path: root/include/spi_flash.h
2016-10-06spi: Move freescale-specific code into a private headerSimon Glass
At present there are two SPI functions only used by freescale which are defined in the spi_flash.h header. One function name matches an existing generic SPL function. Move these into a private header to avoid confusion. Arcturus looks like it does not actually support SPI, so drop the SPI code from that board. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-13sf: Remove spi_flash_removeJagan Teki
Use direct call to device_remove instead of exctra spi_flash_remove defination. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-11-13sf: Fix NULL pointer exception for flashes without lock methodsBin Meng
commit c3c016c "sf: Add SPI NOR protection mechanism" introduced flash_lock()/flash_unlock()/flash_is_locked() methods for SPI flash, but not every flash driver supplies these. We should test these methods against NULL before actually calling them. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-11-05sf: Add SPI NOR protection mechanismFabio Estevam
Many SPI flashes have protection bits (BP2, BP1 and BP0) in the status register that can protect selected regions of the SPI NOR. Take these bits into account when performing erase operations, making sure that the protected areas are skipped. Tested on a mx6qsabresd: => sf probe SF: Detected M25P32 with page size 256 Bytes, erase size 64 KiB, total 4 MiB => sf protect lock 0x3f0000 0x10000 => sf erase 0x3f0000 0x10000 offset 0x3f0000 is protected and cannot be erased SF: 65536 bytes @ 0x3f0000 Erased: ERROR => sf protect unlock 0x3f0000 0x10000 => sf erase 0x3f0000 0x10000 SF: 65536 bytes @ 0x3f0000 Erased: OK Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> [re-worked to fit the lock common to dm and non-dm] Signed-off-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-10-25sf: Add FSR support to spi_flash_cmd_wait_readyJagan Teki
This patch adds flag status register reading support to spi_flash_cmd_wait_ready. Cc: Simon Glass <sjg@chromium.org> Cc: Marek Vasut <marex@denx.de> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Stefan Roese <sr@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Tom Rini <trini@konsulko.com> Cc: Hou Zhiqiang <B48286@freescale.com> Tested-by: Jagan Teki <jteki@openedev.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-10-25sf: Make flash->flags use for generic usageJagan Teki
Use the flash->flags for generic usage, not only for dm-spi-flash, this will be used for future flag additions. [Correct the spi flash flags detect logic] Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-07-01spi/sf: Minor cleanupsJagan Teki
- Adjust tab spaces - Add comments Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-04-28dm: sf: Save flash flags to struct spi_flashBin Meng
Add a new member 'flags' in struct spi_flash to store the flash flags during spi_flash_validate_params(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2015-04-22spi flash: fix trivial problemsPavel Machek
Fix typos and too big #ifdef. Signed-off-by: Pavel Machek <pavel@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2015-04-18dm: sf: Add driver model read/write/erase methodsSimon Glass
Permit use of a udevice to talk to SPI flash. Ultimately we would like to retire the use of 'struct spi_flash' for this purpose, so create the new API for those who want to move to it. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: sf: Add a uclass for SPI flashSimon Glass
Add a driver model uclass for SPI flash which supports the common operations (read, write, erase). Since we must keep support for the non-dm interface, some modification of the spi_flash header is required. CONFIG_DM_SPI_FLASH is used to enable driver model for SPI flash. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-10-22sf: Tidy up public and private header filesSimon Glass
Since spi_flash.h is supposed to be the public API for SPI flash, move private things to sf_internal.h. Also tidy up a few comment nits. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-09-24spl: replace CONFIG_SPL_SPI_* with CONFIG_SF_DEFAULT_*Nikita Kiryanov
Currently, CONFIG_SPL_SPI_* #defines are used for controlling SPI boot in SPL. These #defines do not allow the user to select SPI mode for the SPI flash (there's no CONFIG_SPL_SPI_MODE, so the SPI mode is hardcoded in spi_spl_load.c), and duplicate information already provided by CONFIG_SF_DEFAULT_* #defines. Kill CONFIG_SPL_SPI_*, and use CONFIG_SF_DEFAULT_* instead. Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Hannes Petermaier <hannes.petermaier@br-automation.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-04-22driver: Add support of image load for MMC & SPI in SPLPrabhakar Kushwaha
Add support of loading image, binary for MMC and SPI during SPL boot. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-07Cosmetic: Typo fixesVasili Galka
Signed-off-by: Vasili Galka <vasili@visionmap.com>
2014-01-12sf: Add dual memories support - DUAL_PARALLELJagannadha Sutradharudu Teki
This patch added support for accessing dual memories in parallel connection with single chipselect line from controller. For more info - see doc/SPI/README.dual-flash Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-12sf: Add dual memories support - DUAL_STACKEDJagannadha Sutradharudu Teki
This patch added support for accessing dual memories in stacked connection with single chipselect line from controller. For more info - see doc/SPI/README.dual-flash Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-12sf: Code cleanupsJagannadha Sutradharudu Teki
- comment typo's - func args have a proper names Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-11sf: Discover read dummy_byteJagannadha Sutradharudu Teki
Discovered the read dummy_byte based on the configured read command. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-11sf: Add QUAD_IO_FAST read supportJagannadha Sutradharudu Teki
This patch adds support QUAD_IO_FAST read command. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-11sf: Separate the flash params tableJagannadha Sutradharudu Teki
Moved the flash params table from sf_probe.c and placed on to sf_params.c, hence flash params file will alter based on new addons. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-11sf: Add quad read/write commands supportJagannadha Sutradharudu Teki
