path: root/Makefile
2009-05-18add a depmod check -- check for updates/ preferenceLuis R. Rodriguez
If your distribution lacks an /etc/depmod.d/ or /etc/depmod.conf file we'll add one for you. By default we add the file in /etc/depmod.d/compat-wireless.conf We could get more granular and only add this preference for wireless stuff but that requires some work. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
2009-04-16Reflect changes in wireless-testing.Hauke Mehrtens
* Change the location of ath5k, ath9k and ar9170. * modify some scripts to work with recent version of wireless-testing. * ath9k will be loaded if madwifi is deactivated. * Broadcoms wl.ko will be deactivated if b43 or b43legacy are loaded. * Many modules were added or chanced their name in the last months. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2009-02-19compat.diff update for master-2009-02-18Hauke Mehrtens
Revert commit 65949939dd23bcde83dc0fa56dd5932eda38c050: "nl80211: lock rtnl around all operation" from wireless-testing for kernels older than 2.6.30. This also adds at76c50x-usb driver and accounts for the move of include/net/ieee80211.h to its ipw home where it belongs. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2009-02-06Do not call 'make modules' again when doing 'make install'Luis R. Rodriguez
This should increase the speed of a make install. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
2009-02-06Add support for compressed modules (Mandriva Linux uses this)Luis R. Rodriguez
2009-01-29Update: eeprom_93cx6 changed directoryHauke Mehrtens
2008-11-20New dir for Intel Centrino/minstrel is defaultHauke Mehrtens
- Intel Centrino wireless (ipw2100, ipw2200) drivers get new directory - Old Intel ieee80211 framework replaced by lib80211 and LIBIPW - minstrel is default default rate control algorithm now as it is now in the wireless-testing tree - removed some unused config symbols Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
2008-11-11Ship libertas_tf_usbLuis R. Rodriguez
Ship libertas_tf_usb but only compile it if the distribution said so. We don't handle the case yet where the user wants to replace usb8xxx with libertas_tf_usb. We need a script for that, patches are welcomed. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
2008-11-11Add iwl-load, and make sure we disable iwl4965 upon installLuis R. Rodriguez
We now has two drivers for different kernel releases for the Intel 4965 device. To account for this we add a script to allow us to disable and enable one or each other. By default we disable iwl4965 as we are replacing it with iwlagn. If you want to enable iwl4965: iwl-load iwl4965 If you want to enable iwlagn: iwl-load iwlagn By default we'll use iwlagn. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
2008-11-03b44 is dependent on ssb.Tim Gardner
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
2008-10-27Update compat.diff to reflect new changes on wireless-testingLuis R. Rodriguez
Adds new lib80211. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
2008-09-02Start of new compat-wireless git tree for kernels >= 2.6.27Luis R. Rodriguez
For older kernels please see compat-wireless-2.6-old.git. We split because of the new TX Multiqueue changes introduced which were difficult to backport. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
