== ckmake-report.log ==
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.10.17 [ OK ]
19 3.11.6 [ OK ]
20 3.12-rc7 [ FAIL ]
21 3.2.52 [ OK ]
22 3.3.8 [ OK ]
23 3.4.67 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.17 [ OK ]
19 3.11.6 [ OK ]
20 3.12-rc3 [ FAIL ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
Upstream commit: 09556c795e8afb6672893d41a05a6728c306e5f6
The Atheros atl1c driver now uses build_skb() which was added in 3.5.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Upstream commit: 1a996968fc51cc1323e1bedceb32143aa1226e9b
Upstream commit: 551f46cb4472f03bea0df808ef892ea8eb49a2af
This fixes a build error one some non x86 systems.
Upstream commit: 168beb7a3dad933d29f8e0dabd37db8cf189a4c7
This should prevent some compile errors when backports is used with a
kernel without PCI support.
Upstream commit: 6bc60d332b7109c99cd5f5d5f8b7791f921289d6
The newly created function ends with _compat. This causes compile
warnings and probably runtime problems on kernel < 2.6.29.
Upstream commit: 72657d3ff7c144a85b0b916c81bfeaa54e2d623f
The folder name did not started with an v.
Upstream commit: 4fb89169e8a5969388b16771695452f55ceb43e6
Without this slash it wants to use the directory /backportsstable/
Upstream commit: 3455026991cda1129ae313830ecd7386f75362a5
the filename in kup put should end with a slash otherwise it tried to
overwrite this file.
Upstream commit: fdda21c96cc00461127a394e22eea3f7cb1119a5
Add a logging of the next command to be executed.
Upstream commit: efdb6bbb9cd89d3174dbdecf02b79c0f294e3d10
The full path has to be provided not just the new directory to create.
Upstream commit: 515e82602216fc40a224f02f34d0a0f0c03c8309
dir_to_tar could be the absolute path to the directory to to tar, but
we do not want the full patch in the tar, just the basename.
In addition the second close is not necessary.
Upstream commit: 10eca9f5bef1821de09601a3a7db7eb337c56ba0
This streamlines our release process making it easier for
transitioning releases onto other backport developers.
Upstream commit: 57554a365682979473778ffca9a9c5c82ab4dee6
kup is written in perl, add some basic python interfaces
for it to allow us to upload to kernel.org backport
releases.
Upstream commit: dcd5524fc04730b0af05b28388d246cad97a91c2
Note that kup expects --armor --detach-sign, we'll pass that
as part of our extra_args. The python gpg lib doesn't provide
support for random arguments as this one, so just add our
own little helper and carry it over.
Upstream commit: f9fa9dac70b99a2cf12b494a9fe4440404a30c4e
This cleans sanitizes a source tree and ensures
no content is present from what was intended.
Upstream commit: 455aae0352d34e97fc5910927428c9f8ff44f77a
This verifies that the tree provided has its last commit
both tagged and also digitally signed. In short it does:
git tag -v $(git describe --dirty)
This will be used later.
Upstream commit: 52aca1afb093baef20140b33d50426ecf80d3f6d
We'll use this later.
Upstream commit: 276bf778df6e33f66391e4cea9cbceb888db6f9d
We use --porcelain given that this spits out the results
in an easy-to-parse format for scripts and will remain stable
across git versions and regardless of user configuration.
We will use this later.
Upstream commit: ea70308d746325654d44851be602fe02492b59f9
This lets us throw at it whatever extra stuff we want.
Upstream commit 38dbdde48f135c6b8fd1524eacf79041c7b5899a
The new macro, introduced by
commit 9f5876fa9cfb8cd6f450c200043ca7e31915f976
Author: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Date: Thu Jul 18 16:40:55 2013 -0700
backports: backport drvdata = NULL core driver fixes
evaluates its argument multiple times, causing crashes as
there are potential side-effects of the called code and/or
the arguments.
Fix this by converting it to static inlines.
Also remove the driver_probe_device() macro that has the
same issue, but tries to wrap a function that isn't even
available outside the driver core code in any kernel.
