path: root/include/efi_api.h
2016-10-19smbios: Expose in efi_loader as tableAlexander Graf
We can pass SMBIOS easily as EFI configuration table to an EFI payload. This patch adds enablement for that case. While at it, we also enable SMBIOS generation for ARM systems, since they support EFI_LOADER. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-06-06efi_loader: Add exit supportAlexander Graf
Some times you may want to exit an EFI payload again, for example to default boot into a PXE installation and decide that you would rather want to boot from the local disk instead. This patch adds exit functionality to the EFI implementation, allowing EFI payloads to exit. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-05-27efi_loader: Add network access supportAlexander Graf
We can now successfully boot EFI applications from disk, but users may want to also run them from a PXE setup. This patch implements rudimentary network support, allowing a payload to send and receive network packets. With this patch, I was able to successfully run grub2 with network access inside of QEMU's -M xlnx-ep108. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-04-18efi_loader: Increase path string to 32 charactersAlexander Graf
Whenever we want to tell our payload about a path, we limit ourselves to a reasonable amount of characters. So far we only passed in device names - exceeding 16 chars was unlikely there. However by now we also pass real file path information, so let's increase the limit to 32 characters. That way common paths like "boot/efi/bootaa64.efi" fit just fine. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-27efi_loader: Add GOP supportAlexander Graf
The EFI standard defines a simple boot protocol that an EFI payload can use to access video output. This patch adds support to expose exactly that one (and the mode already in use) as possible graphical configuration to an EFI payload. With this, I can successfully run grub2 with graphical output. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-15include/efi_api.h: Add more detailed API definitionsAlexander Graf
The EFI API header is great, but missing a good chunk of function prototype, GUID defines and enum declarations. This patch extends it to cover more of the EFI API. It's still not 100% complete, but sufficient enough for our EFI payload interface. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-08-05efi: Add start-up library codeSimon Glass
When running as an EFI application, U-Boot must request memory from EFI, and provide access to the boot services U-Boot needs. Add library code to perform these tasks. This includes efi_main() which is the entry point from EFI. U-Boot is built as a shared library. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
