This was added in commit 1aaa753d918 ("crypto: skcipher - Add helper to
zero stack request")
lib80211 does not use skcipher in kernel 4.20 any more, so only add this
to the 4.19 branch.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
This patch was taken from kernel 4.20.
This driver was missing in the list of the other lib80211 driver using
SKCIPHER.
This was added in commit 32751c901728 ("backport: add crypto skcipher
interface"), but all the drivers which need it were deactivated in
commit cdcec8e6128 ("backports: disable things needing LIB80211 unless
SKCIPHER can exist") because it does not compile any more. Remove this
code now completely from the tree.
lib80211 does not use skcipher any more, but directly uses the crpyto
API. since kernel 4.20.
pci_alloc_irq_vectors() was added in commit 162a6b312f1 ("add support
for pci_alloc_irq_vectors"), with this backport the WIL6210 driver works
again.
This reverts commit fbafdbe972402aad051d91d557f9cbb272844939.
This copies the pci_alloc_irq_vectors() function from kernel 4.9 and
replaces the __pci_enable_msi{x}_range() calls with calls to
pci_enable_msi{x}_range(), these were backported to kernel versions <
3.14, so no need to handle the older kernels specially here.
This also adds support for MSIx IRQs and adds the PCI_IRQ_* defines.
Fixes: 162a6b312f1b ("add support for pci_alloc_irq_vectors")
Cc: Omer Dagan <omer.dagan@tandemg.com>
pci_alloc_irq_vectors() needs to be wrapped in CONFIG_PCI and
CONFIG_PCI_MSI definition to avoid a function redefinition compiler
error.
Signed-off-by: Winnie Chang <winnie.chang@cypress.com>
Signed-off-by: Chi-Hsien Lin <chi-hsien.lin@cypress.com>
add support for function in kernels under 4.8
function is a wrapper around 'pci_enable_msi_block' or
'pci_enable_msi_range' depending on the kernel version
the min\max number of interrupts was overridden to always use the
max number of interrupts which seems correct since it was not
supported in the old APIs
Signed-off-by: Omer Dagan <omer.dagan@tandemg.com>
[use GPL expert as everything in backports, remove unused ifdef]
In the pre_doit and post_doit backports, we set the ops to our
backported version, so genetlink itself will always call it. But then
we don't check if the actual ops are set before calling them, which
causes a call to a NULL pointer. Fix this by checking if the ops are
actually set before calling them.
Fixes: ff6746638cf1 ("backports: genetlink: update completely")
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
Support xz compression in uninstall.
Also use compat.ko instead of mac80211.ko to detect
this, as compat is always compiled and mac80211 may
not be.
Replace all the different nested versions of generic netlink
backport with a single one, covering from < 3.13 all the way
to the upcoming netlink policy improvements in 4.20.
New API slated to show up in 4.20.
This is can be useful for minimal testing.
Since 4.15 this no longer takes a family argument, so add that
to the backports instead of trying to work around the family
argument having changed type.
Make all the magic variable argument calls inlines and
rename them so we can override them more easily later.
This reverts commit 1b481348b4564970e3cfa04023f1cc22ce2b6931.
It actually broke the build to include this, as memneq.c is always
built for kernels < 3.13, and thus we get a duplicate symbol export
if we skip the backport definitions.
Easier than making the build system depend on the strange versions
is to just always use our backported version with symbol rename.
If we don't include <linux/net.h> then __BACKPORT_NET_GET_RANDOM_ONCE
can never be defined, and we'll never get the compat code. Fix that.
Ubuntu cherry-picked the patch that added
u64_stat_update_begin_irqsave() in their 4.15 kernel, so we get a
redefinition compilation error if we try to compile against that.
To solve this, check UTS_UBUNTU_RELEASE_ABI and don't define our
backported function if it's 33 or higher.
Just clean up the dependency list, skcipher is known to not
work, but we neither backport bluetooth now, nor does current
upstream bluetooth actually need skcipher.
We can't really backport those, but add them anyway for compilation,
perhaps somebody doesn't want to suspend/resume?
Accidentally, the patch to remove the device removal code from earlier
kernels was sent from an intermediate version of the code, so the
patch doesn't apply properly. Fix it by updating it to the version
that was actually upstreamed.
With commit 3d6ce86ee794 ("drivers: remove force dma flag from buses")
in kernel 4.18 of_dma_configure() got the extra parameter force_dma.
This is backported by setting the force_dma member which was added in
commit d89e2378a97f ("drivers: flag buses which demand DMA
configuration") in kernel 4.15.
In older kernel versions we just ignore this parameter as the
of_dma_configure() function internally takes care of setting this
correctly.