The ath5k driver was patched on v3.11-rc4 with the following
fix which threw off a backport patch.
mcgrof@garbanzo ~/linux-stable (git::master)$ git describe --contains \
f287cbd01f2e8e1b325b96233c373619c2d25ee2
v3.11-rc4~5^2~27^2^2~23
commit f287cbd01f2e8e1b325b96233c373619c2d25ee2
Author: Bob Copeland <me@bobcopeland.com>
Date: Thu Jul 11 09:19:13 2013 -0400
ath5k: fix extra set bit in multicast mask
Bit 32 was always set which looks to have been accidental,
according to git history.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
Upstream commit d611a3226cb97e33b5fe7e43234e91d126de9c42
The old patch changed the or condition to an and condition which is
wrong. This patch fixes the logic again.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
real 34m26.742s
user 929m30.328s
sys 128m39.452s
<sad_trombone>This did not make it to v3.11</sad_trombone>
commit 84292b549bf48f80d470215b357179ea13d64a35
Author: Dave Chinner <dchinner@redhat.com>
Date: Wed Jul 3 10:19:58 2013 +1000
drivers: convert shrinkers to new count/scan API
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
real 34m34.417s
user 933m25.264s
sys 129m41.580s
This is required by s2mps11 as of at least next-20130709.
A hunk context was off for alx.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
real 32m59.877s
user 880m31.524s
sys 124m11.996s
This backports cross-device reservation support.
Given that this feature is built around the
CONFIG_DMA_SHARED_BUFFER and given that some older kernels
will have DMA_SHARED_BUFFER without cross device reservation
support we can't use the c-file and h-file backports Kconfig
trick to automatically backport this feature from the
target git tree.
commit 786d7257e537da0674c02e16e3b30a44665d1cee
Author: Maarten Lankhorst <m.b.lankhorst@gmail.com>
Date: Thu Jun 27 13:48:16 2013 +0200
reservation: cross-device reservation support, v4
This adds support for a generic reservations framework that can be
hooked up to ttm and dma-buf and allows easy sharing of reservations
across devices.
The idea is that a dma-buf and ttm object both will get a pointer
to a struct reservation_object, which has to be reserved before
anything is done with the contents of the dma-buf.
Changes since v1:
- Fix locking issue in ticket_reserve, which could cause
mutex_unlock
to be called too many times.
Changes since v2:
- All fence related calls and members have been taken out for now,
what's left is the bare minimum to be useful for ttm locking conversion.
Changes since v3:
- Removed helper functions too. The documentation has an example
implementation for locking. With the move to ww_mutex there is no
need to have much logic any more.
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
Cc: maarten.lankhorst@canonical.com
Cc: jglisse@redhat.com
Cc: airlied@redhat.com
This backports the kernel's wound/wait style locks 040a0a371,
using the linux-stable v3.11-rc2 as a base for development.
Given the complexity to support debugging mutexes this backport
implementation is simplified by only making this feature availabe
if you to have DEBUG_MUTEXES and DEBUG_LOCK_ALLOC disabled.
Given that ww mutex is required for DRM this also means we must
update the kconfig for DRM and require you to also not be able to build
DRM if you have either of these options enabled. Support for
DEBUG_MUTEXES and DEBUG_LOCK_ALLOC can be added later by anyone
daring. This uses the new dependencies file kconfig language
extension to specify the backport feature build restrictions
for DRM.
Part of the ww mutex addition to the kernel required modifying
the fast path mutex locking scheme by requiring you to deal
with the slow path alternatives on your own (refer to a41b56ef).
The reason for this change was that the mutex fastpath implementation
assumed your slowpath alternative can only be passed one argument
and the addition of ww mutexes requires dealing with the slow
path with a context passed.
It'd be painful to backport all asm for an optimized fastpath
implementation so we penalize the backport ww mutex fast path
by using the generic atomic_dec_return().
To backport a clean our own mutex_lock_common() with the least
amount of changes against upstream commits 2bd2c92c and 41fcb9f2
also needed to be backported. Commit 2bd2c92c dealt with adding
support for queue mutex spinners with an MCS lock, since this
cannot be backported for older kernels we provide empty inlines.
Commit 41fcb9f2 just removed SCHED_FEAT_OWNER_SPIN as it was an
early hack, the only thing required to backport this commit was
to provide an alternative declaration for mutex_spin_on_owner()
as it was declared non-inline for older kernels.
Finally c5491ea7 required backporting schedule_preempt_disabled()
as well but that just consisted of carrying over the original
implementation. Since its not exported we need to reimplement
it to make it available to our internal core ww mutex port.
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains 040a0a371
v3.11-rc1~147^2~5
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains a41b56ef
v3.11-rc1~147^2~6
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains 2bd2c92c
v3.10-rc1~200^2~3
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains 41fcb9f2
v3.10-rc1~200^2~5
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains c5491ea7
v3.4-rc1~3^2~27
commit 040a0a37100563754bb1fee6ff6427420bcfa609
Author: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Date: Mon Jun 24 10:30:04 2013 +0200
mutex: Add support for wound/wait style locks
Wound/wait mutexes are used when other multiple lock
acquisitions of a similar type can be done in an arbitrary
order. The deadlock handling used here is called wait/wound in
the RDBMS literature: The older tasks waits until it can acquire
the contended lock. The younger tasks needs to back off and drop
all the locks it is currently holding, i.e. the younger task is
wounded.
