path: root/include/configs/rpi.h
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06serial: bcm283x_mu: Detect disabled serial deviceAlexander Graf
On the raspberry pi, you can disable the serial port to gain dynamic frequency scaling which can get handy at times. However, in such a configuration the serial controller gets its rx queue filled up with zero bytes which then happily get transmitted on to whoever calls getc() today. This patch adds detection logic for that case by checking whether the RX pin is mapped to GPIO15 and disables the mini uart if it is not mapped properly. That way we can leave the driver enabled in the tree and can determine during runtime whether serial is usable or not, having a single binary that allows for uart and non-uart operation. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-05-26arm: rpi: Define CONFIG_TFTP_TSIZE to show tftp size infoSimon Glass
This shows a proper progress display and the total amount of data transferred. Enable it for Raspberry Pi. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2016-04-16ARM: rpi: fix 64-bit CONFIG_SYS_TEXT_BASEStephen Warren
The Pi firmware has changed the default "kernel" load address for 64-bit mode. The authors have confirmed that this is a deliberate and long-term change. Adapt U-Boot to the new value. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2016-04-11rpi: remove redundant board filesStephen Warren
Now that rpi_*defconfig and Kconfig (rather than the config header file) provide the identity of the build, we don't need to separate config headers and board directories for each RPi variant. Set CONFIG_SYS_BOARD and CONFIG_SYS_CONFIG_NAME so that we can get rid of the duplication. This requires a tiny number of extra ifdefs in the config header. The only disadvantage of this approach is that the $board/$board_name environment variables aren't as descriptive as they used to be. This isn't really an issue because those only exist to allow scripts to create DTB filenames at runtime. However, the RPi board code already sets $fdtfile to something more accurate based on FW-reported board ID anyway. While at it, unify some Kconfig select options, and add a MAINTAINERS entry for bcm283x too. Partially-suggested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01ARM: bcm2835: move CONFIG_BCM283* to KconfigStephen Warren
2016-03-27ARM: bcm283x: don't always define CONFIG_BCM2835Stephen Warren
Currently, CONFIG_BCM2835 is defined for all BCM283x builds and _BCM2836 is defined when building for that SoC. That means there isn't a single define that means "exactly BCM2835". This will complicate future patches where BCM2835-vs-anything-else needs to be determined simply. Modify the code to define one or the other of CONFIG_BCM2835/BCM2836 so future patches are simpler. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-12ARM: bcm283x: Define CONFIG_SYS_CACHELINE_SIZEAlexander Stein
The cacheline is always 32 bytes for arm1176 CPUs, so define it at board config level for cache handling code. The ARM Cortex-A7 has a dcache line size of 64 bytes. Signed-off-by: Alexander Stein <alexanders83@web.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org>
2015-02-21rpi: add support for Raspberry Pi 2 model BStephen Warren
USB doesn't seem to work yet; the controller detects the on-board Hub/ Ethernet device but can't read the descriptors from it. I haven't investigated yet. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-02-21bcm2835/rpi: add SPDX license tags for some filesStephen Warren
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Move Raspberry Pi driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config header and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-11dm: rpi: Move serial to driver modelSimon Glass
Adjust the configuration to use the driver model version of the pl01x serial driver. Add the required platform data. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org>
2014-12-08ARM: rpi: support an environmentStephen Warren
Enable ENV_IS_IN_FAT so that the environment can be stored persistently. It's stored in the FAT partition that the RPi firmware requires. On most RPis, this is on the SD card (which must be present in order for the system to boot). On the CM this is on the built-in eMMC device. Since we now have a persistent environment, there's no need to load uEnv.txt at boot; we only did that to work around the lack of persistent environment. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-12-08ARM: rpi: rename rpi_b to rpiStephen Warren
The U-Boot port runs on a variety of RPi models, not just the B. So, rename the port to something slightly more generic. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
