2014-11-14backports: prefix c-file / h-file auto backport with BPAUTOLuis R. Rodriguez
Things we backport are now prefixed with BACKPORT_, when we copy over libraries with the c-files / h-files trick on the compat/Kconfig trick we prefix these with BACKPORT_ already so in order to help distinguish them use BACKPORT_BPAUTO_ for them and prevent a double BACKPORT_ prefix. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: add backport version parsing for kernel integrationLuis R. Rodriguez
The way we'll define backports versioning information for kernel integration is slightly different, we'll rely completely on Kconfig for the job, but in the end share the same C code defines. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: define C code backport version info using CPTCFG_Luis R. Rodriguez
In order to help unify the naming scheme for shared backports versioning information rely on the CPTCFG_ prefix, when integration support gets added that will translate to the respective CONFIG_BACKPORT_ prefix. Kconfig opt env entries don't get propagated out, so we need to define these ourselves. This leaves all other names in place for packaging and just focuses on sharing on the C / header code. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: move version file generation to run earlierLuis R. Rodriguez
The version file contains: * BACKPORTS_VERSION * BACKPORTED_KERNEL_VERSION * BACKPORTED_KERNEL_NAME This file is used by the Makefile to export variable definitions used to identify the backport. For kernel integration we'll be using a generated Kconfig file instead and since these are needed when processing kconfig logic this will need to be defined earlier. Just move the generation of the version file for packaging up early to match where we will generate the Kconfig with the backports versioning identification. This change has no real functional change other than the move of some code running earlier. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: split Kconfig into Kconfig.package and Kconfig.sourcesLuis R. Rodriguez
This splits up the Kconfig from things which are needed due to our copy of code from the kernel and things which we need specifically only for packaging backports. We will later then share the Kconfig.souce for instance for kernel integration. While at it, split up the list of files that we need to copy into what we know could be shared for integration. The the case of backport packaging Kconfig.package will be copied to the package's Kconfig when building the package with gentree.py. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: update dependencies map fileLuis R. Rodriguez
During development of kernel integration support using CONFIG_BACKPORT was evaluated as a prefix over CPTCFG even for packaging backports, for some reason this change lifted some restrictions one some device drivers which was present before and as such requires some changes to the dependencies map file to ensure correct compilation for respective kernel versions. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: use BACKPORT_DIR prefix on kconfig sourcesLuis R. Rodriguez
This will allow us to do less work for built-in integration support. When packaging we only use BACKPORT_DIR for Kconfig sources we control, to avoid a large change we avoid doing this for other Kconfig files. For integration we'll always have to use BACKPORT_DIR on kconfig sources. Suporting requires a bit of self evaluation of the variable within our kconfig library, ideally we'd have support for groking all variables defined within the Kconfig setup but that requires quite a lot more work as it means also parsing Makefiles and inheriting these definitions within config symbols when used. Since we only define one right now and its used for built-in support we deal with it ourselves for now. Please consider the complexity of adding others, it doesn't seem like there would be much need for others though. If others wanted to use a different BACKPORT_DIR path other than 'backports' that would require tweaking here, but we'll start by assuming no one will want to do that. $ time /home/mcgrof/backports/devel/ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.104 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.58 [ OK ] 12 3.11.10 [ OK ] 13 3.12.31 [ OK ] 14 3.13.11 [ OK ] 15 3.14.22 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.1 [ OK ] 19 3.18-rc1 [ OK ] real 42m41.825s user 1187m38.880s sys 141m11.760s Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: make kconfig src_line backport / ConfigTree specificLuis R. Rodriguez
