1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ FAIL ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Upstream commit 981e0abc8a0b4a7d0327007ef455762efc92bcc0
bpreqs.py assumes the max rc level is 20. However,
backports currently requires coccinelle 1.0.0-rc24
(which is the latest rc before 1.0.0).
This resulted in 1.0.0-rc24 getting higher weight
than 1.0.0, which failed the dependency check.
Fix it by increasing the max rc to 25 (and use
a constant for it)
Signed-off-by: Eliad Peller <eliad@wizery.com>
Upstream commit 9828be04a3f49d5b64eefe1dd17b33fde1ebfba2
This change is only needed for kernel 4.1 and later and not for 4.0.
This reverts commit 1adc4bb782a411b29f4f6ddc9b3ddbe081b7bacb.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.106 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.73 [ OK ]
12 3.11.10 [ OK ]
13 3.12.39 [ OK ]
14 3.13.11 [ OK ]
15 3.14.37 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.10 [ OK ]
20 3.19.3 [ OK ]
21 4.0-rc6 [ OK ]
manual changes done to:
patches/collateral-evolutions/network/0020-tty-termios/drivers_bluetooth_hci_ath.patch
- removed
patches/collateral-evolutions/media/0002-no_dmabuf/v4l2.patch
- handled added CONFIG_HAS_DMA
vb2_ioctl_expbuf() was patched out in backports, but it was still used
in some drivers. This patch removes also the references to that missing
function.
The patch patches/collateral-evolutions/network/0050-iov_iter
/bluetooth.patch added memcpy_fromiovec unconditionally, but
memcpy_fromiovec() is not available in kernel 4.0 any more. This patch
adds the backport code only for older kernel versions.
drivers/net/wireless/ath/ath10k/htt.h uses "struct idr" since commit
89d6d83. This stricture does not get included on kernel 3.0. This adds
the missing include.
The DVB_RTL2830 and DVB_RTL2832 driver are using the new regmap API
since commit b410dae and d101658 which we did not backport. Deactivate
this driver on affected kernel versions for now. In addition the
DVB_USB_RTL28XXU driver has to be deactivated because it depends on
these two modules.
drivers/nfc/pn544/i2c.c includes linux/gpio/consumer.h since commit
0a5942c8, which we can not backport. Deactivate this driver on affected
wait_on_bit_timeout() is only supported with kernel >= 3.17 in
backports. On older kernel versions we go back to the old
implementation. The new implementation was introduced in commits:
a087a98, fad7097 and 129a769.
Some bluetooth code makes use of wait_on_bit_timeout() now. This
function was introduced in commit 44fc0e5. It was only possible to
backport this to kernel >= 3.17. This function makes use of a new
member in struct wait_bit_key which was added with kernel 3.17.
In commit 817bd72 the dma_buf_export() function signature changed
from getting a long list of parameters to just getting a structure
with all the parameters in it. This patch adds a function which
translates from the new signature to the old function signature. This
function now also handles the different versions of dma_buf_export()
used in different kernel versions.
This file was removed from the kernel in commit 32d17597.
This has been in the kernel for a long time, but wasn't
used by anyone. Now it's used by rhashtable, so add it.
This was added to list_nulls.h fairly recently in commit f89bd6f87a53.
These were added upstream a long time ago in commit 685343fc3ba61,
but not needed until implemented in the wireless stack recently.
Last ath10k makes use of hash tables, which changed in the upstream
commit:
* commit 0bbacca7c3911451cea923b0ad6389d58e3d9ce9
* Author: Sasha Levin <sasha.levin@oracle.com>
* Date: Thu Feb 7 12:32:18 2013 +1100
* hlist: drop the node parameter from iterators
The list portion of this commit has already been backported, but the
hashtable part has not. So this change evens it up. It fixes a build
issue when selecting ath10k on a kernel before 3.9
Signed-off-by: Mathieu Olivari <mathieu@qca.qualcomm.com>
Adjust the kernel version parsing and list of backport files
generation for 4.x kernels.
Signed-off-by: Luciano Coelho <luciano.coelho@intel.com>
The messages are only printed if something fails anyway, so
better ask for verbose messages to be able to better identify
what failed.
In mac80211-next a call to get_net_ns_by_fd() has been added in cfg80211
which resides in networking core. This function has been backported
such that it will always fail, ie. as it would when CONFIG_NET_NS
is not defined. The call was added by:
commit 4b681c82d2f9bef121c912ffcaac89a004af3f2c
Author: Vadim Kochan <vadim4j@gmail.com>
Date: Mon Jan 12 16:34:05 2015 +0200
nl80211: Allow set network namespace by fd
Signed-off-by: Arend van Spriel <arend@broadcom.com>
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.67 [ OK ]
4 3.3.8 [ OK ]
5 3.4.106 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.69 [ OK ]
12 3.11.10 [ OK ]
13 3.12.38 [ OK ]
14 3.13.11 [ OK ]
15 3.14.33 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.7 [ OK ]
20 3.19.0 [ OK ]
manual changes do to:
patches/collateral-evolutions/network/0049-no-pfmemalloc/igb.patch
In kernel 3.0 the function prototype is only present when CONFIG_OF is
selected, if that is not selected the prototype is not there. This adds
an empty implementation for that case.
