path: root/backport
2015-08-03header: add of_platform_populate()Hauke Mehrtens
of_platform_populate() is not added when CONFIG_OF_DEVICE is not set on kernel < 3.4. The same is true for of_default_bus_match_table on kernel < 3.11. we do not need to provide a real implementation of of_default_bus_match_table because it will be accessed. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-08-03header: adapt change of parameter in {add,sub}_frag_mem_limit()Hauke Mehrtens
In older kernel versions the first parameter is "struct inet_frag_queue *q", now it is "struct netns_frags *nf", This patch adds the new versions of this function to all kernel versions older than 4.3. This change was done in upstream Linux kernel in this commit: commit 0e60d245a0be7fdbb723607f1d6621007916b252 Author: Florian Westphal <fw@strlen.de> Date: Thu Jul 23 12:05:38 2015 +0200 inet: frag: change *_frag_mem_limit functions to take netns_frags as argument Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-08-03backports: add seq_hex_dump()Hauke Mehrtens
seq_hex_dump() is needed by the wil6210 driver and was added in this commit: commit 96e6df4cfc6ecf91097eb8eec55983a5f102a477 Author: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Date: Fri Jul 24 09:11:53 2015 +1000 seq_file: provide an analogue of print_hex_dump() Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-08-03backports: add hex_dump_to_buffer() with int return valueHauke Mehrtens
In the kernel hex_dump_to_buffer() got an int return value, returning the amount of bytes written into the buffer. This new return value is needed by seq_hex_dump() which we also backport. This change was done in the following commit in mainline Linux kernel: commit 114fc1afb2de7dec40da137dc2a55cd38fc220f2 Author: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Date: Thu Feb 12 15:02:29 2015 -0800 hexdump: make it return number of bytes placed in buffer Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-08-03backports: do not add debugfs_create_devm_seqfile() on recent kernel versionsHauke Mehrtens
An ifdef for the kernel version was missing around the header of debugfs_create_devm_seqfile() and the LINUX_BACKPORT() was also not added. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-28backport: add frame vector codeHauke Mehrtens
The media framework now uses the frame vector code which is only available from kernel 4.2 onwards. This backports the code. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-28backport: add get_user_pages_{locked,unlocked}()Hauke Mehrtens
The get_user_pages_locked() function is needed by the frame vector code which will be added in the next patch. While adding that, this patch also replaces the get_user_pages_unlocked() function with the original version from the next kernel. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-28header: add led_trigger_remove() prototpyeHauke Mehrtens
The led_trigger_remove() function is exported on older kernel versions, but there is no pubic prototype for this function. Now the first driver makes use of this function and this patch adds the prototype. There is no LINUX_BACKPORT() guard here because we want it to point to the original function which is exported normally. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-28header: add N_NCIHauke Mehrtens
It should be save to just copy it. This was added in this upstream commit: commit 9961127d4bce6325e9a0b0fb105e0c85a6c62cb7 Author: Vincent Cuissard <cuissard@marvell.com> Date: Thu Jun 11 11:25:47 2015 +0200 NFC: nci: add generic uart support Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-28header: remove kparam_{block,unblock}_sysfs_write()Hauke Mehrtens
This is not used by any code in backports and was also removed from the mainline kernel. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-28header: add kernel_param_{lock,unlock}() functionsHauke Mehrtens
In the mainline kernel the kernel module parameter locking is not protected by a global lock any more, but each module has its own lock now. This resulted in some changes in the api. This patch converts calls to the new api to the old one. This backports the changes done in this commit: commit b51d23e4e9fea6f264d39535c2a62d1f51e7ccc3 Author: Dan Streetman <ddstreet@ieee.org> Date: Wed Jun 17 06:18:52 2015 +0930 module: add per-module param_lock Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-28header: rename duplicate include guardHauke Mehrtens
The same include guard is also used in backport/backport-include /asm-generic/barrier.h which prevents both files from being included at the same time. Reported-by: Martin Tippmann <martin.tippmann@gmail.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-28headers: add missing include statementFlorian Grandel