The kconfig source line used on a backport project is very project specific. For backport packaging the source line simply should follow the full path of the project but for integration this will vary depending on the backport prefix directory used. We'll add support for that next. $ time /home/mcgrof/backports/devel/ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.104 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.58 [ OK ] 12 3.11.10 [ OK ] 13 3.12.31 [ OK ] 14 3.13.11 [ OK ] 15 3.14.22 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.1 [ OK ] 19 3.18-rc1 [ OK ] real 43m56.439s user 1187m4.516s sys 138m53.328s Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: modify kconfig parser to use bpid and target_dirLuis R. Rodriguez
The kconfig parser sets a base directory using the directory in which the Kconfig file passed lives in. This strategy assumes the kernel uses relative paths, while this is truly supported in practice though upstream only deals with full paths based on the actual root directory of the kernel. Its safer, cleaner and much simpler to support full paths, and since the kernel uses full paths anyway lets stick to that and complain when relative paths are found. This also modifies our own provided Kconfig to use full paths as well, we'll need this later to adjust our Kconfigs for kernel integration. $ time /home/mcgrof/backports/devel/ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.104 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.58 [ OK ] 12 3.11.10 [ OK ] 13 3.12.31 [ OK ] 14 3.13.11 [ OK ] 15 3.14.22 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.1 [ OK ] 19 3.18-rc1 [ OK ] real 44m3.002s user 1188m20.708s sys 140m25.540s Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: avoid git tree reinitializationLuis R. Rodriguez
When using backports against for packaging with --gitdebug you either have to use --clean or assume the directory is empty already. In either case you start fresh. With integration this will be a bit different, you could end up with a project directory where the git tree was present but only the target directory was empty. Calling git init on an already existing git directory will reinitialize your git tree, that can reset some config stuff, let's avoid that. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: fold outdir as a backport identity targetLuis R. Rodriguez
The output directory is always the same as the project directory for packaging backports but for integration these will differ, to make introduction of integration easier to follow use the outdir as both project directory and target directory and fold the existing args.outdir under the backport identity object as both "project_dir" and "target_dir". This commit has no functional changes. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: replace BACKPORT_PWD with BACKPORT_DIRLuis R. Rodriguez
This will also be used for built-in kernel integration, by using this we can share more code with the built-in kernel approach. Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: add prefix for integration on dependenciesLuis R. Rodriguez
When integrating we need the BACKPORT prefix added to dependency symbols. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: allow for different backport prefix and simple integration supportLuis R. Rodriguez
The way we backport when packaging is to minimize the amount of changes required by taking advantage of the fact that Kconfig can treat CONFIG_ as an environment variable with getenv() when parsing menu entries. When doing integration we don't want to do this so instead we'll rely on the CONFIG_BACKPORT prefix. This requires a bit of work on our current parsers, so to do that identify the backport and provide that to helpers. This also provides initial basic support for integration where no additional code was required other than prefixes or ensuring certain things are not done for integration. Before we expose integration support we'll need to add quite a bit more things so this just assumes integration is never desired. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: keep track of original backported source symbols early onLuis R. Rodriguez
We'll later want to do some modifications of symbols we backport when integrating, but before we do any modification on kconfig files we should keep track of the original source symbols. This commit introduces no functional changes right now, it will become more useful after we start adjusting kconfig entries for integration. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: grant parsers access to kconfig config and menuconfigLuis R. Rodriguez
Allow parsers to query the type of option used, either config or menuconfig. This will be used later. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: move packaging kconfig hacks to its own fileLuis R. Rodriguez
Move packaging kconfig hacks to its own file, we'll be ignoring this file later for postprocessing. Keeping this in a separate file will make parsing much simpler. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: ifdef around module_init() module_exit() for modulesLuis R. Rodriguez
