Some drivers now also call the other dev_*_ratelimited() functions.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
This definition may exists on non-vanilla kernels.
Signed-off-by: Jonathan DE CESCO <jonathan.de.cesco@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Since support for kernels < 3.0 was removed, there's now a bunch
of dead code that can be removed - do it.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Avoid conflicts with RHEL7.0 as DEVICE_ATTR_* defines,
enum pkt_hash_types, skb_set_hash(), dma_common_get_sgtable()
are already present.
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean
/home/mcgrof/linux-next /home/mcgrof/build/next-20140409
Copy original source files ...
Apply patches ...
Modify Kconfig tree ...
Rewrite Makefiles and Kconfig files ...
Done!
real 1m30.186s
user 9m25.180s
sys 0m24.428s
mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.54 [ OK ]
4 3.3.8 [ OK ]
5 3.4.79 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.29 [ OK ]
12 3.11.10 [ OK ]
13 3.12.10 [ OK ]
14 3.13.2 [ OK ]
15 3.14-rc1 [ OK ]
real 26m54.859s
user 744m15.764s
sys 83m47.440s
Some old custom kernels have it defined.
Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com>
This is needed by drivers/regulator/fixed.c
net/bluetooth/hci_sysfs.c uses ATTRIBUTE_GROUPS on all kernel versions.
Now it has to be for older kernel versions as well and
__ATTRIBUTE_GROUPS is also needed for these old versions.
devm_kmalloc() was added in kernel 3.13. To backport it we replace the
calls with devm_kzalloc() instead.
This fixes lots of compile problems on RHEL 6.5.
In some places backports checked for the kernel version on weather to
add a own define for module_driver or not. This patch makes it check if
there is already one or not.
In struct class the new sysfs dev_groups member was added with kernel
3.11, but in other structs, like struct bus_type the new member was
added with kernel 3.12. This backport is now needed on different kernel
versions depending on the struct where is was used.
With this patch ATTRIBUTE_GROUPS() will always be used with the new API
and ATTRIBUTE_GROUPS_BACKPORT() will always be used used with the old
API and the patch has to add a KERNEL_VERSION check to add the correct
macro.
This adds dev_get_platdata() function.
This is used by drivers/media/v4l2-core/v4l2-dev.c.
By requiring 2.6.25 we can get rid of quite a lot of backport work.
2.6.25 was released more than five years ago (April 2011) and wasn't
a long-term kernel either, so there's little point in supporting it
now.
This was causing conflicts again when updating against
wireless-next, so instead of adjusting the patches just
provide a proper static inline backport.
Older kernel versions do not support the new sysfs api with dev_groups.
This makes net/wireless/sysfs.c use the old api on older kernels.
This is a backport of this commit:
commit f0bc99c84349ce87af5b35839d19bfb17bb9b27f
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Date: Wed Jul 24 15:05:35 2013 -0700
net: wireless: convert class code to use dev_groups
This was mostly done by Johannes Berg <johannes@sipsolutions.net>.
Cc: Johannes Berg <johannes@sipsolutions.net>
The new macro, introduced by
commit 9f5876fa9cfb8cd6f450c200043ca7e31915f976
Author: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Date: Thu Jul 18 16:40:55 2013 -0700
backports: backport drvdata = NULL core driver fixes
evaluates its argument multiple times, causing crashes as
there are potential side-effects of the called code and/or
the arguments.
Fix this by converting it to static inlines.
Also remove the driver_probe_device() macro that has the
same issue, but tries to wrap a function that isn't even
available outside the driver core code in any kernel.
The Linux kernel had tons of code which at times cleared the
drvdata upon probe failure or release. There are however a bunch
of drivers that didn't clear this.
Commit 0998d063 implmented clearing this upon device_release_driver()
and dealt with probe failure on driver_probe_device(). After this the
kernel was cleaned up separately with *tons* of patches to remove all
these driver specific settings given that the clearing is now done
internally by the device core.
Instead of ifdef'ing code back in for older code where it was properly
in place backport this by piggy backing the new required code upon the
calls used in place. There is a small race here upon device_release_driver()
but we can live with that theoretical race.
Due to the way we hack this backport we can't use a separate namespace
as we have with other symbols.
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains \
0998d0631001288a5974afc0b2a5f568bcdecb4d
v3.6-rc1~99^2~14^2~17
I count 65 patches implemented after this:
mcgrof@frijol ~/linux-stable (git::master)$ git format-patch \
--grep="device-core: Ensure drvdata = NULL when no driver is bound" \
-o null-drv-fix v3.6-rc1~99^2~14^2~17..
TL;DR
Alan Stern argued that perhaps applying this to backports wasn't a good
idea given that evidence shows that the original patch actually exposed
tons of bugs in driver code where they were doing the wrong thing.
While this may be true if the original patch was a bad idea it should
be reverted, and if a bug is found upstream, then by all means
finding it through backports will only accelerate the pace at which
we fix these exposed bugs. That is, if a bug is found due to this on
backports then a respective fix for it should go upstream, not to
backports. This is the benefit of providing backports releases: keep
your users engaged on upstream fixes.
Furthermore I am in hopes that perhaps we can SmPL'ify the bugs
instead and in the future perhaps require SmPL to proove that
the what the original patch was doing won't affect the inverse
of what the patch was trying to do -- that is drivers doing the
wrong thing.
commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
Author: Hans de Goede <hdegoede@redhat.com>
Date: Wed May 23 00:09:34 2012 +0200
1) drvdata is for a driver to store a pointer to driver specific data
2) If no driver is bound, there is no driver specific data associated with
the device
3) Thus logically drvdata should be NULL if no driver is bound.
But many drivers don't clear drvdata on device_release, or set drvdata
early on in probe and leave it set on probe error. Both of which results
in a dangling pointer in drvdata.
This patch enforce for drvdata to be NULL after device_release or on probe
failure.
Tested with ckmake against next-20130618:
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
real 32m2.332s
user 860m23.688s
sys 121m20.840s
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Julia Lawall <julia.lawall@lip6.fr>
Cc: linux-usb@vger.kernel.org
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Felix Fietkau <nbd@openwrt.org>
Also type of the 3 parameter of class_find_device() changed from void *
to const void *, add a cast to prevent a warning.
Instead of patching, make a macro that casts the const out
from the function pointer arguments to avoid the warning.
This may not be the right thing to do, but it resolves
linking the TI driver on 2.6.36 where pm_wakeup_event()
is declared but not always exported.
Move everything into the appropriate header files.
Also include uidgid.h into the new fs.h since kernels
that had uidgid.h include it already, so it doesn't
change anything there, but those that don't have it
obviously can't have included it and people rely on
it behing included there.
