Upstream commit 0edf6b301cc8b29792188512195e34c6977292f1
[mcgrof: modified to remove subsystems not yet backported on v3.10]
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Upstream commit 75ff03ec2a9fbd48e4191ac82d6ffbf78e8f0a90
Throw users a bone by helping them compile specific target
drivers. Hauke did some good work in providing tons of
defconfigs, provide a command to let users query these
easily with 'make defconfig-help'. Also provide a more
generic 'make help' target.
Screenshot of make defconfig-help:
mcgrof@frijol ~/backports-20130618 $ make defconfig-help
Driver or subsystem configuration targets:
defconfig-alx
defconfig-ar5523
defconfig-ath5k
defconfig-ath6kl
defconfig-ath9k
defconfig-ath10k
defconfig-b43
defconfig-b43legacy
defconfig-brcmfmac
defconfig-brcmsmac
defconfig-carl9170
defconfig-drm
defconfig-ieee802154
defconfig-iwlwifi
defconfig-media
defconfig-nfc
defconfig-regulator
defconfig-rtlwifi
defconfig-wifi
defconfig-wil6210
Running 'make help' will provide the above and in addition to that
something similar to what the Linux kernel provides with the
list of supported targets backports provides.
Upstream commit 7574abeacdc2305461517fea566c2594ead6f3d1
== ckmake-report.log ==
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.85 [ OK ]
18 3.1.10 [ OK ]
19 3.10.0 [ OK ]
20 3.2.48 [ OK ]
21 3.3.8 [ OK ]
22 3.4.52 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.9 [ OK ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
i915 now uses swiotlb_nr_tbl(), but we can not backport it to kernel
version <= 3.2.
Upstream commit 8742a33b63428b13d21be4b79220813d2180752a
This was added via uapi/linux/ethtool.h but using
that file causes some odd issues I simply cannot
resolve right now. I stuff these definitions into
the regular include/linux/ethtool.h for now.
This backports commit 589665f5 added via v3.2.
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains \
589665f5a6008dbce1d0af2cb93e94a80bf78151
v3.2-rc1~4^2~10
Upstream commit afe18ac2454e8ba8c3a45a837da7c7fca65c5aae
This backports the new upstream alx driver and
properly splits up each required backports into
its respective collateral evolution bucket.
Upstream commit e3220f58fc08f986c3b84458d50eee2d3b983690
The alx driver was upstreamed by Johannes, so this is
no longer required. Note that this driver is now GPLv2
or later, BSD folks will have to look at the old unified
tree for a permissive licensed port.
Upstream commit 98be7feed42539492bc768ec287b204b186790c4
The original version also checked for bInterfaceNumber, which is only
available in more recent kernel versions.
Upstream commit 01d7e21c43c0255a0f107b18ce05b2350f561f84
NET_CORE was added with kernel 3.2 and before this patch no Ethernet
driver was build on older kernel versions.
Upstream commit 6f1b6d9b8a662eb3d79711e77879a381bb365036
The ATL1E driver needs netif_set_gso_max_size() and this is not
available in older kernel versions.
Upstream commit e256bb71deb06d1276f8774aa95e8501a7462080
The alx driver uses drivers/net/mdio.c which was added with kernel
2.6.31. Build the alx driver only on this kernel version or a more
recent one.
Upstream commit df89d22b5d0998a5689554c9875813e97eab23d9
This default config contains all wifi drivers.
Upstream commit 95c69b5d45e07b865c13fade1f1d61c6e55c5cfc
Upstream commit 88f8c8b255e4fec946f2a8ecd70f0d28ad82d16a
This adds default configs for Atheros wifi drivers.
Upstream commit d58be321df286371d50ed54e835efeea087a9fac
We ship it, so we should use it. This should fix issues
like one distro needing "-lncurses -ltinfo" and others
requiring just "-lncurses" and not having "tinfo".
Upstream commit a029928078ce7708c4cd54a6b9f1fc0212fc3395
Catch running make in the backport template directory by
checking for the .local-symbols file. If it isn't there
then we're in the input/template directory rather than in
an output tree, give the user a hint about it instead of
keeling over.
Upstream commit 1ea075ea8dd98a5cc21d3d79ff0204797bb78eb5
The bcma and ssb mips driver are depending on kernel 3.3.
Upstream commit 7ff43c90253ab78ade9696eb1f73964542710304
The MEI NFC driver needs include/linux/mei_cl_bus.h which was added
with kernel 3.10.
