include/linux/rhashtable.h now uses struct lockdep_map unconditionally
which is fine for upstream as lockdep.h defines an empty lockdep_map
structure if CONFIG_LOCKDEP is not set. However, that is only true
since kernel 4.15 so adding such definition in our lockdep.h to cover
older kernels.
Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com>
We were not checking if the allocation failed in
backport_genl_register_family(), which could lead to NULL pointer
dereferences later. Fix that.
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
Include static inline functions that were added by commit
74de6960c99d ("rcu: Provide functions for determining if call_rcu()
has been invoked").
[Activate on < 4.20 only]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
The select queue parameters changed so the patches need to be updated
as well.
[Fix compile on kernel > 4.19]
No manual changes needed.
The mt76 core driver makes use of struct page_frag_cache which was only
added with kernel 4.2, deactivate all modules of the mt76 driver on
older kernel versions. CONFIG_MT7603E was newly added in this kernel
version.
When building against kernel 4.8, 3.14 and older, brcmfmac failed
because struct sk_buff was not declared in brcmfmac/bus.h. This is used
in the brcmf_bus_ops.txdata() callback.
I do not know why this was working before.
smp_acquire__after_ctrl_dep() was introduced in kernel 4.8 in upstream
Linux commit 33ac279677d ("locking/barriers: Introduce
smp_acquire__after_ctrl_dep()") and is used by backports lib-refcount.c
implementation now.
This just adds the default implementation to backports.
rhashtable_lookup_get_insert_fast() was added in kernel 4.12 in Linux
upstream commit f9fe1c12d12 ("rhashtable: Add
rhashtable_lookup_get_insert_fast") It is now used by mac80211.
For kernel < 4.9 we already backport the complete rhashtable
implementation, so this is only needed for kernels more recent than 4.9.
This is copied from upstreamn Linux kernel.
Add new macros introduced from v5.1-rc1
23323289b154 netlink: reduce NLA_POLICY_NESTED{,_ARRAY} arguments
v3: Fix v4.20 compilation error
Signed-off-by: AceLan Kao <acelan.kao@canonical.com>
The patch patches/0013-fix-makefile-includes/mt76.patch was added in
upstream Linux commit 85b7e2acd31b ("mt76: Add missing include of
linux/module.h") which was added in v5.1-rc1
The iwlwifi driver now needs this function. Backport it.
The code surrounding the #ifdef we add has changed. Update the patch
accordingly.
If we fail to allocate extack, we fall back to the code path
that tries to send an error *with* extack, but that will
access our extack pointer. It also doesn't make sense, so just
return an error back to netlink immediately and let it handle
sending the error message to userspace.
The patch that introduces nospec.h was cherry-picked for 4.15 only in
4.15.2, so we need to adjust the ifdefs of our stub.
At least one function, namely ftrace_print_array_seq(), still needs
the ftrace_event.h header file, otherwise sparse may warning that it
is declared as non-static without pre-declaration.
Now that 4.21 became 5.0, we need to update the Makefile accordingly.
Stop looking at 4.19 for the 4.* series and add 5.*.
Enable users to be able to conveniently select the Marvell wifi drivers that
they need.
Signed-off-by: Tamás Szűcs <tszucs@protonmail.ch>
The patch patches/0086-rtl8723bs-no-extern-inline.patch was added in
upstream Linux commit 97715058b70d ("staging: rtl8723bs: Fix build error
with Clang when inlining is disabled") which was added in v5.0-rc4.
1 3.10.108 [ LINK ]
2 3.11.10 [ LINK ]
3 3.12.74 [ OK ]
4 3.13.11 [ LINK ]
5 3.14.79 [ LINK ]
6 3.15.10 [ LINK ]
7 3.16.62 [ OK ]
8 3.17.8 [ LINK ]
9 3.18.134 [ OK ]
10 3.19.8 [ LINK ]
11 4.0.9 [ LINK ]
12 4.1.52 [ OK ]
13 4.2.8 [ LINK ]
14 4.3.6 [ LINK ]
15 4.4.174 [ OK ]
16 4.5.7 [ OK ]
17 4.6.7 [ OK ]
18 4.7.10 [ OK ]
19 4.8.17 [ OK ]
20 4.9.155 [ OK ]
21 4.10.17 [ OK ]
22 4.11.12 [ OK ]
23 4.12.14 [ OK ]
24 4.13.16 [ OK ]
25 4.14.98 [ OK ]
26 4.15.18 [ OK ]
27 4.16.18 [ OK ]
28 4.17.19 [ OK ]
29 4.18.20 [ OK ]
30 4.19.20 [ OK ]
31 4.20.7 [ OK ]
The name of this configuration option was changed in Linux commit
b7da53cd6cd1 ("qtnfmac_pcie: use single PCIe driver for all platforms").
dev_open() got the extra parameter extack in Linux commit 00f54e68924e
("net: core: dev: Add extack argument to dev_open()"), just ignore it on
older kernel versions. This is used by the hostap driver.
This was introduced in Linux commit 58d81d64e06f ("lib: cordic: Move
cordic macros and defines to header file") and is used by the b43 and
brcmsmac driver.
