This reverts commit 1b4e6ad4d927c7998fa578f2d29e0c4ec01a9217.
Said commit broke b43 on older kernels (<3.16).
I am not aware of any user of the NFC coded in backports, at least I
haven't seen any patches regarding this. Remove this code to reduce the
efforts needed in the backports project.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Use the versions shipped with the kernel instead.
bcma and ssb didn't change much in the last few years, most of the
changes were related to code only used on embedded devices. Removing
this reduces the number of parts we have to backport. b43, b43legacy and
brcmsmac work well with the in kernel version.
With 802.15.4 code removed, CPTCFG_IEEE802154_6LOWPAN can be inherited
from the base kernel and thus cause problems - remove it all.
BCMA GPIO driver now relies on functionality that is available
since v4.5. Just drop GPIO which disables brcmsmac led functionality
so it can be backported to kernels prior to 4.5.
Signed-off-by: Arend van Spriel <arend@broadcom.com>
This adds the new driver CPTCFG_RTL8XXXU and removes the config option
for CPTCFG_B43_PCMCIA. pcmcia support in b43 is now done in ssb.
This removes the old driver IEEE802154_FAKEHARD and adds two new
drivers.
This wifi driver was missing before.
This driver uses the cfg80211 so we should ship it.
In 3.17 kernel the brcmfmac supports PCIe host interface. So enable
support when selecting defconfig-brcmfmac.
It looks like no one is using the regulator drivers and maintaining
them costs some time because they often break. When someone needs
a specific driver please send a patch adding this one specific driver,
maintaining a small subset is not a problem, but maintaining all is a
big task.
This adds Redpine Signals Inc 91x WLAN driver support
Set the default option to module.
Remove some config options which were not available in the kernel any
more and add some missing new options.
This symbol is obsolete, it was removed upstream, so just
remove it from the defconfig file as well.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
This can be useful for pure testing scenarios.
Add defconfig and necessary files to copy-list.
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
Signed-off-by: Jason Mobarak <jam@cozybit.com>
Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com>
This adds ath10k, wcn36xx and rt3573 to the default wifi config.
Maintaining the DRM driver takes a lot of recourses as there they are
depending on many API changes done to the core kernel code and
currently we do not have that many recourses to follow them. On the
other side one needs also new userspace drivers to make use of the new
features added to the DRM kernel drivers and it is not easy to update
the X drivers. Therefore we came to the conclusion to remove the drm
drivers for now.
There were also some problems with some DRM drivers, like the Intel
i915 driver caused kernel panic on some systems and was probably only
usable on some very recent kernel versions.
Signed-off-by: Patrick Ziegler <patrick.ziegler@fh-kl.de>
This adds the ieee802154 subsystem.
== ckmake-report.log ==
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
This default config contains all wifi drivers.
This adds default configs for Atheros wifi drivers.
Without wext support we will get lots of complains about iwconfig
not working.
This adds a default config for the broadcom wifi drivers.
This adds backport support for all media subsystem
drivers. This is enabled only for >= 3.2. Some media
drivers rely on the new probe deferrral mechanism
(-EPROBE_DEFER see commit d1c3414c), those are only
enabled for kernels >= 3.4. Some media drivers only
depend on the regulatory but since we only support
backporting the regulatory on kernels >= 3.4 we only
enable those media drivers for >= 3.4.
This backports 433 media drivers.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.65 [ OK ]
18 3.1.10 [ OK ]
19 3.2.38 [ OK ]
20 3.3.8 [ OK ]
21 3.4.32 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.9 [ OK ]
25 3.8.0 [ OK ]
26 3.9-rc1 [ OK ]
real 39m35.615s
user 1068m47.428s
sys 155m55.657s
Cc: linux-media@vger.kernel.org
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
This backports the latest regulator drivers for kernels >= 3.4.
We enable the regulator only on kernels >= 3.4 given that
it relies on the new probe deferral mechanism which would
otherwise mean having to support drivers that do not probe
correctly. Note that 3.2 had a base regulator implementation
but that was just stubs.
I did look into a way to upgrade the core kernel regulator
but given that it relies on late_initcall() and core_initcall()
we can't update this part of the kernel. I even looked at
using ksplice for this but it seems ksplice can't be used to
update init sections on the vmlinux ELF. I also haven't much
updates to these routines since 3.4 except for 86f5fcfc.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.65 [ OK ]
18 3.1.10 [ OK ]
19 3.2.38 [ OK ]
20 3.3.8 [ OK ]
21 3.4.32 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.9 [ OK ]
25 3.8.0 [ OK ]
26 3.9-rc1 [ OK ]
real 39m35.615s
user 1068m47.428s
sys 155m55.657s
Cc: Liam Girdwood <lgirdwood@gmail.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Thierry Escande <thierry.escande@linux.intel.com>
This was previously not really enabled because it wasn't
in the Makefile.kernel, add it there. Also add a defconfig
file for all DRM drivers.
This passes ckmake --defconfig drm:
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.65 [ OK ]
18 3.1.10 [ OK ]
19 3.2.38 [ OK ]
20 3.3.8 [ OK ]
21 3.4.32 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.9 [ OK ]
25 3.8.0 [ OK ]
26 3.9-rc1 [ OK ]
This enables users to more easily select the driver that
they need, and us to ship default configurations that we
prefer for that driver. Add iwlwifi as the first example.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
