BUILD to config, in order to enable optimization of thumb. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: lager: Remove CONFIG_USE_ARCH_MEMSET and MEMCPYNobuhiro Iwamatsu
Because do not need these feature to lager board, this delete it. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: lager: Remove define of SCIF registerNobuhiro Iwamatsu
The define of SCIF register was already defined in rcar-base.h. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-04-28arm: rmobile: lager: Remove MACH_TYPE_LAGER and CONFIG_MACH_TYPENobuhiro Iwamatsu
MACH_TYPE_LAGER and CONFIG_MACH_TYPE are not already available on Lager board. This removes them. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: lager: Update calculation of CONFIG_SH_TMU_CLK_FREQNobuhiro Iwamatsu
CONFIG_SH_TMU_CLK_FREQ of lager is calculated from the external clock. This defines RMOBILE_XTAL_CLK, this updates the calculation of CONFIG_SH_TMU_CLK_FREQ. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: lager: Remove NOR-Flash supportNobuhiro Iwamatsu
Lagar board has NOR-Flash. But user uses SPI-Flash ROM instead of NOR-Flash. This removed the setting of NOR-Flash. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-02-19configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZEMasahiro Yamada
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c) GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19config: remove platform CONFIG_SYS_HZ definition part 3Masahiro Yamada
This commit removes platform CONFIG_SYS_HZ definition for the remainders of part1 (commit cdb23792) and part2 (commit f232950f). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Rob Herring <rob.herring@calxeda.com>
2014-01-16arm: lager: Add support QSPI device and enable boot from SPI flashNobuhiro Iwamatsu
This supports SH-QSPI device on lager board, and enable booting from SPI flash. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-12-18arm: lager: Add support reset functionNobuhiro Iwamatsu
The lager board uses I2C for reset. ned-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2013-12-18arm: lager: Add support I2CNobuhiro Iwamatsu
The lager board has I2C for rcar. This supports I2C for rcar on lager board. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2013-12-18arm: lager: Add support EthernetNobuhiro Iwamatsu
The lager board has one sh-ether device. This supports sh-ether. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2013-12-03arm: rmobile: Add support lager boardNobuhiro Iwamatsu
The lager board has R8A7790, 4GB DDR3-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - DDR3-SDRAM - SCIF Signed-off-by: Kouei Abe <kouei.abe.cp@renesas.com> Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Ryo Kataoka <ryo.kataoka.wt@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