This was introduced in Linux commit 801f87469ee8 ("netlink: add
nl_set_extack_cookie_u64()") and is used by the wireless subsystem.
This was introduced in Linux commit a08f06bb7a07 ("seq_file: Introduce
DEFINE_SHOW_ATTRIBUTE() helper macro" and is used by the cw1200 and the
wil6210 driver.
These functions are not used by any driver any more, remove them. They
were introduced for the frame vector code which was used by the media
subsystem. They also case some compile problems with kernel 4.4 which
get fixed by just removing this code.
lib80211 does not use skcipher any more, build these modules again on
older kernels without skcipher.
ipw2x00 uses DRIVER_ATTR_RW which does not compile on kernel 3.10,
require at least kernel 3.11.
Add some new wifi drivers to the default configuration.
The alx, igb and the media driver were removed some time ago, also
remove the default configurations.
These functions declared in backport-public_key.h are not implemented in
backports, and they were causing warnings because kernel_pkey_params was
not declared before.
This driver includes linux/pm_wakeirq.h which was added in kernel 4.2,
deactivate this driver on older kernel versions.
This was added in upstream commit 4c96b7dc0d39 ("Add a matching set of
device_ functions for determining mac/phy") and is used by ath10k now.
In the mainline kernel it uses device_property_read_u8_array(), but that
was only introduced in kernel 3.18, use of_property_read_u8_array() only
on all kernel versions where this backport is needed which was added
much earlier.
Without the inclusion of linux/module.h, MODULE_FIRMWARE was not
declared when compiling against some kernel versions, add it.
This was introduced in kernel commit 8c2dd3e4a4b ("mm: rename
__alloc_page_frag to page_frag_alloc and __free_page_frag to
page_frag_free") and commit 44fdffd7050 ("mm: add support for releasing
multiple instances of a page") and is used by the mt76 driver.
Backporting it to kernel older than 4.2 is harder so just do it till
that version.
This was introduced in kernel commit fe896d18789 ("mm: introduce page
reference manipulation functions") and will be used by
__page_frag_cache_drain() in the next commit.
This patch was merged upstream and removed from backports:
* patches/0090-use-skb_pad.patch
This patch was manually modified:
* patches/0025-usb-sg/usbnet.patch
This was added in commit 32751c901728 ("backport: add crypto skcipher
interface"), but all the drivers which need it were deactivated in
commit cdcec8e6128 ("backports: disable things needing LIB80211 unless
SKCIPHER can exist") because it does not compile any more. Remove this
code now completely from the tree.
lib80211 does not use skcipher any more, but directly uses the crpyto
API. since kernel 4.20.
pci_alloc_irq_vectors() was added in commit 162a6b312f1 ("add support
for pci_alloc_irq_vectors"), with this backport the WIL6210 driver works
again.
This reverts commit fbafdbe972402aad051d91d557f9cbb272844939.
This copies the pci_alloc_irq_vectors() function from kernel 4.9 and
replaces the __pci_enable_msi{x}_range() calls with calls to
pci_enable_msi{x}_range(), these were backported to kernel versions <
3.14, so no need to handle the older kernels specially here.
This also adds support for MSIx IRQs and adds the PCI_IRQ_* defines.
Fixes: 162a6b312f1b ("add support for pci_alloc_irq_vectors")
Cc: Omer Dagan <omer.dagan@tandemg.com>
pci_alloc_irq_vectors() needs to be wrapped in CONFIG_PCI and
CONFIG_PCI_MSI definition to avoid a function redefinition compiler
error.
Signed-off-by: Winnie Chang <winnie.chang@cypress.com>
Signed-off-by: Chi-Hsien Lin <chi-hsien.lin@cypress.com>
add support for function in kernels under 4.8
function is a wrapper around 'pci_enable_msi_block' or
'pci_enable_msi_range' depending on the kernel version
the min\max number of interrupts was overridden to always use the
max number of interrupts which seems correct since it was not
supported in the old APIs
Signed-off-by: Omer Dagan <omer.dagan@tandemg.com>
[use GPL expert as everything in backports, remove unused ifdef]
In the pre_doit and post_doit backports, we set the ops to our
backported version, so genetlink itself will always call it. But then
we don't check if the actual ops are set before calling them, which
causes a call to a NULL pointer. Fix this by checking if the ops are
actually set before calling them.
Fixes: ff6746638cf1 ("backports: genetlink: update completely")
Support xz compression in uninstall.
Also use compat.ko instead of mac80211.ko to detect
this, as compat is always compiled and mac80211 may
not be.
Replace all the different nested versions of generic netlink
backport with a single one, covering from < 3.13 all the way
to the upcoming netlink policy improvements in 4.20.
New API slated to show up in 4.20.
This is can be useful for minimal testing.
Since 4.15 this no longer takes a family argument, so add that
to the backports instead of trying to work around the family
argument having changed type.
Make all the magic variable argument calls inlines and
rename them so we can override them more easily later.
This reverts commit 1b481348b4564970e3cfa04023f1cc22ce2b6931.
It actually broke the build to include this, as memneq.c is always
built for kernels < 3.13, and thus we get a duplicate symbol export
if we skip the backport definitions.
Easier than making the build system depend on the strange versions
is to just always use our backported version with symbol rename.
