path: root/include/linux/bitops.h
2009-09-17Correct ffs/fls regression for PowerPC etcSimon Kagstrom
Commits 02f99901ed1c9d828e3ea117f94ce2264bf8389e 52d61227b66d4099b39c8309ab37cb67ee09a405 introduced a regression where platform-specific ffs/fls implementations were defined away. This patch corrects that by using PLATFORM_xxx instead of the name itself. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de>
2009-09-15Define ffs/fls for all architecturesSimon Kagstrom
UBIFS requires fls(), which is not defined for arm (and some other architectures) and this patch adds it. The implementation is taken from Linux and is generic. ffs() is also defined for those that miss it. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2009-09-15Move __set/clear_bit from ubifs.h to bitops.hSimon Kagstrom
__set_bit and __clear_bit are defined in ubifs.h as well as in asm/include/bitops.h for some architectures. This patch moves the generic implementation to include/linux/bitops.h and uses that unless it's defined by the architecture. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2000-08-21Initial revisionwdenk
