Upstream commit: 10eca9f5bef1821de09601a3a7db7eb337c56ba0
This streamlines our release process making it easier for
transitioning releases onto other backport developers.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Upstream commit: 57554a365682979473778ffca9a9c5c82ab4dee6
kup is written in perl, add some basic python interfaces
for it to allow us to upload to kernel.org backport
releases.
Upstream commit: dcd5524fc04730b0af05b28388d246cad97a91c2
Note that kup expects --armor --detach-sign, we'll pass that
as part of our extra_args. The python gpg lib doesn't provide
support for random arguments as this one, so just add our
own little helper and carry it over.
Upstream commit: f9fa9dac70b99a2cf12b494a9fe4440404a30c4e
This cleans sanitizes a source tree and ensures
no content is present from what was intended.
Upstream commit: 455aae0352d34e97fc5910927428c9f8ff44f77a
This verifies that the tree provided has its last commit
both tagged and also digitally signed. In short it does:
git tag -v $(git describe --dirty)
This will be used later.
Upstream commit: 52aca1afb093baef20140b33d50426ecf80d3f6d
We'll use this later.
Upstream commit: 276bf778df6e33f66391e4cea9cbceb888db6f9d
We use --porcelain given that this spits out the results
in an easy-to-parse format for scripts and will remain stable
across git versions and regardless of user configuration.
We will use this later.
Upstream commit: ea70308d746325654d44851be602fe02492b59f9
This lets us throw at it whatever extra stuff we want.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ FAIL ]
19 3.11.3 [ FAIL ]
20 3.12-rc3 [ FAIL ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Upstream commit: 09556c795e8afb6672893d41a05a6728c306e5f6
The Atheros atl1c driver now uses build_skb() which was added in 3.5.
Upstream commit: 1a996968fc51cc1323e1bedceb32143aa1226e9b
This is now in kernel 3.10+
Upstream commit: 551f46cb4472f03bea0df808ef892ea8eb49a2af
This fixes a build error one some non x86 systems.
Upstream commit: 168beb7a3dad933d29f8e0dabd37db8cf189a4c7
This should prevent some compile errors when backports is used with a
kernel without PCI support.
Upstream commit: 6bc60d332b7109c99cd5f5d5f8b7791f921289d6
The newly created function ends with _compat. This causes compile
warnings and probably runtime problems on kernel < 2.6.29.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.2.45 [ OK ]
20 3.3.8 [ OK ]
21 3.4.46 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.13 [ OK ]
26 3.9.3 [ OK ]
real 33m18.960s
user 900m1.540s
sys 125m0.580s
Upstream commit 1c44a3a37bc973641065d4c15741ac54ee986a6b
In terms of project naming the backports project has evolved
as follows:
compat-wireless --> compat-drivers --> backports
All along the design and intent behind the initial project
has been to provide a framework for delivery of *upstream*
drivers using a backported infrastructure. I've made it
clear that in no way shape or form did I ever want any
proprietary driver to make use of the framework. As the
project has grown I'm not alone with this sentiment so
lets document that and also fix a few symbols that have
slipped along the way.
[mcgrof: backport to linux-3.10.y branch]
Upstream commit 0edf6b301cc8b29792188512195e34c6977292f1
[mcgrof: modified to remove subsystems not yet backported on v3.10]
Upstream commit 75ff03ec2a9fbd48e4191ac82d6ffbf78e8f0a90
Throw users a bone by helping them compile specific target
drivers. Hauke did some good work in providing tons of
defconfigs, provide a command to let users query these
easily with 'make defconfig-help'. Also provide a more
generic 'make help' target.
