path: root/include/configs/smdkv310.h
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-12-17usb: s3c-otg: Rename USB_GADGET_S3C_UDC_OTG* to USB_GADGET_DWC2_OTG*Marek Vasut
The s3c-otg IP block is in fact a DWC2 OTG one, so finally rename the config option to make it less misleading. No functional change, just a mechanical change done using the following script: git grep USB_GADGET_S3C_UDC_OTG | cut -d : -f 1 | sort -u | \ while read line ; do sed -i "s/USB_GADGET_S3C_UDC_OTG/USB_GADGET_DWC2_OTG/g" $line ; done Signed-off-by: Marek Vasut <marex@denx.de>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-07usb: s3c-otg: Split out PHY controlMarek Vasut
Split the Samsung specific PHY control into a separate file and compile this into the S3C OTG driver only if used on a Samsung system. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Vince Bridgers <vbridger@altera.com> Acked-by: Pavel Machek <pavel@denx.de> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2014-10-08config: Move smdkv310 to use common exynos4 fileSimon Glass
Most of the smdkv310 features are common with other exynos4 boards. To permit easier addition of driver model support, use the common file and add a device tree file. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-05-13S5P: Exynos: Config: Enable GPIO CMD configAkshay Saraswat
Enabling configs for GPIO CMD, EXYNOS4 family and replacing exynos_gpio_get with new linear GPIO pin number required because of the new function asking only 2 arguments (pin and value) instead of 3 (bank, pin and value). Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-11-15configs: clean up unused macro CONFIG_L2_OFFMasahiro Yamada
Since commit c2dd0d455 and 45bf05854 introduced the new cache maintainance framework to ARM, CONFIG_L2_OFF has not been used at all. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-05EXYNOS: Move files from board/samsung to arch/armRajeshwari Shinde
This patch performs the following: 1) Convert the assembly code for memory and clock initialization to C code. 2) Move the memory and clock init codes from board/samsung to arch/arm 3) Creat a common lowlevel_init file across Exynos4 and Exynos5. Converted the common lowlevel_init from assembly to C-code 4) Made spl_boot.c and tzpc_init.c common for both exynos4 and exynos5. 5) Enable CONFIG_SKIP_LOWLEVEL_INIT as stack pointer initialisation is already done in _main. 6) exynos-uboot-spl.lds made common across SMDKV310, Origen and SMDK5250. TEST: Tested SD-MMC boot on SMDK5250 and Origen. Tested USB and SPI boot on SMDK5250 Compile tested for SMDKV310. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS4210: Configure GPIO for uartRajeshwari Shinde
This patch configures the gpio values for UART on Origen and SMDKV310 using pinmux Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-04exynos: Update origen and smdkv310 to use common tzpc_initInderpal Singh
Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Acked-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-08ARM: SAMSUNG: support sdhci controllerJaehoon Chung
To support sdhci controller, remove the CONFIG_S5P_MMC.. Instead, use the CONFIG_S5P_SDHCI/CONFIG_SDHCI. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Lei Wen<leiwen@marvell.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2011-12-09S5PC2XX: Rename S5pc2XX to exynosChander Kashyap
As per new naming convention for Samsung SoC's, all Cortex-A9 and Cortex-A15 based SoC's will be classified under the name Exynos. Cortex-A9 and Cortex-A15 based SoC's will be sub-classified as Exynos4 and Exynos5 respectively. In order to better adapt and reuse code across various upcoming Samsung Exynos based boards, all uses of s5pc210 prefix/suffix/directory-names are renamed in this patch. s5pc210 is renamed as exynos4210 and S5PC210/s5pc210 suffix/prefix are renamed as exynos4/EXYNOS4. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-11-03smdkv310: use macro for mmc data read function addressChander Kashyap
board/samsung/smdkv310/mmc_boot.c: Removed the typedef for "mmc data read API (copy_sd_mmc_to_mem)" as it is used only once and replaced hard-coded API address value by macro. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-11-03smdkv310: use spl framework for mmc splChander Kashyap
smdkv310 board was using mmc_spl framework for mmc spl support. This patch migrates the framework from mmc_spl to spl. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-11-03SMDKV310: Initialize board id using CONFIG_MACH_TYPEChander Kashyap
Use CONFIG_MACH_TYPE generic macro to initialize board id. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-08-04SMDKV310: Enable device tree supportThomas Abraham
Enable passing a flattened device tree to the kernel. Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
2011-08-04Removed unused define, CONFIG_ARMV7.Christopher Harvey
Signed-off-by: Christopher Harvey <charvey@matrox.com>
2011-05-26ARMV7: Add support for Samsung SMDKV310 BoardChander Kashyap
SMDKV310 board is based on Samsung S5PV310 SOC. This SOC is very much similar to S5PC210. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
