path: root/include/iotrace.h
2016-05-17Allow iotrace byte access to use an address of any sizeSimon Glass
If an address is used with readb() and writeb() which is smaller than the expected size (e.g. 32-bit value on a machine with 64-bit addresses), a warning results. Fix this by adding a cast. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-20Add an I/O tracing featureSimon Glass
When debugging drivers it is useful to see what I/O accesses were done and in what order. Even if the individual accesses are of little interest it can be useful to verify that the access pattern is consistent each time an operation is performed. In this case a checksum can be used to characterise the operation of a driver. The checksum can be compared across different runs of the operation to verify that the driver is working properly. In particular, when performing major refactoring of the driver, where the access pattern should not change, the checksum provides assurance that the refactoring work has not broken the driver. Add an I/O tracing feature and associated commands to provide this facility. It works by sneaking into the io.h heder for an architecture and redirecting I/O accesses through its tracing mechanism. For now no commands are provided to examine the trace buffer. The format is fairly simple, so 'md' is a reasonable substitute. Note: The checksum feature is only useful for I/O regions where the contents do not change outside of software control. Where this is not suitable you can fall back to manually comparing the addresses. It might be useful to enhance tracing to only checksum the accesses and not the data read/written. Signed-off-by: Simon Glass <sjg@chromium.org>