Screenshot of make defconfig-help:
mcgrof@frijol ~/backports-20130618 $ make defconfig-help
Driver or subsystem configuration targets:
defconfig-alx
defconfig-ar5523
defconfig-ath5k
defconfig-ath6kl
defconfig-ath9k
defconfig-ath10k
defconfig-b43
defconfig-b43legacy
defconfig-brcmfmac
defconfig-brcmsmac
defconfig-carl9170
defconfig-drm
defconfig-ieee802154
defconfig-iwlwifi
defconfig-media
defconfig-nfc
defconfig-regulator
defconfig-rtlwifi
defconfig-wifi
defconfig-wil6210
Running 'make help' will provide the above and in addition to that
something similar to what the Linux kernel provides with the
list of supported targets backports provides.
Upstream commit 7574abeacdc2305461517fea566c2594ead6f3d1
== ckmake-report.log ==
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.85 [ OK ]
18 3.1.10 [ OK ]
19 3.10.0 [ OK ]
20 3.2.48 [ OK ]
21 3.3.8 [ OK ]
22 3.4.52 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.9 [ OK ]
i915 now uses swiotlb_nr_tbl(), but we can not backport it to kernel
version <= 3.2.
Upstream commit 8742a33b63428b13d21be4b79220813d2180752a
This was added via uapi/linux/ethtool.h but using
that file causes some odd issues I simply cannot
resolve right now. I stuff these definitions into
the regular include/linux/ethtool.h for now.
This backports commit 589665f5 added via v3.2.
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains \
589665f5a6008dbce1d0af2cb93e94a80bf78151
v3.2-rc1~4^2~10
Upstream commit afe18ac2454e8ba8c3a45a837da7c7fca65c5aae
This backports the new upstream alx driver and
properly splits up each required backports into
its respective collateral evolution bucket.
Upstream commit e3220f58fc08f986c3b84458d50eee2d3b983690
The alx driver was upstreamed by Johannes, so this is
no longer required. Note that this driver is now GPLv2
or later, BSD folks will have to look at the old unified
tree for a permissive licensed port.
Upstream commit 98be7feed42539492bc768ec287b204b186790c4
The original version also checked for bInterfaceNumber, which is only
available in more recent kernel versions.
Upstream commit 01d7e21c43c0255a0f107b18ce05b2350f561f84
NET_CORE was added with kernel 3.2 and before this patch no Ethernet
driver was build on older kernel versions.
Upstream commit 6f1b6d9b8a662eb3d79711e77879a381bb365036
The ATL1E driver needs netif_set_gso_max_size() and this is not
available in older kernel versions.
Upstream commit e256bb71deb06d1276f8774aa95e8501a7462080
The alx driver uses drivers/net/mdio.c which was added with kernel
2.6.31. Build the alx driver only on this kernel version or a more
recent one.
Upstream commit df89d22b5d0998a5689554c9875813e97eab23d9
This default config contains all wifi drivers.
Upstream commit 95c69b5d45e07b865c13fade1f1d61c6e55c5cfc
Upstream commit 88f8c8b255e4fec946f2a8ecd70f0d28ad82d16a
This adds default configs for Atheros wifi drivers.
Upstream commit d58be321df286371d50ed54e835efeea087a9fac
We ship it, so we should use it. This should fix issues
like one distro needing "-lncurses -ltinfo" and others
requiring just "-lncurses" and not having "tinfo".
Upstream commit a029928078ce7708c4cd54a6b9f1fc0212fc3395
Catch running make in the backport template directory by
checking for the .local-symbols file. If it isn't there
then we're in the input/template directory rather than in
an output tree, give the user a hint about it instead of
keeling over.
Upstream commit 1ea075ea8dd98a5cc21d3d79ff0204797bb78eb5
The bcma and ssb mips driver are depending on kernel 3.3.
Upstream commit 7ff43c90253ab78ade9696eb1f73964542710304
The MEI NFC driver needs include/linux/mei_cl_bus.h which was added
with kernel 3.10.
Upstream commit e753851dda4afd9efe5cdd88bc6bf306b550f506
Without wext support we will get lots of complains about iwconfig
not working.
Upstream commit cc0e72a0d558af1305ef03bbcf48f73ec574a7af
This adds a default config for the broadcom wifi drivers.