The net/route.h header is missing when compiling against the android msm kernel. Explicitly add it here to make the kernel compile. Signed-off-by: Florian Grandel <fgrandel@gmail.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-16header: fix warning in lockdep_assert_held()backports-20150612Hauke Mehrtens
When building the kernel there are lots of warnings like this: drivers/net/wireless/ath/ath10k/ce.c:404:21: warning: unused variable ‘ar_pci’ [-Wunused-variable] struct ath10k_pci *ar_pci = ath10k_pci_priv(ar); They are caused by an empty lockdep_assert_held() which does nothing with this variable in kernel version < 3.9. This patch replaces this macro with the version from a recent kernel and silence this warning. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15backports: add mediatek mt7601u driverHauke Mehrtens
2015-06-15header: add devm_kcalloc()Hauke Mehrtens
This is needed by the mt7601u driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15header: add dev_dbg_once() and othersHauke Mehrtens
The mt7601u driver makes use of some of these functions and they are not available on kernel version < 3.19. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15backports: add tty_set_termios()Hauke Mehrtens
tty_set_termios() was not exported any more in kernel 4.0-rc1 (commit 632f32e21) and exported again in kernel 4.1-rc2 (commit b00f5c2dc). This patch adds the backport for kernel 4.0.X, we can not detect kernel 4.1-rc1, which would also need this fix, so bluetooth will have a compile error on kernel 4.1-rc1, kernel 4.1-rc2 and more recent versions will work. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15backports: add HDMI driverHauke Mehrtens
Before we only copied the hdmi.h header file and not the driver. Now some other drivers need the hdmi driver code, also copy it now too. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15backports: add backport for new AEAD crypto APIHauke Mehrtens
mac80211 makes use of the new AEAD crypto api since commit 957e0fe629. This patch provides a backport layer which converts the new API to the old one used in older kernel versions. This backport is based on this mainline commit: 996d98d85. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: Johannes Berg <johannes.berg@intel.com>
2015-06-15header: fix rt6_nexthop() backportHauke Mehrtens
rt6_nexthop() got an additional parameter in commit 2647a9b0. Instead of only backporting it for kernel < 3.10 do it now for kernel version < 4.2. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-09backports: include: introduce backport for ACPI_COMPANION() macroArend van Spriel
The brcmfmac driver now uses the ACPI_COMPANION() macro which was introduced in v3.13 kernel. This provides a backport of that macro for older kernels. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-06-09backports: add missing include for vfreeJonathan Liu
Signed-off-by: Jonathan Liu <net147@gmail.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-05-25header: handler new parameter net in sock_create_kern()Hauke Mehrtens
Linux commit eeb1bd5c4 added a new parameter to sock_create_kern(). In the original function it was replaced with &init_net every time, now it is taken from the parameter. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-25header: remove last parameter from sk_alloc()Hauke Mehrtens
Linux commit 11aa9c28 added a new parameter to sk_alloc() which is not available on older kernel versions. Just ignore it on these older versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-25header: do not backport wait functions on kernel >= 3.18.12Hauke Mehrtens
This feature was backported to kernel 3.18.12 and we should not activate it on these kernel versions any more. Reported-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-25backport: allow compilation with Ubuntu's 3.13Emmanuel Grumbach
Canonical backported: Author: Or Gerlitz <ogerlitz@mellanox.com> Date: Mon Jan 20 13:59:19 2014 +0200 net: Add GRO support for UDP encapsulating protocols This is commit 2da204a8f67fbe25816cbce8cc8551f03d5b951a in their tree. Cope with that. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> [changed bool, it should be build when the kernel version is != 3.13.11] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-11header: add dummy add_device_randomness()Hauke Mehrtens
add_device_randomness() is now used by ath9k. This function was introduced in commit a2080a67abe9 , and then backported to many stable kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-11header: add possible_{write,read}_pnet() on kernel >= 4.1Hauke Mehrtens
backports only adds the possible_{write,read}_pnet() functions for kernel < 4.1. This results in a compile error on kernel 4.1. This patch make it use the original functions on these kernel versions. This fixes a problem introduced in 3d418885971. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-05-11backports: handle netdev->tstatsJohannes Berg