We only need this for modules. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: move legacy and SmPL patch application into helperLuis R. Rodriguez
This allows us to extend how backports uses patches for different types of applications. This will later be used for kernel integration support, for example. This should have no functional change. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-10-25backports: refresh patches on next-20141023backports-20141023Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.104 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.58 [ OK ] 12 3.11.10 [ OK ] 13 3.12.31 [ OK ] 14 3.13.11 [ OK ] 15 3.14.22 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.1 [ OK ] 19 3.18-rc1 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-25devel: update the test kernelsHauke Mehrtens
2014-10-25backports: add device coredump frameworkJohannes Berg
As drivers will start requiring the new framework and it has been merged to linux/master during the 3.18 merge window, we can include it into backports to compile if needed. On kernels that do already have it but didn't want it built honor that, but if building otherwise don't. This may need to be revisited in the future. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-25backports: add kobj_to_dev()Johannes Berg
This will be needed by the devcoredump backport. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-25defconfig: add some new wifi driversbackports-20141003Hauke Mehrtens
2014-10-25defconfig: update media defconfigHauke Mehrtens
2014-10-25backports: refresh patches on next-20141003Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.103 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.54 [ OK ] 12 3.11.10 [ OK ] 13 3.12.27 [ OK ] 14 3.13.11 [ OK ] 15 3.14.18 [ OK ] 16 3.15.10 [ OK ] 17 3.16.2 [ OK ] 18 3.17-rc3 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-25dependencies: deactivate IR_HIX5HD2 on < 3.7Hauke Mehrtens
IR_HIX5HD2 needs syscon, this has to be added to the Kconfig file and on kernel < 3.7 it is completely missing. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-25dependencies: deactivate SOC_CAMERA on < 3.5Hauke Mehrtens
Deactivate SOC_CAMERA because of missing backport for vb2_expbuf() in kernel < 3.5. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-25dependencies: deactivate pt3 on kernel < 3.3Hauke Mehrtens
pt3 needs kthread_freezable_should_stop() which is not available on these old kernels. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-25dependencies: deactivate some media drivers on < 3.4Hauke Mehrtens
Deactivate all drivers using regmap_bulk_write() on kernel < 3.4. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-25dependencies: deactivate tracing in ath10k and ath with < 3.4Hauke Mehrtens
On kernel < 3.4 compiling ath10k with tracing results in huge compile errors. Just deactivate it till someone fixes the problems. The same compile error occurs in ath module with kernel 3.0. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-25backports: add freezable_schedule_hrtimeout_range()Hauke Mehrtens
This is used by the pt3 driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-25backports: add some missing header filesHauke Mehrtens
The hackrf driver needs PAGE_ALIGN() from mm.h. The ir-hix5hd2 driver needs of_get_property() from of.h. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-25backports: add wil6210_uapi.hHauke Mehrtens
This file is needed by the wil6210 driver now. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-20backports: refresh on next-20140919backports-20140919Hauke Mehrtens
2014-10-20backports: these drivers need a new functionHauke Mehrtens
These drivers need regmap_bulk_write(), which was added in 3.4 Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-20backports: add skb_clone_sk()Hauke Mehrtens
skb_clone_sk() is now used by mac80211 and this change also needs some changes to skb_complete_wifi_ack(), so I replaced it with our own version. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-20backports: add eth_get_headlen()Hauke Mehrtens
Instead of using the code from a recent kernel, I used the old code from the igb driver to calculate the header length. The new code in the kernel makes use of some __skb_flow_dissect() functions and headers not available in 3.0. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-20backports: add S8_MINHauke Mehrtens
This is needed by the iwlwifi river. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-10-20defconfigs: enable PCIe support in brcmfmac defconfigArend van Spriel
In 3.17 kernel the brcmfmac supports PCIe host interface. So enable support when selecting defconfig-brcmfmac. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-09-23backports: fix mconf compilation library assumptionsLuis R. Rodriguez