Upstream commit e753851dda4afd9efe5cdd88bc6bf306b550f506
Without wext support we will get lots of complains about iwconfig
not working.
Upstream commit cc0e72a0d558af1305ef03bbcf48f73ec574a7af
This adds a default config for the broadcom wifi drivers.
Upstream commit 3fc43d6f57044d0cf8003dc8bc30749931b6a727
The kernel 3.10 already includes the new versions.
Upstream commit 2bbf9dda81f21c08be51a1c61c0d2eb701c7af94
Upstream commit 8d10f3b2021e8644ee00cbc030290f45c4d176d9
Using openSUSE 12.3 with x86_64 architecture, the 'make menuconfig'
command results in the following:
finger@larrylap:~/backports-3.10-rc1-1> make menuconfig
cc -Wl,--no-as-needed -lncurses mconf.o zconf.tab.o lxdialog/checklist.o lxdialog/inputbox.o lxdialog/menubox.o lxdialog/textbox.o lxdialog/util.o lxdialog/yesno.o -o mconf
/usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: /lib64/libncurses.so.5: undefined reference to symbol 'acs_map'
/usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: note: 'acs_map' is defined in DSO /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../lib64/libtinfo.so so try adding it to the linker command line
/usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../lib64/libtinfo.so: could not read symbols: Invalid operation
collect2: error: ld returned 1 exit status
make[2]: *** [mconf] Error 1
make[1]: *** [menuconfig] Error 2
make: *** [menuconfig] Error 2
When "-ltinfo" is added to the LDFLAGS symbol as suggested by the linker,
it builds and runs correctly.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 17m9.368s
user 403m46.554s
sys 95m42.811s
[mcgrof: tested with ckmake]
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m50.520s
user 815m12.233s
sys 127m49.075s
Directory copying is recursive, so there's no need
to list subdirectories. All atheros ethernet drivers
are copied, so don't list them one by one. The same
is true for the Bluetooth include files.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m46.042s
user 816m2.488s
sys 126m33.079s
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m45.327s
user 814m25.678s
sys 128m22.341s
Samuel folded code under net/nfc/llcp/ onto
the parent net/nfc/ directory with llcp_ prefixes
for the files. Address this change introduced
as of next-20130430.
commit 30cc4587659e1c9b1bfade8b2a757d91e04758ab
Author: Samuel Ortiz <sameo@linux.intel.com>
Date: Fri Apr 26 11:49:40 2013 +0200
NFC: Move LLCP code to the NFC top level diirectory
And stop making it optional. LLCP is a fundamental part of the NFC
specifications and making it optional does not make much sense.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m48.875s
user 815m54.307s
sys 127m12.229s
The recent file shuffling on nouveau requires some
changes not upstream to get it to compile to ensure
some objects do get interpreted as requiring the
new search path.
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains 271a15ea
v3.10-rc1~129^2~24
commit 271a15eabe094538d958dc68ccfc9c36b699247a
Author: David Howells <dhowells@redhat.com>
Date: Fri Apr 12 00:38:51 2013 +0100
proc: Supply PDE attribute setting accessor functions
Supply accessor functions to set attributes in proc_dir_entry structs.
The following are supplied: proc_set_size() and proc_set_user().
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
cc: linuxppc-dev@lists.ozlabs.org
cc: linux-media@vger.kernel.org
cc: netdev@vger.kernel.org
cc: linux-wireless@vger.kernel.org
cc: linux-pci@vger.kernel.org
cc: netfilter-devel@vger.kernel.org
cc: alsa-devel@alsa-project.org
This was missing.
Intorduced in next-20130429 and Linus has merged it
onto v3.10-rc1. We cannot backport remove_proc_subtree()
modularly [0] so just go ahead and revert this change.
The alternative is to go and review each procfs usage
for each driver we have issues and see if it makes
sense to replace procs with debugfs upstream.
commit 8ce584c7416d8a85a6f3edc17d1cddefe331e87e
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Sat Mar 30 20:13:46 2013 -0400
procfs: add proc_remove_subtree()
just what it sounds like; do that only to procfs subtrees you've
created - doing that to something shared with another driver is
not only antisocial, but might cause interesting races with
proc_create() and its ilk.
[0] http://marc.info/?t=136841961600002&r=1&w=2
This doesn't make sense since we'd have no way of knowing
when such a patch should be applied. Right now the patch
would be ignored, but make it extra obvious and error out
on such patches.