Upstream commit 3fc43d6f57044d0cf8003dc8bc30749931b6a727
The kernel 3.10 already includes the new versions.
Upstream commit 2bbf9dda81f21c08be51a1c61c0d2eb701c7af94
Upstream commit 8d10f3b2021e8644ee00cbc030290f45c4d176d9
Using openSUSE 12.3 with x86_64 architecture, the 'make menuconfig'
command results in the following:
finger@larrylap:~/backports-3.10-rc1-1> make menuconfig
cc -Wl,--no-as-needed -lncurses mconf.o zconf.tab.o lxdialog/checklist.o lxdialog/inputbox.o lxdialog/menubox.o lxdialog/textbox.o lxdialog/util.o lxdialog/yesno.o -o mconf
/usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: /lib64/libncurses.so.5: undefined reference to symbol 'acs_map'
/usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: note: 'acs_map' is defined in DSO /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../lib64/libtinfo.so so try adding it to the linker command line
/usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../lib64/libtinfo.so: could not read symbols: Invalid operation
collect2: error: ld returned 1 exit status
make[2]: *** [mconf] Error 1
make[1]: *** [menuconfig] Error 2
make: *** [menuconfig] Error 2
When "-ltinfo" is added to the LDFLAGS symbol as suggested by the linker,
it builds and runs correctly.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 17m9.368s
user 403m46.554s
sys 95m42.811s
[mcgrof: tested with ckmake]
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m50.520s
user 815m12.233s
sys 127m49.075s
Directory copying is recursive, so there's no need
to list subdirectories. All atheros ethernet drivers
are copied, so don't list them one by one. The same
is true for the Bluetooth include files.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m46.042s
user 816m2.488s
sys 126m33.079s
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m45.327s
user 814m25.678s
sys 128m22.341s
Samuel folded code under net/nfc/llcp/ onto
the parent net/nfc/ directory with llcp_ prefixes
for the files. Address this change introduced
as of next-20130430.
commit 30cc4587659e1c9b1bfade8b2a757d91e04758ab
Author: Samuel Ortiz <sameo@linux.intel.com>
Date: Fri Apr 26 11:49:40 2013 +0200
NFC: Move LLCP code to the NFC top level diirectory
And stop making it optional. LLCP is a fundamental part of the NFC
specifications and making it optional does not make much sense.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m48.875s
user 815m54.307s
sys 127m12.229s
The recent file shuffling on nouveau requires some
changes not upstream to get it to compile to ensure
some objects do get interpreted as requiring the
new search path.
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains 271a15ea
v3.10-rc1~129^2~24
commit 271a15eabe094538d958dc68ccfc9c36b699247a
Author: David Howells <dhowells@redhat.com>
Date: Fri Apr 12 00:38:51 2013 +0100
proc: Supply PDE attribute setting accessor functions
Supply accessor functions to set attributes in proc_dir_entry structs.
The following are supplied: proc_set_size() and proc_set_user().
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
cc: linuxppc-dev@lists.ozlabs.org
cc: linux-media@vger.kernel.org
cc: netdev@vger.kernel.org
cc: linux-wireless@vger.kernel.org
cc: linux-pci@vger.kernel.org
cc: netfilter-devel@vger.kernel.org
cc: alsa-devel@alsa-project.org
This was missing.
Intorduced in next-20130429 and Linus has merged it
onto v3.10-rc1. We cannot backport remove_proc_subtree()
modularly [0] so just go ahead and revert this change.
The alternative is to go and review each procfs usage
for each driver we have issues and see if it makes
sense to replace procs with debugfs upstream.
commit 8ce584c7416d8a85a6f3edc17d1cddefe331e87e
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Sat Mar 30 20:13:46 2013 -0400
procfs: add proc_remove_subtree()
just what it sounds like; do that only to procfs subtrees you've
created - doing that to something shared with another driver is
not only antisocial, but might cause interesting races with
proc_create() and its ilk.
[0] http://marc.info/?t=136841961600002&r=1&w=2