On OpenSUSE factory 'make menuconfig' fails to compile with: cc -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -DCURSES_LOC="<ncurses.h>" -DLOCALE -c -o lxdialog/yesno.o lxdialog/yesno.c cc -Wl,--no-as-needed -lncursesw mconf.o zconf.tab.o lxdialog/checklist.o lxdialog/inputbox.o lxdialog/menubox.o lxdialog/textbox.o lxdialog/util.o lxdialog/yesno.o -o mconf /usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld: /lib64/libncursesw.so.5: undefined reference to symbol 'acs_map' /usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../lib64/libtinfo.so: error adding symbols: DSO missing from command line collect2: error: ld returned 1 exit status Although this can be fixed by linking with -ltinfo after a bit further investigation I've traced this issue down to how we speak to the linker and ask it to link and when. For instance if one were to compile and link mconf by specifying the linker requirements before the final object file things fail and if we ask for it after things work. For instance if we ask for the libraries before: gcc -lncursesw -o kconf/mconf kconf/mconf.o kconf/zconf.tab.o kconf/lxdialog/checklist.o kconf/lxdialog/util.o kconf/lxdialog/inputbox.o kconf/lxdialog/textbox.o kconf/lxdialog/yesno.o kconf/lxdialog/menubox.o -lncursesw Passing the linker requirements at the end makes the gcc happy: gcc -o kconf/mconf kconf/mconf.o kconf/zconf.tab.o kconf/lxdialog/checklist.o kconf/lxdialog/util.o kconf/lxdialog/inputbox.o kconf/lxdialog/textbox.o kconf/lxdialog/yesno.o kconf/lxdialog/menubox.o -lncursesw It seems that using -Wl,--no-as-needed does not do what we wish with regards to the above requirements, this could be a bug but the kernel treats things a bit differently so we need to adopt, fix this by being explicit by using -Wl,--add-needed and letting it figure things out automagically. This has been tested on Debian and OpenSUSE factory. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-09-07backports: refresh patches on next-20140905backports-20140905Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.103 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.54 [ OK ] 12 3.11.10 [ OK ] 13 3.12.27 [ OK ] 14 3.13.11 [ OK ] 15 3.14.18 [ OK ] 16 3.15.10 [ OK ] 17 3.16.2 [ OK ] 18 3.17-rc3 [ OK ] manual changes were done in: patches/collateral-evolutions/network/0006-ieee802154-6lowpan-namespace.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-09-07backports: remove usage of skbuff->xmit_moreHauke Mehrtens
This is a revet of these two upstream commits: commit c1ebf46c1f72fe542853fc00f059a7d15259379d Author: David S. Miller <davem@davemloft.net> Date: Fri Aug 22 17:24:49 2014 -0700 igb: Support netdev_ops->ndo_xmit_flush() commit 0b725a2ca61bedc33a2a63d0451d528b268cf975 Author: David S. Miller <davem@davemloft.net> Date: Mon Aug 25 15:51:53 2014 -0700 net: Remove ndo_xmit_flush netdev operation, use signalling instead. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-09-07backports: bluetooth revert patch adding write_iterHauke Mehrtens
This reverts this upstream patch for older kernel versions: commit 9f87eaae842575ec7de51654127a9bf4ad07ad6d Author: Al Viro <viro@zeniv.linux.org.uk> Date: Sat Aug 23 11:28:14 2014 -0400 switch hci_vhci to ->write_iter() Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-09-07backports: adapt api change of rchan_callbacks->create_buf_file in ath10kHauke Mehrtens
2014-09-06backports: always use absolute path to output directory, less probability of ↵backports-20140822Jacob Siverskog
pycocci failure. While running gentree.py I got error messages such as 'Failed to process SmPL patch collateral-evolutions/generic/0001-group-attr/0001-group_attr_class.cocci', due to incorrect path handling. This patch always makes gentree always call pycocci with the absolute path to the output directory. Signed-off-by: Jacob Siverskog <jacob@teenageengineering.com>
2014-09-06backports: refresh patches on next-20140822Hauke Mehrtens
2014-09-06backports: remove regulator driversHauke Mehrtens
It looks like no one is using the regulator drivers and maintaining them costs some time because they often break. When someone needs a specific driver please send a patch adding this one specific driver, maintaining a small subset is not a problem, but maintaining all is a big task. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-09-06backports: update test kernel versionsHauke Mehrtens
2014-09-06backports: fix build with Ubuntu mainline kernelsHauke Mehrtens
We only want the UTS_UBUNTU_RELEASE_ABI var when we are on a normal Ubuntu distribution kernel and not when we are on a Ubuntu mainline kernel. Some of the Ubuntu mainline kernel do have an invalid octal number in this field like 031418 and we do not want to evaluate this at all on the Ubuntu mainline kernels. All Ubuntu distribution kernel have CONFIG_VERSION_SIGNATURE set so this way we can detect the which type of kernel we are on. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
