path: root/mips_config.mk
2008-06-05[MIPS] mips_config.mk: Misc fixesShinya Kuribayashi
- Kill redundant `-pipe' (this will be added by $(TOPDIR)/config.mk) - Modify comments Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-10-21[MIPS] Add PIC-related switches to PLATFORM_{CPP,LD}FLAGS and cleanupShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