For full documentation please read Documentation/ww-mutex-design.txt.
References: https://lwn.net/Articles/548909/
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Rob Clark <robdclark@gmail.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: dri-devel@lists.freedesktop.org
Cc: linaro-mm-sig@lists.linaro.org
Cc: rostedt@goodmis.org
Cc: daniel@ffwll.ch
Link: http://lkml.kernel.org/r/51C8038C.9000106@canonical.com
commit a41b56efa70e060f650aeb54740aaf52044a1ead
Date: Thu Jun 20 13:31:05 2013 +0200
arch: Make __mutex_fastpath_lock_retval return whether fastpath succeeded or not
This will allow me to call functions that have multiple
arguments if fastpath fails. This is required to support ticket
mutexes, because they need to be able to pass an extra argument
to the fail function.
Originally I duplicated the functions, by adding
__mutex_fastpath_lock_retval_arg. This ended up being just a
duplication of the existing function, so a way to test if
fastpath was called ended up being better.
This also cleaned up the reservation mutex patch some by being
able to call an atomic_set instead of atomic_xchg, and making it
easier to detect if the wrong unlock function was previously
used.
Cc: robclark@gmail.com
Cc: daniel@ffwll.ch
Link: http://lkml.kernel.org/r/20130620113105.4001.83929.stgit@patser
commit 2bd2c92cf07cc4a373bf316c75b78ac465fefd35
Author: Waiman Long <Waiman.Long@hp.com>
Date: Wed Apr 17 15:23:13 2013 -0400
mutex: Queue mutex spinners with MCS lock to reduce cacheline contention
<-- snip -->
commit 41fcb9f230bf773656d1768b73000ef720bf00c3
Date: Wed Apr 17 15:23:11 2013 -0400
mutex: Move mutex spinning code from sched/core.c back to mutex.c
<-- snip -->
commit c5491ea779793f977d282754db478157cc409d82
Author: Thomas Gleixner <tglx@linutronix.de>
Date: Mon Mar 21 12:09:35 2011 +0100
sched/rt: Add schedule_preempt_disabled()
<-- snip -->
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Rob Clark <robdclark@gmail.com>
Cc: daniel@ffwll.ch
Certain complex features that are backported may be be
limitted to a certain target build configuration. An example
can be if a backported feature is not yet backported with
support for lockdep. In order to avoid build failures with
these types of restrictions allow for specifying build
configuration dependencies on backported upstream kconfig
symbols other than just kernel versioning contstraints.
This adds support for specifying upstream kconfig constaints
other than kernel versioning by adding kconfig language
extensions on the dependencies file. This will update the
copied over upstream Kconfig file for the symbol specified
with the kconfig constraints specified.
This was added via 9c19761a. While at it clean up the backported
header a bit to make backporting more OF stuff more manageable.
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains 9c19761a
v3.7-rc1~123^2~4
commit 9c19761a7ecdc86abb2fba0feb81e8952eccc1f1
Author: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Date: Tue Sep 18 08:10:28 2012 +0100
dt: introduce of_get_child_by_name to get child node by name
This patch introduces of_get_child_by_name function to get a child node
by its name in a given parent node.
Without this patch each driver code has to iterate the parent and do
a string compare, However having of_get_child_by_name libary function would
avoid code duplication, errors and is more convenient.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
This is required by CONFIG_REGULATOR_MAX8998
which builds drivers/regulator/max8998.c as of
next-20130703.
When an automatic backport isn't included due to not
being used (see commit 6e0475b599217eceb8e01a1e572c,
"gentree: add automatic backports only if needed"),
selecting BACKPORT_USERSEL_BUILD_ALL will make the
build fail. Avoid this by disabling such symbols in
the Kconfig.
DMI_EXACT_MATCH uses struct dmi_strmatch's new member exact_match:
@@ -456,7 +456,8 @@ enum dmi_field {
struct dmi_strmatch {
- unsigned char slot;
+ unsigned char slot:7;
+ unsigned char exact_match:1;
char substr[79];
Prior to 5017b285 we only had slot so to use DMI_EXACT_MATCH with its
intent we'd have to do something like slot |= 1 if its called. This
however assumes though that older code has the sanity check as changed
in 5017b285 on drivers/firmware/dmi_scan.c. dmi_scan.o gets linked
with CONFIG_DMI. At least for x86 that gets objects sprinkled on
arch/x86/, but more importantly CONFIG_DMI is bool. I've argued how I
envision us being able to backport core components before (see
0935deab for the hint) but as it is right now we can't. We only
backport things we can throw in as modular.
