Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Upstream commit abe05f0c83f5947f84cc0e6408ee0930595389b7
page_ref_count() was backported to kernel version 4.4.216, do not add it
in backports for this kernel version any more.
Upstream commit e1e5fc5c84336b1b4e1354895fffafa7b2524bd7
We're testing sparse, so don't want warnings here.
Upstream commit a4ff4832887a4c2aa3b7599ae784290b3d2ff041
The rx_count and rx_list attributes were only added in kernel 5.4 in
commit 323ebb61e32b ("net: use listified RX for handling GRO_NORMAL skbs")
Link: https://lore.kernel.org/r/20200126231336.2573-1-hauke@hauke-m.de
Upstream commit eea7eb88324405d9ed90ff0b430d631f5f25b0e0
Since my last system upgrade I started building with gcc 9,
and that complains that a function is cold when the one we
create locally here isn't - mark it as cold always, I don't
think it would complain the other way around.
Upstream commit 3c6ca332a2ea9e3ebc6c99c5095a7acf14f09b91
In v5.2, x509_cert_parser.c implemented a new function,
x509_note_params(). So we need the new generated asn1 files. Update
these files from the ones generated with v5.2
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
Upstream commit a17ed9f1fcd12d56757bc33a275d5dfa98d7e75e
When building with /bin/sh -> bash, things are SUPER slow (at least
for me), because bash takes a LOOONG time to look at the environment
variables (and we typically have around 6k), adding over a second to
each bash invocation for me.
The reason we export them is that we need them in all of the sub-
makes, and those only read auto.conf, which we can't change.
Work around this by overriding 'make' itself, and using --eval to
read *our* .config file into each make that gets called. This way,
the variables are present in all make invocations in the same way
as they would be through the environment, but don't get passed to
shell invocations.
If --eval is not supported, keep doing what we did before.
kvcalloc() was added in kernel commit 1c542f38ab8d ("mm: Introduce
kvcalloc()") and is now used by the fq header filers.
The skb_get_hash_perturb() function now takes a siphash_key_t instead of
an u32. This was changed in commit 55667441c84f ("net/flow_dissector:
switch to siphash"). Use the correct type in the fq header file
depending on the kernel version.
Since Linux upstream commit 4cfd21885592 ("PCI: let
pci_disable_link_state propagate errors") The
pci_disable_link_state() function can return an error. This
return code is now used by the mt76 driver.
In case it is not possible to disable ASPM, for example on some ACPI
systems, we should return an error and mt76 handles this. Do this by
checking the PCI registers if the operation was successfully.
The checking of the PCI register was added by Felix Fietkau.
When running under an Arch Linux system where python is python3, the
following error was observed:
Traceback (most recent call last):
File "/home/dfrey/projects/backports-linux/devel/pycocci", line 172, in <module>
ret = _main()
File "/home/dfrey/projects/backports-linux/devel/pycocci", line 158, in _main
if args.jobs > 0:
TypeError: '>' not supported between instances of 'NoneType' and 'int'
The problem is that args.jobs is None in the case that the -j or --jobs
argument wasn't passed to the command. In python3, an exception is
generated when performing a comparison between different types.
Signed-off-by: David Frey <dpfrey@gmail.com>
skb_ext_reset() was added in upstream commit 174e23810cd3 ("sk_buff:
drop all skb extensions on free and skb scrubbing") and is now used by
mac80211_hwsim.
skb_ext_reset() replaced the old call to secpath_reset() in
mac80211_hwsim and other places and it also does similar things than
this function. Juts call the old secpath_reset() on older kernel
versions.
This was added to net/xfrm.h and not linux/skbuff.h because
secpath_reset() is only available in net/xfrm.h in the upstream kernel
and this is not included in linux/skbuff.h.
nf_reset_ct() was added in upstream Linux commit 895b5c9f206e
("netfilter: drop bridge nf reset from nf_reset") and is now used by
mac80211_hwsim.
The upstream commit renamed nf_reset() to nf_reset_ct() and did some
modifications to this inline function, just call the old version on
older kernel versions.
Instead of limiting the maximum load to a fixed number limit it to the
number of available CPUs. This should hopefully increase the speed as
less task switches are needed.
Also reduce the number of treads per build to half the number of
available CPUs. Normally multiple builds are done in parallel anyway.
Only build the own lib-arc4 version when it is not build as a module or
into the kernel. Without this change it was also build when
CRYPTO_LIB_ARC4 was build as a module in the kernel.
The ath9k owl driver uses pci_lock_rescan_remove() and
pci_unlock_rescan_remove() which was added in kernel 3.14, only compile
it on kernel >= 3.14.
Add writel_relaxed() from upstream commit 9439eb3ab9d1 ("asm-generic:
io: implement relaxed accessor macros as conditional wrappers") which is
used by the wil6210 driver.
Add __ioread32_copy() from usptream Linux commit a9aec5881b9d
("lib/iomap_copy.c: add __ioread32_copy()") which is used by mt76
driver.
Add skb_mac_offset() from upstream kernel commit ea6da4fd388a
("net/skbuff: Introduce skb_mac_offset()") which is used by the wil6210
driver.
Add skb_frag_off() Which was added in upstream commit 7240b60c98d6
("linux: Add skb_frag_t page_offset accessors") which is used by the
usbnet driver.
Add devm_platform_ioremap_resource() from upstream kernel commit
7945f929f1a7 ("drivers: provide devm_platform_ioremap_resource()") which
Add static_assert() from upstream commit 6bab69c65013 ("build_bug.h: add
wrapper for _Static_assert") which is used by rtw88.
In upstream commit 7ce2e76a0420 linux/pci-aspm.h was removed and the
content included into pci.h. Add an include to have the functions
defined in linux/pci-aspm.h available when linux/pci.h is included.
