Catch running make in the backport template directory by
checking for the .local-symbols file. If it isn't there
then we're in the input/template directory rather than in
an output tree, give the user a hint about it instead of
keeling over.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Having the kconfig code in a directory called "kconfig"
and having a file called "Kconfig" causes issues if the
code is ever stored on a case-insensitive filesystem.
Avoid these by just calling the kconfig directory kconf
instead.
I failed to see v2 patch.
This reverts commit 7f1b4e0258ade60670cf60f2bd46996005843cea.
instead.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
This adds vm_iomap_memory() from:
commit b4cbb197c7e7a68dbad0d491242e3ca67420c13e
Author: Linus Torvalds <torvalds@linux-foundation.org>
Date: Tue Apr 16 13:45:37 2013 -0700
vm: add vm_iomap_memory() helper function
Without wext support we will get lots of complains about iwconfig
not working.
This adds a default config for the broadcom wifi drivers.
The kernel 3.10 already includes the new versions.
Using openSUSE 12.3 with x86_64 architecture, the 'make menuconfig'
command results in the following:
finger@larrylap:~/backports-3.10-rc1-1> make menuconfig
cc -Wl,--no-as-needed -lncurses mconf.o zconf.tab.o lxdialog/checklist.o lxdialog/inputbox.o lxdialog/menubox.o lxdialog/textbox.o lxdialog/util.o lxdialog/yesno.o -o mconf
/usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: /lib64/libncurses.so.5: undefined reference to symbol 'acs_map'
/usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: note: 'acs_map' is defined in DSO /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../lib64/libtinfo.so so try adding it to the linker command line
/usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../lib64/libtinfo.so: could not read symbols: Invalid operation
collect2: error: ld returned 1 exit status
make[2]: *** [mconf] Error 1
make[1]: *** [menuconfig] Error 2
make: *** [menuconfig] Error 2
When "-ltinfo" is added to the LDFLAGS symbol as suggested by the linker,
it builds and runs correctly.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 17m9.368s
user 403m46.554s
sys 95m42.811s
[mcgrof: tested with ckmake]
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains 271a15ea
v3.10-rc1~129^2~24
commit 271a15eabe094538d958dc68ccfc9c36b699247a
Author: David Howells <dhowells@redhat.com>
Date: Fri Apr 12 00:38:51 2013 +0100
proc: Supply PDE attribute setting accessor functions
Supply accessor functions to set attributes in proc_dir_entry structs.
The following are supplied: proc_set_size() and proc_set_user().
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
cc: linuxppc-dev@lists.ozlabs.org
cc: linux-media@vger.kernel.org
cc: netdev@vger.kernel.org
cc: linux-wireless@vger.kernel.org
cc: linux-pci@vger.kernel.org
cc: netfilter-devel@vger.kernel.org
cc: alsa-devel@alsa-project.org
This was missing.
The new backport rfkill approach caused a sparse warning:
linux/rfkill.h:70:43: warning: mixing different enum types
linux/rfkill.h:70:43: int enum rfkill_type versus
linux/rfkill.h:70:43: int enum old_rfkill_type
Fix it by adding a cast.
This is required by some drivers as of next-20130424.
commit fcf371ee5624cc87abac205cd0dad2432d7f0346
Author: Axel Lin <axel.lin@ingics.com>
Date: Thu Apr 18 10:34:49 2013 +0800
regulator: core: Add regulator_map_voltage_ascend() API
A lot of regulator hardware has ascendant voltage list.
This patch adds regulator_map_voltage_ascend() and export it.
Drivers that have ascendant voltage list can use this as their map_voltage()
operation, this is more efficient than default regulator_map_voltage_iterate()
function.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
This backports 9356b8fc d314774c and f646968f8f
all added in next-20130423. Soome driver changes are
still required and will be addressed separately.
commit 9356b8fc07dc126cd91d2b12f314d760ab48996e
Author: Eric Dumazet <dada1@cosmosbay.com>
Date: Tue Sep 27 15:23:16 2005 -0700
[NET]: Reorder some hot fields of struct net_device
Place them on separate cache lines in SMP to lower memory bouncing
between multiple CPU accessing the device.