Since we only backport modularly for now we can't backport DMI_EXACT_MATCH()
and as such all entries defined with DMI_EXACT_MATCH() should be ifdef'd
out for usage only on kernels >= v3.11 but to help reduce code churn we
can also just force such entries to be ignored for now. We therefore
backport DMI_EXACT_MATCH() for now to match something that will not be
found.
As noted by Johannes this wasn't being initialized
without this.
The regexp doesn't require the extra brackets.
The source line can be prefixed by spaces and tabs. Without
this a slew of kconfig options were not being parsed for
dependency checking and at compile time they'd obviously
fail.
Tested with ckmake against next-20130627
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
real 34m5.379s
user 921m5.112s
sys 128m8.156s
There is a symbol missing otherwise that is currently
only provided by the core, ie, non modular.
v4l2-core now supports enabling and disabling its own clock
on turning the camera on / off. We backport v4l2-core fully
so just backport the soc calls appropriately to let SOC cameras
to turn the clock on / off when the v4l2-core clock ops are
implemented on a device driver.
struct dmi_strmatch was modified on v3.11 with a
exact_match member. The DMI_EXACT_MATCH() macro was
added as a mod version of DMI_MATCH() to account for
dmi strings that look closely like each other. An
example is D510MO Vs D510MOV.
Since exact_match is is not available on older kernels
we can't use it and must revert to the old DMI_MATCH().
Addressing the desired behaviour will require a separate
change to deal with addressing the difference
in the behaviour.
Chris Wilson recommends that if we can't use this we should
also rever the DMI related fixes. I believe these are:
dcf6d294830d46b0e6901477fb4bf455281d90c8 - drm/i915: quirk away phantom LVDS on Intel's D525MW mainboard
e5614f0c2d0f4d7f0b8ef745d34593baf2c5dbf8 - drm/i915: quirk away phantom LVDS on Intel's D510MO mainboard
Once we get confirmation we can do that.
Proof of why we can't backport DMI_EXACT_MATCH():
member exact_match:
char substr[79];
Prior to 5017b285 we only had slot member so to use
DMI_EXACT_MATCH() with its intent we'd have to do something
like:
slot |= 1
if its called. This however assumes though that older code has
the sanity check as changed in 5017b285 on drivers/firmware/dmi_scan.c.
dmi_scan.o gets linked with CONFIG_DMI. At least for x86 that gets
objects sprinkled on arch/x86/, but more importantly CONFIG_DMI is
bool. I've argued how I envision us being able to backport core
components before (see 0935deab for the hint) but as it is right
now we can't. We only backport things we can throw in as modular.
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains 5017b285
v3.11-rc1~99^2~254
commit 5017b2851373ee15c7035151853bb1448800cae2
Author: Jani Nikula <jani.nikula@intel.com>
Date: Wed Jul 3 15:05:02 2013 -0700
dmi: add support for exact DMI matches in addition to substring matching
dmi_match() considers a substring match to be a successful match. This is
not always sufficient to distinguish between DMI data for different
systems. Add support for exact string matching using strcmp() in addition
to the substring matching using strstr().
The specific use case in the i915 driver is to allow us to use an exact
match for D510MO, without also incorrectly matching D510MOV:
.ident = "Intel D510MO",
.matches = {
DMI_MATCH(DMI_BOARD_VENDOR, "Intel"),
DMI_EXACT_MATCH(DMI_BOARD_NAME, "D510MO"),
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Cc: <annndddrr@gmail.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Cornel Panceac <cpanceac@gmail.com>
Cc: Greg KH <greg@kroah.com>
Cc: jani.nikula@intel.com
Cc: annndddrr@gmail.com
Cc: chris@chris-wilson.co.uk
Cc: cpanceac@gmail.com
Cc: daniel.vetter@ffwll.ch
Cc: greg@kroah.com
swiotlb_nr_tbl() was available since 3.2 but was exported since 3.3.
Since it uses an internal global state variable, it is impossible
to backport it to. Instead of reverting the changes added just
let this return 0 as the code will not do anything. This simplifies
the backport.
Since kernel version 3.3, workqueue names could be
sprintf'ed instead of just pointing to a name. This
wasn't used a lot so never needed to be backported,
but now it's used everywhere. Backport this API.
[mcgrof: add WQ_HIGHPRI and WQ_MEM_RECLAIM defines]
