This fixes the following warning:
/net/bluetooth/hidp/core.c:271:12: warning: ‘hidp_get_raw_report’ defined but not used [-Wunused-function]
static int hidp_get_raw_report(struct hid_device *hid,
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
/drivers/net/ethernet/atheros/atl1e/atl1e_main.c:328:13: warning: ‘atl1e_rx_mode’ defined but not used [-Wunused-function]
static void atl1e_rx_mode(struct net_device *netdev,
/drivers/net/wireless/mwifiex/sta_cmd.c: In function ‘mwifiex_cmd_cfg_data’:
/drivers/net/wireless/mwifiex/sta_cmd.c:1196:6: warning: unused variable ‘ret’ [-Wunused-variable]
int ret;
/drivers/net/wireless/mwifiex/sdio.c:124:12: warning: ‘mwifiex_sdio_resume’ defined but not used [-Wunused-function]
static int mwifiex_sdio_resume(struct device *dev)
/drivers/net/wireless/at76c50x-usb.c: In function ‘at76_mod_init’:
/drivers/net/wireless/at76c50x-usb.c:2472:2: warning: passing argument 2 of ‘led_trigger_register_simple’ from incompatible pointer type [enabled by default]
led_trigger_register_simple("at76_usb-tx", &ledtrig_tx);
In file included from /backport-include/linux/leds.h:3:0,
from /drivers/net/wireless/at76c50x-usb.c:45:
include/linux/leds.h:97:13: note: expected ‘struct led_trigger **’ but argument is of type ‘struct backport_led_trigger **’
extern void led_trigger_register_simple(const char *name,
/drivers/net/wireless/at76c50x-usb.c: In function ‘at76_mod_exit’:
/drivers/net/wireless/at76c50x-usb.c:2484:2: warning: passing argument 1 of ‘led_trigger_unregister_simple’ from incompatible pointer type [enabled by default]
led_trigger_unregister_simple(ledtrig_tx);
include/linux/leds.h:99:13: note: expected ‘struct led_trigger *’ but argument is of type ‘struct backport_led_trigger *’
extern void led_trigger_unregister_simple(struct led_trigger *trigger);
RedHat 6.5 already contains ether_addr_equal_64bits() which will
conflict with our declaration.
This is needed by bcma.
alx_get_stats64() was added recently to alx driver, but on kernel <
2.6.30 only get_stats is available, convert the function on such
kernels to use the old api.
On kernel versions < 2.6.36 phy_mii_ioctl() gets struct mii_ioctl_data
as second parameter and on more recent kernel versions it takes struct
ifreq. This patch converts one version to the other.
ssb uses this header file, but does not use any of the functions in
there in the default config, because that is only used when
SSB_DRIVER_GPIO and SSB_EMBEDDED are activated.
net/bluetooth/hci_sysfs.c uses ATTRIBUTE_GROUPS on all kernel versions.
Now it has to be for older kernel versions as well and
__ATTRIBUTE_GROUPS is also needed for these old versions.
This copies the sdio device id list into backprots, this is used by
brcmfmac.
drivers/bcma/driver_gpio.c calls irq_set_chip_and_handler() when
BCMA_HOST_SOC is activated. irq_set_chip_and_handler() gets exported on
kernel >= 3.7, we should not activate this on any older kernel.
This patch reverts the changes done in the following commit for older
kernel versions:
commit f663dd9aaf9ed124f25f0f8452edf238f087ad50
Author: Jason Wang <jasowang@redhat.com>
Date: Fri Jan 10 16:18:26 2014 +0800
net: core: explicitly select a txq before doing l2 forwarding
CC: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.77 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.27 [ OK ]
27 3.11.10 [ OK ]
28 3.12.8 [ OK ]
29 3.13-rc8 [ OK ]
The act8865 regulator driver needs this header file.
This driver uses some members of struct regulator_desc which were added
in kernel 3.12.
ether_addr_equal_unaligned() is used by some drivers.