The new backport rfkill approach caused a sparse warning:
linux/rfkill.h:70:43: warning: mixing different enum types
linux/rfkill.h:70:43: int enum rfkill_type versus
linux/rfkill.h:70:43: int enum old_rfkill_type
Fix it by adding a cast.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m52.106s
user 816m17.749s
sys 127m27.702s
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m48.012s
user 814m18.301s
sys 127m38.575s
This is required by some drivers as of next-20130424.
commit fcf371ee5624cc87abac205cd0dad2432d7f0346
Author: Axel Lin <axel.lin@ingics.com>
Date: Thu Apr 18 10:34:49 2013 +0800
regulator: core: Add regulator_map_voltage_ascend() API
A lot of regulator hardware has ascendant voltage list.
This patch adds regulator_map_voltage_ascend() and export it.
Drivers that have ascendant voltage list can use this as their map_voltage()
operation, this is more efficient than default regulator_map_voltage_iterate()
function.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m53.044s
user 815m38.362s
sys 127m50.187s
This addresses the last remaining components to
backport the ethernet vlan changes introduced by
9356b8fc d314774c and f646968f8f on next-20130423.
This backports 9356b8fc d314774c and f646968f8f
all added in next-20130423. Soome driver changes are
still required and will be addressed separately.
commit 9356b8fc07dc126cd91d2b12f314d760ab48996e
Author: Eric Dumazet <dada1@cosmosbay.com>
Date: Tue Sep 27 15:23:16 2005 -0700
[NET]: Reorder some hot fields of struct net_device
Place them on separate cache lines in SMP to lower memory bouncing
between multiple CPU accessing the device.
- One part is mostly used on receive path (including
eth_type_trans()) (poll_list, poll, quota, weight, last_rx,
dev_addr, broadcast)
- One part is mostly used on queue transmit path (qdisc)
(queue_lock, qdisc, qdisc_sleeping, qdisc_list, tx_queue_len)
- One part is mostly used on xmit path (device)
(xmit_lock, xmit_lock_owner, priv, hard_start_xmit, trans_start)
'features' is placed outside of these hot points, in a location that
may be shared by all cpus (because mostly read)
name_hlist is moved close to name[IFNAMSIZ] to speedup __dev_get_by_name()
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
commit d314774cf2cd5dfeb39a00d37deee65d4c627927
Author: Stephen Hemminger <shemminger@vyatta.com>
Date: Wed Nov 19 21:32:24 2008 -0800
netdev: network device operations infrastructure
This patch changes the network device internal API to move adminstrative
operations out of the network device structure and into a separate structure.
This patch involves some hackery to maintain compatablity between the
new and old model, so all 300+ drivers don't have to be changed at once.
For drivers that aren't converted yet, the netdevice_ops virt function list
still resides in the net_device structure. For old protocols, the new
net_device_ops are copied out to the old net_device pointers.
After the transistion is completed the nag message can be changed to
an WARN_ON, and the compatiablity code can be made configurable.
Some function pointers aren't moved:
* destructor can't be in net_device_ops because
it may need to be referenced after the module is unloaded.
* neighbor setup is manipulated in a couple of places that need special
consideration
* hard_start_xmit is in the fast path for transmit.
commit f646968f8f7c624587de729115d802372b9063dd
Author: Patrick McHardy <kaber@trash.net>
Date: Fri Apr 19 02:04:27 2013 +0000
net: vlan: rename NETIF_F_HW_VLAN_* feature flags to NETIF_F_HW_VLAN_CTAG_*
Rename the hardware VLAN acceleration features to include "CTAG" to indicate
that they only support CTAGs. Follow up patches will introduce 802.1ad
server provider tagging (STAGs) and require the distinction for hardware not
supporting acclerating both.
The new code for the "critical protocol indication" uses
snd_portid and must be adjusted in the backport patches.
This is required as of next-20130423.
commit 5de17984898c5758fc6ebe08eccea9f4b6548914
Author: Arend van Spriel <arend@broadcom.com>
Date: Thu Apr 18 15:49:00 2013 +0200
cfg80211: introduce critical protocol indication from user-space
Some protocols need a more reliable connection to complete
successful in reasonable time. This patch adds a user-space
API to indicate the wireless driver that a critical protocol
is about to commence and when it is done, using nl80211 primitives
NL80211_CMD_CRIT_PROTOCOL_START and NL80211_CRIT_PROTOCOL_STOP.
There can be only on critical protocol session started per
registered cfg80211 device.