- One part is mostly used on receive path (including
eth_type_trans()) (poll_list, poll, quota, weight, last_rx,
dev_addr, broadcast)
- One part is mostly used on queue transmit path (qdisc)
(queue_lock, qdisc, qdisc_sleeping, qdisc_list, tx_queue_len)
- One part is mostly used on xmit path (device)
(xmit_lock, xmit_lock_owner, priv, hard_start_xmit, trans_start)
'features' is placed outside of these hot points, in a location that
may be shared by all cpus (because mostly read)
name_hlist is moved close to name[IFNAMSIZ] to speedup __dev_get_by_name()
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
commit d314774cf2cd5dfeb39a00d37deee65d4c627927
Author: Stephen Hemminger <shemminger@vyatta.com>
Date: Wed Nov 19 21:32:24 2008 -0800
netdev: network device operations infrastructure
This patch changes the network device internal API to move adminstrative
operations out of the network device structure and into a separate structure.
This patch involves some hackery to maintain compatablity between the
new and old model, so all 300+ drivers don't have to be changed at once.
For drivers that aren't converted yet, the netdevice_ops virt function list
still resides in the net_device structure. For old protocols, the new
net_device_ops are copied out to the old net_device pointers.
After the transistion is completed the nag message can be changed to
an WARN_ON, and the compatiablity code can be made configurable.
Some function pointers aren't moved:
* destructor can't be in net_device_ops because
it may need to be referenced after the module is unloaded.
* neighbor setup is manipulated in a couple of places that need special
consideration
* hard_start_xmit is in the fast path for transmit.
commit f646968f8f7c624587de729115d802372b9063dd
Author: Patrick McHardy <kaber@trash.net>
Date: Fri Apr 19 02:04:27 2013 +0000
net: vlan: rename NETIF_F_HW_VLAN_* feature flags to NETIF_F_HW_VLAN_CTAG_*
Rename the hardware VLAN acceleration features to include "CTAG" to indicate
that they only support CTAGs. Follow up patches will introduce 802.1ad
server provider tagging (STAGs) and require the distinction for hardware not
supporting acclerating both.
There's only a single user of vb2_mmap_pfn_range() and
at least on 3.2 having the function in compat-3.9.c is
problematic if CPTCFG_BACKPORT_BUILD_DMA_SHARED_BUFFER
isn't set, because on that kernel there's no dma-buf.h
and then compilation can fail.
There's not much point in backporting rfkill, if the base kernel
doesn't have it then providing the it as /dev/rfkill_backport
won't be picked up by any apps, and if the base kernel has it
then it would cause odd behaviour as the base kernel's platform
drivers using the rfkill API would not talk to the backported
modules rfkill.
An unusable backported rfkill isn't much better than not having
it at all, so change the way we backport rfkill and don't carry
the code but simply provide the API as wrappers.
If the base kernel is 3.10 or higher (the current version) then
don't change anything at all.
If the base kernel is 2.6.33 or higher (with the new rfkill API)
then just wrap the API and disable rfkill registrations for any
types that the base kernel doesn't know about.
For all other kernels, provide only static inlines that behave
like the rfkill API when rfkill isn't compiled in.
The downside is that we need to copy the rfkill API. This is,
however, very very stable (it essentially hasn't changed since
2.6.33), so that's not a problem.
Just as an alias for 'install'.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
This is a no-op for the modular use case of the
backports project but by enabling this it allows
for developers a way to embed the backports releases
onto a target source Linux directory, with obvious
pending modifications, by adding our backport_init()
onto the target kernel's init/main.c start_kernel().
Enable this theoretical use case. Hackers welcome to
go play on this theoretical integration strategy now.
Cc: pstew@chromium.org
This backport's Konstantin's radix-tree bit optimized
iterator, 78c1d7848, added on v3.4. This is used by a new
drivers in the future. The new bit optimized iterator relies
on the stack optimization introduced via e2bdb933 added as of
v3.3. Backporting the bit optimized iterator requires
adjusting it to the old v3.2 radix_tree_node which is not
implemented here. For kernels v3.3 - v3.3 we can backport
the bit optimized iterator given that the radix_tree_node
did not changed between v3.3 - v3.4, in fact it hasn't
changed even up to v3.10. The backport relies on the same
helpers and inlines present on v3.3-v3.10 to implement
radix_tree_next_chunk().
This was tested as of next-20130410.