This is used by some drivers now
Modifications upstream affected:
* drivers_net_wireless_iwlwifi_pcie_internal.patch
* drivers_net_wireless_iwlwifi_pcie_trans.patch
Manually refresh the patches.
Change-Id: Iad8218a243e644352c3b1029d12795c528259dde
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
kernel.org does not support bzip2 any more, use gzip instead.
A user reported that the linux/mm.h header was missing on his mips
device with kernel 2.6.26.
led_blink_set is also exported by the RedHat 6.5 kernel and collides
with backports when loading the compat.ko module. This fixes the
problem by prefixing the symbol.
manual changes done to:
patches/collateral-evolutions/network/25-multicast-list_head/include_net_mac80211.patch
patches/collateral-evolutions/network/25-multicast-list_head/net_mac80211_driver-ops.patch
patches/collateral-evolutions/network/25-multicast-list_head/net_mac80211_iface.patch
patches/collateral-evolutions/network/64-b44-32bit-stats/drivers_net_ethernet_broadcom_b44.patch
patches/collateral-evolutions/network/70-umode_t-api-change/drivers_net_wireless_ath_ath9k_debug.patch
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.77 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.27 [ OK ]
27 3.11.10 [ OK ]
28 3.12.8 [ OK ]
29 3.13-rc8 [ OK ]
Update to current versions.
The class parameter was added in kernel 3.7 to i2c_add_mux_adapter()
and could just be ignored by older kernel versions.
This header file is now needed by a media driver.
When these drivers are build with older kernel versions we get build
errors.
This adds the backport for some printk_ratelimited() functions.
This is not used by any driver any more. brcmsmac was the only driver
selecting this, but did not used it since some months, now it does not
even select it any more.
Backport multicast list handling for kernel < 2.6.35 in iwlwifi mvm
driver.
The bluetooth 6lowpan code now accesses the addr_assign_type member of
struct netdev, which is not available in older kernel versions.
This file was added in kernel 2.6.32 and is now needed by bluetooth.
struct property is missing in the general header files in older kernel
versions. There are different versions of this header depending on the
architecture code in use. This removed the access to any members of
struct property for older kernel version when CONFIG_OF is not set.
The mdio bus functions where introduced in that version.
The flags argument was removed from phy_connect in this commit:
commit f9a8f83b04e0c362a2fc660dbad980d24af209fc
Author: Florian Fainelli <florian@openwrt.org>
Date: Mon Jan 14 00:52:52 2013 +0000
net: phy: remove flags argument from phy_{attach, connect, connect_direct}
v4l2 now supports tracing and needs a new header file that was missing.
This adds ARPHRD_6LOWPAN to if_arp.h
netif_notify_peers() was renamed to netdev_notify_peers() in kernel
3.7. Replace the calls to netdev_notify_peers() with
netif_notify_peers().
Some older kernel versions do not even have netif_notify_peers(), there
we just remove the call, currently it is only used in the 6lowpan code
and I assume it will still work, but not so good.
devm_kmalloc() was added in kernel 3.13. To backport it we replace the
calls with devm_kzalloc() instead.
Since spatch is rather slow, but can handle multiple spatches
concatenated in a single file, just do that and run it only
once rather than for each spatch. That shaves off some of the
runtime (startup etc. and finding affected files.)
On my system, I go from
real 9m42.616s
user 8m48.352s
sys 0m22.884s
to
real 9m1.948s
user 8m40.108s
sys 0m12.088s
This changed from not having a return value to having one,
so backport the version that has it.
After a few changes were made we need a refresh of patches
against next-20131206, this refreshes the patches and test
compiles against all supported kernels again.