This patch add quad commands support like - QUAD_PAGE_PROGRAM => for write program - QUAD_OUTPUT_FAST ->> for read program Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-11sf: Add extended read commands supportJagannadha Sutradharudu Teki
Current sf uses FAST_READ command, this patch adds support to use the different/extended read command. This implementation will determine the fastest command by taking the supported commands from the flash and the controller, controller is always been a priority. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-12-09spi_flash: Add spi_flash_probe_fdt() to locate SPI by FDT nodeSimon Glass
This allows us to put the SPI flash chip inside the SPI interface node, with U-Boot finding the correct bus and chip select automatically. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-10-07sf: Minor cleanupsJagannadha Sutradharudu Teki
- Add spaces, tabs - Commenting. - Rearrange code. - Add static qualifier for missing func. - Remove memory_map from ramtron.c - Ramtron: spi_flash_internal.h -> sf_internal.h Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-10-07sf: spi_flash cleanupsJagannadha Sutradharudu Teki
More cleanups on spi_flash side: - Removed unneeded comments. - Rearranged macros in proper location. - Rearranged func declerations - Renamed few function names. - Added License headers. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-10-07sf: Remove spi_flash_do_alloc referencesJagannadha Sutradharudu Teki
Added a support for common probe, hence removed removed spi_flash_do_alloc reference. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-10-07sf: Add proper comment style on spi_flash structureJagannadha Sutradharudu Teki
Added proper comment style on spi_flash structure to make more readable. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-10-07sf: probe: Add support for flag status pollingJagannadha Sutradharudu Teki
From Micron, 512MB onwards, flash requires to poll flag status instead of read status- hence added E_FSR flag on spectific flash parts. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-10-07sf: probe: Add support for erase sector selection flagJagannadha Sutradharudu Teki
SECT_4K, SECT_32K and SECT_64K opeartions are performed to to specific flash by adding a SECT* flag on respective spi_flash_params.flag param. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-10-07sf: probe: Add support for SST_WPJagannadha Sutradharudu Teki
Most of the SST flashes needs to write up using SST_WP, AAI Word Program, so added a flag param on spi_flash_params table. SST flashes, which supports SST_WP need to use a WP write sst_write_wp instead of common flash write. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-23sf: Add flag status register polling supportJagannadha Sutradharudu Teki
Flag status register polling is required for micron 512Mb flash devices onwards, for performing erase/program operations. Like polling for WIP(Write-In-Progress) bit in read status register, spi_flash_cmd_wait_ready will poll for PEC(Program-Erase-Control) bit in flag status register. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-23sf: Add bank addr code in CONFIG_SPI_FLASH_BARJagannadha Sutradharudu Teki
Defined bank addr code on CONFIG_SPI_FLASH_BAR macro, to reduce the size for existing boards which has < 16Mbytes SPI flashes. It's upto user which has provision to use the bank addr code for flashes which has > 16Mbytes. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-23sf: Read flash bank addr register at probe timeJagannadha Sutradharudu Teki
Read the flash bank addr register to get the state of bank in a perticular flash. and also bank write happens only when there is a change in bank selection from user. bank read only valid for flashes which has > 16Mbytes those are opearted in 3-byte addr mode, each bank occupies 16Mytes. Suppose if the flash has 64Mbytes size consists of 4 banks like bank0, bank1, bank2 and bank3. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-23sf: Discover the bank addr commandsJagannadha Sutradharudu Teki
Bank/Extended addr commands are specific to particular flash vendor so discover them based on the idocode0. Assign the discovered bank commands to spi_flash members so-that the bank read/write will use their specific operations. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-03-19sf: Enable FDT-based configuration and memory mappingSimon Glass
Enable device tree control of SPI flash, and use this to implement memory-mapped SPI flash, which is supported on Intel chips. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-19sf: Add spi_flash_alloc() to create a new SPI flash structSimon Glass
At present it is difficult to extend the SPI flash structure since all devices allocate it themselves, and few of them zero all fields. Add a new function spi_flash_alloc() which can be used by SPI devices to perform this allocation, and thus ensure that all devices can better cope with SPI structure changes. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-24sf: Add spi_boot() to allow booting from SPI flash in an SPLChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Scott Wood <scottwood@freescale.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26sf: unify write funcsMike Frysinger
Once we add a new page_size field for write lengths, we can unify the write methods for most of the spi flash drivers. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-12sf: add struct spi_flash.sector_size parameterRichard Retanubun
This patch adds a new member to struct spi_flash (u16 sector_size) and updates the spi flash drivers to start populating it. This parameter can be used by spi flash commands that need to round up units of operation to the flash's sector_size. Having this number in one place also allows duplicated code to be further collapsed into one common location (such as erase parameter and the detected message). Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-11sf: punt unused spi_flash_region structMike Frysinger
2009-11-24spi_flash.h: pull in linux/types.h for u## typesMike Frysinger
2008-06-03SPI Flash subsystemHaavard Skinnemoen
This adds a new SPI flash subsystem. Currently, only AT45 DataFlash in non-power-of-two mode is supported, but some preliminary support for other flash types is in place as well. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