Throw the helper into compat config build option
CPTCFG_BACKPORT_BUILD_RADIX_HELPERS only to be built
on v3.3 right now unless someone really wants to
backport 78c1d7848 support onto v3.2.
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains 78c1d7848
v3.4-rc2~15^2~26
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains e2bdb933
v3.3-rc1~81^2~8
ckmake below, and then the commit log references above.
== ckmake-report.log ==
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m37.773s
user 809m37.644s
sys 126m30.806s
commit 78c1d78488a3c45685d993130c9f17102dc79a54
Author: Konstantin Khlebnikov <khlebnikov@openvz.org>
Date: Wed Mar 28 14:42:53 2012 -0700
radix-tree: introduce bit-optimized iterator
A series of radix tree cleanups, and usage of them in the core pagecache
code.
Micro-benchmark:
lookup 14 slots (typical page-vector size)
in radix-tree there earch <step> slot filled and tagged
before/after - nsec per full scan through tree
* Intel Sandy Bridge i7-2620M 4Mb L3
New code always faster
* AMD Athlon 6000+ 2x1Mb L2, without L3
New code generally faster,
Minor degradation (marked with "*") for huge sparse trees
* i386 on Sandy Bridge
New code faster for common cases: tagged and dense trees.
Some degradations for non-tagged lookup on sparse trees.
Ideally, there might help __ffs() analog for searching first non-zero
long element in array, gcc sometimes cannot optimize this loop corretly.
Numbers:
CPU: Intel Sandy Bridge i7-2620M 4Mb L3
radix-tree with 1024 slots:
tagged lookup
step 1 before 7156 after 3613
step 2 before 5399 after 2696
step 3 before 4779 after 1928
step 4 before 4456 after 1429
step 5 before 4292 after 1213
step 6 before 4183 after 1052
step 7 before 4157 after 951
step 8 before 4016 after 812
step 9 before 3952 after 851
step 10 before 3937 after 732
step 11 before 4023 after 709
step 12 before 3872 after 657
step 13 before 3892 after 633
step 14 before 3720 after 591
step 15 before 3879 after 578
step 16 before 3561 after 513
normal lookup
step 1 before 4266 after 3301
step 2 before 2695 after 2129
step 3 before 2083 after 1712
step 4 before 1801 after 1534
step 5 before 1628 after 1313
step 6 before 1551 after 1263
step 7 before 1475 after 1185
step 8 before 1432 after 1167
step 9 before 1373 after 1092
step 10 before 1339 after 1134
step 11 before 1292 after 1056
step 12 before 1319 after 1030
step 13 before 1276 after 1004
step 14 before 1256 after 987
step 15 before 1228 after 992
step 16 before 1247 after 999
radix-tree with 1024*1024*128 slots:
tagged lookup
commit e2bdb933ab8b7db71c318a4ddcf78a9fffd61ecb
Author: Hugh Dickins <hughd@google.com>
Date: Thu Jan 12 17:20:41 2012 -0800
radix_tree: take radix_tree_path off stack
Down, down in the deepest depths of GFP_NOIO page reclaim, we have
shrink_page_list() calling __remove_mapping() calling __delete_from_
swap_cache() or __delete_from_page_cache().
You would not expect those to need much stack, but in fact they call
radix_tree_delete(): which declares a 192-byte radix_tree_path array on
its stack (to record the node,offsets it visits when descending, in case
it needs to ascend to update them). And if any tag is still set [1],
that calls radix_tree_tag_clear(), which declares a further such
192-byte radix_tree_path array on the stack. (At least we have
interrupts disabled here, so won't then be pushing registers too.)
That was probably a good choice when most users were 32-bit (array of
half the size), and adding fields to radix_tree_node would have bloated
it unnecessarily. But nowadays many are 64-bit, and each
radix_tree_node contains a struct rcu_head, which is only used when
freeing; whereas the radix_tree_path info is only used for updating the
tree (deleting, clearing tags or setting tags if tagged) when a lock
must be held, of no interest when accessing the tree locklessly.
So add a parent pointer to the radix_tree_node, in union with the
rcu_head, and remove all uses of the radix_tree_path. There would be
space in that union to save the offset when descending as before (we can
argue that a lock must already be held to exclude other users), but
recalculating it when ascending is both easy (a constant shift and a
constant mask) and uncommon, so it seems better just to do that.