Programmable pins were introduced in the ptp subsystem in kernel 3.15
and igb makes use of them now. These patches are removing the code
accessing these new functions.
These patches are needed for every kernel which does not have this
commit:
commit 6092315dfdec5185881605d15a0e200d6e90eb66
Author: Richard Cochran <richardcochran@gmail.com>
Date: Thu Mar 20 22:21:52 2014 +0100
ptp: introduce programmable pins.
CC: Stefan Assmann <sassmann@kpanic.de>
These macros are used by some Ethernet drivers now.
This function is needed by some media driver.
This was introduced on kernel version 3.1, so a kernel (3.0) without
it is still just within the support window. Define this constant if
it isn't defined.
[Move the code to backport/backport-include/linux/netdevice.h, it is
placed there in recent kernel version]
The tx_flags haven't been a union since 2.6.37, so since we
no longer support that kernel the '&' operation will now be
possible on all supported kernels. Use that fact to get rid
of the patch by defining SKBTX_WIFI_STATUS to 0 so the code
also disappears, but doesn't have to be patched.
While at it, clean up a double #if.
nl80211.c recently changed using defined strings instead of hard-coded in
multi-cast group definitions:
commit 71b836eca7f380fbd4c025f8c4371f9a071bc909
Author: Johannes Berg <johannes.berg@intel.com>
Date: Tue Dec 23 17:17:38 2014 +0100
nl80211: define multicast group names in header
Changed the version number in the file header comment.
hwmon group registration functions have been added in 3.13 kernel.
Latest ath10k patches make use of this mechanism, therefore the
need for the backport.
[do not dereference hwdev before giving to dev_set_drvdata]
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.65 [ OK ]
4 3.3.8 [ OK ]
5 3.4.105 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.63 [ OK ]
12 3.11.10 [ OK ]
13 3.12.35 [ OK ]
14 3.13.11 [ OK ]
15 3.14.27 [ OK ]
16 3.15.10 [ OK ]
17 3.16.6 [ OK ]
18 3.17.7 [ OK ]
19 3.18.1 [ OK ]
20 3.19-rc1 [ OK ]
This header is needed by some media drivers. It is safe to copy this
file, because it does not contains any header for an interface to other
kernel subsystems or drivers, but only consonants defined in the HDMI
standard.
This file was newly added to the kernel. It was extracted from
linux/clocksource.h.
string.h is usually included from the asm/ folder in most configuration,
but on some older kernels and non-x86 architecture, this inclusion is
not necessarily happening. As we're using memcpy() in the code
below, we need to be safe and make sure string.h is indeed there.
This issue has been observed on a 3.4 vendor kernels, but may be
applicable to other configurations.
This patches was merged upstream
The wakeup_path member was added in kernel 3.2, just ignore this on
older kernel versions. This will break WoL in b44 with these old kernel
versions.
usage of the new iov_iter api was added in the following patches:
commit 17836394e578b8d6475ecdb309ad1356bbcf37a2
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Mon Nov 24 17:07:38 2014 -0500
first fruits - kill l2cap ->memcpy_fromiovec()
commit c0371da6047abd261bc483c744dbc7d81a116172
Date: Mon Nov 24 10:42:55 2014 -0500
put iov_iter into msghdr
commit 56c39fb67cdb665ae67fba4975f5e20e6614cda6
Date: Mon Nov 24 16:44:09 2014 -0500
switch l2cap ->memcpy_fromiovec() to msghdr
I haven't found a way to backport this, so this is mostly a revert of
these upstream commits to make bluetooth use the old APIs on older
kernel versions.
dma_rmb() is added twice, because most architectures do not include
asm-generic/barrier.h, but only asm/barrier.h. This should work with
all architectures.
dma_rmb() is used by the igb driver.
eth_skb_pad() is used by the igb driver.
skb_put_padto() is used by the igb driver.
napi_alloc_skb() is now used by some Ethernet drivers instead of
netdev_alloc_skb_ip_align(). It can not be placed into backport-
include/linux/skbuff.h because it accesses a member of struct
napi_struct which is not possible in skbuff.h, placing it into
netdevice.h worked in my tests.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.65 [ OK ]
4 3.3.8 [ OK ]
5 3.4.105 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.63 [ OK ]
12 3.11.10 [ OK ]
13 3.12.35 [ OK ]
14 3.13.11 [ OK ]
15 3.14.27 [ OK ]
16 3.15.10 [ OK ]
17 3.16.6 [ OK ]
18 3.17.7 [ OK ]
19 3.18.1 [ OK ]
manual changed were needed for the following patches:
backport-adjustments/crypto-ccm.patch
backport-adjustments/devcoredump.patch
DMA_ATTR_SKIP_CPU_SYNC was added to the enum with kernel 3.6. This
patch removes all calls to dma_set_attr() with this value on
kernel < 3.6.
