path: root/include
2002-11-10* Vince Husovsky, 7 Nov 2002:LABEL_2002_11_10_2310wdenk
Add "-n" to linker options to get rid of "Not enough room for program headers" problem * Patch by David Müller, 05 Nov 2002 Rename CONFIG_PLL_INPUT_FREQ to CONFIG_SYS_CLK_FREQ so we can use an already existing name * Patch by Pierre Aubert, 05 Nov 2002 Hardware related improvements in FDC boot code * Patch by Holger Schurig, 5 Nov 2002: Make the PXA really change it's frequency * Patch by Pierre Aubert, 05 Nov 2002 Add support for slave serial Spartan 2 FPGAs * Fix uninitialized memory (MAC address) in 8xx SCC/FEC ethernet drivers
2002-11-05Quick & Dirty fix for log buffer problem when environment is not setwdenk
Trigger watchdog when reading the env - this might take a while. Set debugging baud rate for KUP4K board
2002-11-05* Add support for log buffer which can be passed to Linux kernel'sLABEL_2002_11_05_1735wdenk
syslog mechanism; used especially for POST results. * Patch by Klaus Heydeck, 31 Oct 2002: Add initial support for kup4k board
2002-11-05* Patch by Robert Schwebel, 04 Nov 2002:LABEL_2002_11_05_0120wdenk
- use watchdog to reset PXA250 systems - added progress callbacks to (some of the) ARM code - update for Cogent CSB226 board * Add support for FPS860 board
2002-11-04Patch by Guillaume Alexandre,, 04 Nov 2002:wdenk
Improve PCI access on 32-bits Compact PCI bus Adjust VFD initialization on TRAB Cleanup RRvision video code
2002-11-03* Fix mdelay() on TRAB - this was still the debugging version withwdenk
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings and README.
2002-10-31Initial revisionwdenk
2002-10-26Initial revisionwdenk
2002-10-25Initial revisionwdenk
2002-10-24Initial revisionwdenk
2002-10-21Initial revisionwdenk
2002-10-19Initial revisionwdenk
2002-10-17Initial revisionwdenk
2002-10-11Initial revisionwdenk
2002-10-07Initial revisionwdenk
2002-10-02Initial revisionwdenk
2002-09-30Initial revisionwdenk
2002-09-28Initial revisionwdenk
2002-09-27Initial revisionwdenk
2002-09-26Initial revisionwdenk
2002-09-20Initial revisionwdenk
2002-09-18Initial revisionwdenk
2002-09-17Initial revisionwdenk
2002-09-15Initial revisionwdenk
2002-09-12Initial revisionwdenk
2002-09-10Initial revisionwdenk
2002-09-07Initial revisionwdenk
2002-08-27Initial revisionwdenk