Since commit 7b07cbefb68d ("iommu: of: Handle IOMMU lookup failure with
deferred probing or error") in kernel 4.12 this function returns int and
not void any more.
This reverts commit 1b4e6ad4d927c7998fa578f2d29e0c4ec01a9217.
Said commit broke b43 on older kernels (<3.16).
This is just a forward include, but earlier versions don't include
linux/types.h despite relying on it.
The getrawmonotonic64() function that is used by the
ktime_get_raw_ts64() backport was only introduced in 3.19. To fix
compilation with earlier kernels, do the convertion from
getrawmonotonic() manually if the kernel is < 3.19.
Additionally, add timespec_to_timespec64() that we need for this
conversion (and which was only introduced in 3.17).
On 4.16, the coredump method returns int rather than void. It
would be possible to fix that up, but so far I'm too lazy.
This driver has to include linux/kmemleak.h to get kmemleak_not_leak in
kernel 4.19. I haven't seen any problem when compiling against multiple
other kernels, but didn't test all the 3.X versions.
The netdev destructor spatch did not apply to the wil6210 driver any
more, because there the calls were done in a different order compared to
the spatch. Add an additional rule which applies when the order is
changed.
Fixes: 30a378636e47 ("backports: speed up netdev destructor spatch by two orders of magnitude")
Kernel 4.16 added a new .coredump member to the driver structure which
can be implemented by drivers. Remove this member on older kernel
versions as they do not support this feature.
__skb_pad() was only added with kernel 4.13.
The free_on_error parameter of __skb_pad() is set to constant true,
which is also the setting used by skb_pad() so it should be save to use
skb_pad() instead.
This patch should be added to the mainline Linux kernel.
The hostap and atmel wireless driver now make use of the
proc_create_single_data() function which can not easily be backported.
As these drivers are not used too often just deactivate them on older
kernel versions for now.
The WIL6210 driver now uses pci_alloc_irq_vectors() which is only
available in kernel >= 4.8, only build this driver against such kernel
versions.
[backporting the function doesn't seem too hard, but unless
somebody complains we're too lazy]
When RSI_COEX is activated the driver wants to link against the
rsi_bt_ops symbol from the bluetooth driver btrsi. This driver was only
added in kernel 4.17. Deactivate bluetooth coexistence support for older
kernel versions.
This is used by the rtl8723bs driver. The implementation is completely
in this header file, so it is save to copy it
I am not aware of any user of the NFC coded in backports, at least I
haven't seen any patches regarding this. Remove this code to reduce the
efforts needed in the backports project.
Use the versions shipped with the kernel instead.
bcma and ssb didn't change much in the last few years, most of the
changes were related to code only used on embedded devices. Removing
this reduces the number of parts we have to backport. b43, b43legacy and
brcmsmac work well with the in kernel version.
In kernel v4.19-rc1, the activate op in struct led_trigger, changed
from void to int. To solve this, add a semantic patch to insert a
wrapper function that returns void and calls the function that returns
int.
[use <+... ...+> as suggested by Hauke]
Replace the existing skb->xmit_more semantic patch rule with a more
generic one that uses a helper inline function.
The u64_stats_init() macro was turned into a static inline function in
v4.2 to prevent warnings that happen when its argument is not used
elsewhere.
Since we started hitting these warnings, undefine the macro and define
the static inline to prevent them.
With kernels < 3.17, we need to include hrtimer.h to get ktime_divns()
for the ktime_get_boottime_seconds() backport. But we can't just
include htrtimer.h in the backport timekeeping.h because we run into
some cyclical inclusions that cause problems. To solve that make
ktime_get_boottime_seconds() non-inline and add it to a new
backport-4.18.c file.
In kernels earlier than 3.18, the raw_spin_lock defininition when
CONFIG_DEBUG_LOCK_ALLOC is not enabled, was dropping one of the
parameters, which caused a few "unused variable" warnings at places
where this argument was only used in the call to
raw_spin_lock_nested(). Take the latest definition which evaluates
the argument to avoid compiler warnings.
We were including leds.h twice in backport-4.5.c and one of them was
very early, which caused inclusion conflicts at least with < 3.16
kernels.
This was introduced in 4.18 and is needed by rhashtable.h, that we
copy. So copy it as well.
For some reason, sometimes when the git logs contain non-ascii
characters, we get some conversion errors. This only happens if one
of the strings we use is explicitly unicode, otherwise everything is
fine. The only string we use that is of unicode type is the tree
names that comes from the configuration sections. To avoid issues,
convert the strings we get from the config file into ascii before
using it.