$ time ckmake --allyesconfig
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.52 [ OK ]
19 3.3.8 [ OK ]
20 3.4.70 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.20 [ OK ]
27 3.11.9 [ OK ]
28 3.12.1 [ OK ]
29 3.13-rc1 [ OK ]
real 33m3.982s
user 892m21.988s
sys 128m11.492s
Current run time *without* the last two cocci patches applied:
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py \
--verbose \
--clean \
--refresh \
/home/mcgrof/linux-next/ \
/home/mcgrof/build/next-20131206
real 3m13.530s
user 2m56.104s
sys 0m16.180s
With the last two cocci patch files applied and spatch version 1.0.0-rc17:
--verbose \
--clean \
--refresh \
real 23m2.521s
user 19m19.436s
sys 3m3.840s
With the last two cocci patch files applied and spatch version 1.0.0-rc19:
--verbose \
--clean \
--refresh \
real 8m6.077s
user 7m46.076s
sys 0m18.124s
Moving forward please make sure to have present at least spatch
1.0.0-rc19 on your system to generate releases. The gains of extending
how we do backports more automatically with Coccinelle for the
short cost observed on 1.0.0-rc19 makes it worth it to continue to
embrace SmPL to backport further collateral evolutions.
Cc: Peter Senna <peter.senna@gmail.com>
Cc: Julia Lawall <julia.lawall@lip6.fr>
Cc: Gilles Muller <Gilles.Muller@lip6.fr>
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
The collateral evolution on pci power management ops can easily
be expressed with SmPL, use that instead.
spatch version 1.0.0-rc19 with Python support and with PCRE support
--verbose \
--clean \
--refresh \
real 8m6.077s
user 7m46.076s
sys 0m18.124s
There are three exceptions that this patch does not address:
libertas: this should be made a separate collateral evolution
specifically for spi drivers
iwlegacy: we'll deal with this as an evolution to our spatch,
it deals with having to rely on grammar rules which
go beyond just one file.
mwifiex: coccinelle is not doing the transormation due to
an isomorphism on how pm suspend ops are declared,
although we may be able to deal with this within
Coccinelle to teach it this isomorphism we can
also address this by streamlining how pm ops are
defined upstream in the meantime.
This is easily expressed instead as an SmPL patch for
interpretation with Coccinelle. This replaces 336 lines
patch code with 9 lines of SmPL.
This replaces the old shell scripts:
* get-compat-kernels
* get-compat-trees
with a shiny central Python based backpor update manager:
* backports-update-manager
The new version provides a few features which were
simply a difficult to implement and quite frankly
pointless to try to implement in shell. Things worth
mentioning:
* This will now monitor your old directories
and packages and remove any stale old directory
or packages. You should feel comfortable with
now just getting the latest code from the repo
and always just running the script, it will do
everything you wished it did for you.
* This will always check the URLs and ensure your
file size matches the target upstream size, we
used to only check if you had the file or not
* The compat-ksrc directory was renamed to
ksrc-backports which goes inline with our
rebranding crusade. The tool is smart enough
to figure out if you had the old name and
rename it for you. Its also smart enough to
figure out if you had your old compat-ksrc
as a symlink and preserve things just as you
intended following the old real path.
* The debs/ directory is now moved into
ksrc-backports, making it easier to manage
and detect what is or not part of backports.
* I found no way to deal with objects to extract
GNU archive items with Python, so we're stuck with
requiring GNU ar, this provides a simple wrapper
for our usage.
* For the tree updater we instead or relying on
Linus' tree to be a remote we leave it separately
but always use --reference and allow users to provide
their own --reference override for new clones.
It should be easy to extend this should others have
other custom work spaces through a config file or
the like.
* To keep backports up to date on a system after
an initial run one should only need to run through
a cronjob:
backports-update-manager --force
To only update the git trees:
backports-update-manager --force --git-trees-only
Relying on an continued update list is dumb though,
in the future we should look into putting out new
builds through without requiring GNU ar and also
updating the list through a json file just as the
kernel has its own now:
https://www.kernel.org/releases.json
SLES 11 SP3 does not have dev_hw_addr_random() so this patch includes
the stuff which would be done in dev_hw_addr_random() in
eth_hw_addr_random().
SLES 11 SP3 backported skb_add_rx_frag() with 6 arguments and we have
to use that function with the truesize parameter. This removes the
define for SLES 11 SP3 like it is done for RHEL.
This fixes lots of compile problems on RHEL 6.5.