Manual modifications where needed to make the following patch apply:
patches/0013-fix-makefile-includes/rtw88.patch
This updates the KConfig system used in backports to the version from
kernel 4.17. In kernel 4.18 some bigger changes to the KConfig system
were introduced which are harder to backport, so start with using this
older version.
This version now generates the zconf.lex.c and zconf.tab.c files from
the original sources, newer kernel versions will delete these files in
a make clean, after that they are now regenerated. We do not ship them
by default any more, so we need lex and yacc.
The Makefile was not copied from the mainline kernel but this is written
specifically for the backports project.
Cc: Anthony Wong <yp@anthonywong.net>
The airo driver now uses crypto_sync_skcipher() which was introduced in
kernel 4.20, just make it depend on this kernel version.
GRO_CONSUMED was added in kernel commit 25393d3fc055 ("net: Prepare gro
for packet consuming gro callbacks") in kernel 4.11. Just remove it for
cfg80211.h uses struct nla_policy in two places, but does not include
net/netlink.h directly. Because of this missing include the rename to
struct nla_backport_policy is not applied and this results in type
mismatch errors when compiling backports. With this additional include
the type is renamed.
The arc4 library was extracted from the crypto system in commit
dc51f25752bf ("crypto: arc4 - refactor arc4 core code into separate
library") in kernel 4.20. This is now used by mac80211 and lib80211 for
WEP crypto.
The struct netlink_callback got a new extack attribute in commit
4a19edb60d02 ("netlink: Pass extack to dump handlers") in kernel 4.20.
Use a function instead of directly accessing it to return NULL on older
kernel versions, the code should handle NULL.
The xmit_more member was removed from struture sk_buff and the
skb_xmit_more() function is not used in backports any more, just remove
this code as it does not compile any more on kernel 5.2 and more recent.
This adds the function trace_##name##_enabled to __DECLARE_TRACE() which
was added in commit 7c65bbc7dc ("tracing: Add
trace_<tracepoint>_enabled() function"). This is now used by ath10k.
__DECLARE_TRACE() got other changes wit kernel 3.16, so add two
different versions.
nl80211_validate_nested() was added in commit 901bb9891855 ("nl80211:
require and validate vendor command policy") in kernel 5.3 and is used
by nl80211.
ktime_get_boottime_ns() was added in commit 9285ec4c8b61 ("timekeeping:
Use proper clock specifier names in functions") in kernel 5.3. This is
used by multiple drivers.
BITS_PER_TYPE was moved in the upstream kernel in commit 9144d75e22ca
("include/linux/bitops.h: introduce BITS_PER_TYPE") in kernel 4.19 and
is now used by the ath10k driver.
No manual changes needed.
Older kernel versions are missing these files and still try to include
them, add them to make compile testing on recent system easier.
The behavior of of_get_mac_address() changed in kernel 5.2, it now
returns an error code and not NULL in case of an error.
This was changed in upstream kernel commit d01f449c008a
("of_net: add NVMEM support to of_get_mac_address")
This removes the removed driver CPTCFG_R8822BE and adds the newly added
drivers CPTCFG_MT7603E, CPTCFG_MT7615E and CPTCFG_RTW88
The functions provided by include/net/inet_frag.h are not used by any
code in backports any more and this file causes compile warnings
with kernel 3.16.
On kernel 3.18 linux/module.h is not indirectly included in this
driver. On some other kernel version linux/interrupt.h is not
indirectly included, but needed.
This fixes some compile problems in the rtw88 driver.
The MT76 driver does not compile on kernel < 4.2, also add such a
dependency to the new driver MT7615E.
ktime_t was converted from the union to s64 in kernel 4.10.
hrtimer_start() was already converted some time ago in backports, now
mac80211_hwsim uses hrtimer_start() together with the newly added
functions.
In the current kernel napi_complete_done() returns a bool and this is
now used by the mt76 driver. Try to backport this functionality by
doing the check which makes the function return false already in
backports.
This was added in upstream kernel commit 364b6055738b ("net: busy-poll:
return busypolling status to drivers")
DMI_PRODUCT_SKU was added in kernel 4.18, do not use it on older kernel
versions.
mac80211_hwsim uses HRTIMER_MODE_ABS_SOFT and HRTIMER_MODE_REL_SOFT now.
These enum entries were added in commit 98ecadd4305d ("hrtimer: Add
clock bases and hrtimer mode for softirq context") in kernel 4.16.
This will execute the timers in hard interrupt context and not in soft
interrupt context like intended.
The brcmfmac driver now uses new sdio_retune*() functions. They are
added with kernel 5.2-rc6 and are backported to kernel 4.19.56 and
5.1.15
sdio_retune_hold_now() and sdio_retune_release() should work like in the
upstream kernel, the implementation of mmc_retune_release() and
mmc_retune_hold() was copied to backports into these functions. On
kernel < 4.3 backporting this is not so easy, so just use an empty
implementation there.
It is not possible to backport sdio_retune_crc_disable() and
sdio_retune_crc_enable() because they need an additional member in a
structure, just add an empty implementation.
ipv6_stubs.h was added in kernel commit 3616d08bcbb5 ("ipv6: Move ipv6
stubs to a separate header file").
Most of its content is from include/net/addrconf.h, so include that file
indirectly on older kernel versions.
This extends the backported netlink handling with strict parsing. the
struct gen_ops now supports the validate member and does the validation
inside the backport layer.
This is needed to use backports with kernel 5.2.
[Hauke: Remove nla_validate_nested()]
[Hauke: Support struct genl_ops on older kernel versions]
The cordic.c file was moved and the driver from drivers/staging/rtlwifi/
was removed in mainline kernel.