The driver can support this by implementing the cfg80211 callbacks
.crit_proto_start() and .crit_proto_stop(). Examples of protocols
that can benefit from this are DHCP, EAPOL, APIPA. Exactly how the
link can/should be made more reliable is up to the driver. Things
to consider are avoid scanning, no multi-channel operations, and
alter coexistence schemes.
Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com>
Reviewed-by: Franky (Zhenhui) Lin <frankyl@broadcom.com>
Signed-off-by: Arend van Spriel <arend@broadcom.com>
[mcgrof@do-not-panic.com]: Required as of next-20130423
and provided commit log message that introduced this
change.
There's only a single user of vb2_mmap_pfn_range() and
at least on 3.2 having the function in compat-3.9.c is
problematic if CPTCFG_BACKPORT_BUILD_DMA_SHARED_BUFFER
isn't set, because on that kernel there's no dma-buf.h
and then compilation can fail.
There's not much point in backporting rfkill, if the base kernel
doesn't have it then providing the it as /dev/rfkill_backport
won't be picked up by any apps, and if the base kernel has it
then it would cause odd behaviour as the base kernel's platform
drivers using the rfkill API would not talk to the backported
modules rfkill.
An unusable backported rfkill isn't much better than not having
it at all, so change the way we backport rfkill and don't carry
the code but simply provide the API as wrappers.
If the base kernel is 3.10 or higher (the current version) then
don't change anything at all.
If the base kernel is 2.6.33 or higher (with the new rfkill API)
then just wrap the API and disable rfkill registrations for any
types that the base kernel doesn't know about.
For all other kernels, provide only static inlines that behave
like the rfkill API when rfkill isn't compiled in.
The downside is that we need to copy the rfkill API. This is,
however, very very stable (it essentially hasn't changed since
2.6.33), so that's not a problem.
Just as an alias for 'install'.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
This is a no-op for the modular use case of the
backports project but by enabling this it allows
for developers a way to embed the backports releases
onto a target source Linux directory, with obvious
pending modifications, by adding our backport_init()
onto the target kernel's init/main.c start_kernel().
Enable this theoretical use case. Hackers welcome to
go play on this theoretical integration strategy now.
Cc: pstew@chromium.org
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m44.234s
user 813m54.992s
sys 126m44.115s
Commit b4f34d8d9 on next-20130419 added new bluetooth hidp
session-management helper, then commit 520518 also on
next-20130419 replaced the old management code with
the new one. Thanks to David Herrmann for his review and
his changes for this backport.
commit b4f34d8d9d26b2428fa7cf7c8f97690a297978e6
Author: David Herrmann <dh.herrmann@gmail.com>
Date: Sat Apr 6 20:28:46 2013 +0200
Bluetooth: hidp: add new session-management helpers
This is a rewrite of the HIDP session management. It implements HIDP as an
l2cap_user sub-module so we get proper notification when the underlying
connection goes away.
The helpers are not yet used but only added in this commit. The old
session management is still used and will be removed in a following patch.
The old session-management was flawed. Hotplugging is horribly broken and
we have no way of getting notified when the underlying connection goes
down. The whole idea of removing the HID/input sub-devices from within the
session itself is broken and suffers from major dead-locks. We never can
guarantee that the session can unregister itself as long as we use
synchronous shutdowns. This can only work with asynchronous shutdowns.
However, in this case we _must_ be able to unregister the session from the
outside as otherwise the l2cap_conn object might be unlinked before we
are.
The new session-management is based on l2cap_user. There is only one
way how to add a session and how to delete a session: "probe" and "remove"
callbacks from l2cap_user.
This guarantees that the session can be registered and unregistered at
_any_ time without any synchronous shutdown.
On the other hand, much work has been put into proper session-refcounting.
We can unregister/unlink the session only if we can guarantee that it will
stay alive. But for asynchronous shutdowns we never know when the last
user goes away so we must use proper ref-counting.
The old ->conn field has been renamed to ->hconn so we can reuse ->conn in
the new session management. No other existing HIDP code is modified.
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit 5205185d461d5902325e457ca80bd421127b7308
Date: Sat Apr 6 20:28:47 2013 +0200
Bluetooth: hidp: remove old session-management
We have the full new session-management now available so lets switch over
and remove all the old code. Few semantics changed, so we need to adjust
the sock.c callers a bit. But this mostly simplifies the logic.
As of next-20130419 the atl1.c driver uses
atl1_pm_ops directly instead of the ATL1_PM_OPS
macro. This fixes that hunk.