This adds the necessary backporting to handle netdev->tstats which was introduced in 3.14 (and some helper macros in 3.15). For some reason my spatch isn't reliably patching the occurrence in net/mac80211/tx.c, so for now I'm including a manual patch. Change-Id: Ib22e307a9bd31f6c31372ef8cc2828ca6e14fce4 Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-11backports: include missing device.hJohannes Berg
debugfs.h needs device.h, otherwise you get a warning backport-include/linux/debugfs.h:11:10: warning: ‘struct device’ declared inside parameter list Change-Id: Ic669c855d47a8114649d1d319fcb1bcdc024415c Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-26header: add clk_prepare_enable() and clk_disable_unprepare()Hauke Mehrtens
These functions are used by some media drivers since 4f528afc. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-26header: add TRACE_DEFINE_ENUM define for v4l2Hauke Mehrtens
v4l2 makes use of TRACE_DEFINE_ENUM. This was introduced in 0c564a538 and is not supported in older kernel versions, implement it empty. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-26header: add IS_REACHABLE()Hauke Mehrtens
This was introduced in commit 9b174527e and is used by the media drivers. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-25header: do not use genl backport on RHEL 7.0Hauke Mehrtens
The genl changes were backported to RHEL 7.0 Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-25header: add LINUX_BACKPORT() macro to reinit_completion()Hauke Mehrtens
This fixes compalation on RHEL 7.1 Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-25header: lockdep_assert_held is already in kernel 3.0Hauke Mehrtens
This backport is not needed because it is already provided by all supported kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-25header: add module_pnp_driver()Hauke Mehrtens
This macro is used by some media drivers and was added to the kernel in commit 95c0fd457. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-25header: add DIV_ROUND_CLOSEST_ULLHauke Mehrtens
This adds the DIV_ROUND_CLOSEST_ULL macro which was added to the kernel in 350f28a7a. In addition this patch fixes some problems in the DIV_ROUND_CLOSEST macro. Both are copied from the kernel. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-25backports: deal with struct timespec64 changesStefan Assmann
In kernel 3.17 struct timespec64 was introduced. commit 361a3bf00582469877f8d18ff20f1efa6b781274 Author: John Stultz <john.stultz@linaro.org> Date: Wed Jul 16 21:03:58 2014 +0000 time64: Add time64.h header and define struct timespec64 git describe --contains 361a3bf00582469877f8d18ff20f1efa6b781274 v3.17-rc1~109^2~62 Deal with the required changes via defines. Signed-off-by: Stefan Assmann <sassmann@kpanic.de> [Moved defines into the same header files as in mailine kernel, removed some ktime_*] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-25backports: add passthru_features_check()Stefan Assmann
This is required by igb and possibly other network drivers. Signed-off-by: Stefan Assmann <sassmann@kpanic.de> [change to EXPORT_SYMBOL_GPL] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-22backports: deal better with possible_net_tEmmanuel Grumbach
Instead of just assuming CONFIG_NET_NS is defined, deal with this better. Sadly, it needs a header file patch (as an spatch doesn't deal properly with header files.) Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-06backports: add USB ZD1201 driverHauke Mehrtens
This wifi driver was missing before. This driver uses the cfg80211 so we should ship it. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-06backports: add Atmel at76c50x PCI and PCMCIA driverHauke Mehrtens
2015-04-06backports: add Cisco/Aironet (AIRO) driverHauke Mehrtens
2015-04-06headers: add sock_skb_cb_check_size()Hauke Mehrtens
The bluetooth code needs this function. It was introduced in upstream commit b4772ef87. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-05backports: backport recent wext changeJohannes Berg
backport the commit 36ef906ee8fefbfac3844206e66d8450e6221c69 ("wext: add checked wrappers for adding events/points to streams") Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-05backport-include: map possible_net_t to struct net *Arend van Spriel
commit 0c5c9fb55106 (net: Introduce possible_net_t) changed use of write_pnet and read_pnet. This patch will map possible_net_t back to struct net * to use old api. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-05backports: backport netlink IP/IPv6 address accessorsJohannes Berg
These were introduced upstream in commits 67b61f6c130a and 930345ea6304. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-05backports: include rhashtableJohannes Berg
As mac80211 now needs rhashtable, include it in backports. For now, it actually depends on mac80211 and is selected for kernels < 4.1 -- it existed in previous kernels but with different API, so cannot be used from there easily. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