Two little optimizations: no need to decrement height when descending,
adjusting shift is enough; and once radix_tree_tag_if_tagged() has set
tag on a node and its ancestors, it need not ascend from that node
again.
perf on the radix tree test harness reports radix_tree_insert() as 2%
slower (now having to set parent), but radix_tree_delete() 24% faster.
Surely that's an exaggeration from rtth's artificially low map shift 3,
but forcing it back to 6 still rates radix_tree_delete() 8% faster.
Commit 5a753a4 on next-20130410 extended the
dma-buf implementation to add debugfs support.
We backport support for this by adding its own
subsys_init() call as a helper to the backport
module (still called compat) respective subsys_init()
call, backport_init(). For kernels where this is
already supported this is a no-op.
This didn't make it to v3.9 but I see Linus has
already merged this as part of the merge window
what will be v3.10.
This also refreshes patches for next-20130410 and
I supply the refresh as part of this same patch
given that the only patch refreshed was the one
modifyin the drivers/base/dma-buf.c.
commit 5a753a49fb7e17fa83ea9cf39c7b1a902363d828
Author: Sumit Semwal <sumit.semwal@linaro.org>
Date: Thu Apr 4 11:44:37 2013 +0530
dma-buf: Add debugfs support
Add debugfs support to make it easier to print debug information
about the dma-buf buffers.
Cc: Dave Airlie <airlied@redhat.com>
[minor fixes on init and warning fix]
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
$ ckmake --allyesconfig
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m10.328s
user 797m1.841s
sys 125m15.978s
We are only backporting CONFIG_SOC_CAMERA for kernels >= 3.4
but there is an exported symbol from there that some media
drivers that we do support on 3.3 need. Handle this special
case.
SOC_CAMERA is only enabled on 3.4 as it depends on some
newer regulator functionality, however there are some SOC
cameras that can rely on the 3.3 regulatory built-in core
and the 3.3 SOC_CAMERA module however two routines are
not exported in that version of SOC_CAMERA that newer
SOC cameras do require. Backport that functionality.
Technically this should go into <media/soc_camera.h>
given that is where its where its exported on linux-next
but in practice only placing it on <linux/v4l2-mediabus.h>
actually fixes linking errors for 3.3 for all SOC camera
drivers we make available for 3.3:
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/imx074.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/mt9m001.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/mt9m111.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/mt9t031.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/mt9t112.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/mt9v022.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/ov2640.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/ov5642.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/ov6650.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/ov772x.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/ov9640.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/ov9740.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/rj54n1cb0c.ko
LD [M] /home/mcgrof/build/drivers/media/i2c/soc_camera/tw9910.ko
This fixes all pending linking errors on 3.3.
$ time ckmake --check-exports --allyesconfig
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.65 [ OK ]
18 3.1.10 [ OK ]
19 3.2.38 [ OK ]
20 3.3.8 [ OK ]
21 3.4.32 [ LINK ]
22 3.5.7 [ LINK ]
23 3.6.11 [ OK ]
24 3.7.9 [ OK ]
25 3.8.0 [ OK ]
26 3.9-rc1 [ OK ]
real 30m14.581s
user 796m34.495s
sys 126m46.807s
We added dma_common_get_sgtable() assuming it should only
be available to older kernels as of 3.6 but it was only
up to 3.8 where it was detangled from depending on
CONFIG_HAVE_GENERIC_DMA_COHERENT. Its a mess to express
this on compat files so just word it via kconfig and throw this
onto its own files given that there may be other helpers
we may need to backport later with the same circumstances.
One last hack was required for 3.3-3.6 and that is due
to header changes between kernels.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.65 [ OK ]
18 3.1.10 [ OK ]
19 3.2.38 [ OK ]
20 3.3.8 [ LINK ]
21 3.4.32 [ LINK ]
22 3.5.7 [ LINK ]
23 3.6.11 [ OK ]
24 3.7.9 [ OK ]
25 3.8.0 [ OK ]
26 3.9-rc1 [ OK ]
real 30m3.120s
user 795m40.684s
sys 123m29.995s
Mask the symbol so no matter where it was backported we can
compile against that kernel tree.
Signed-off-by: Dor Shaish <dor.shaish@intel.com>
The kernel's "make clean" will recurse into subdirectories, even
into those that aren't enabled in Kconfig. Thus, the previous
trick of changing symbols from CONFIG_* to IMPOSSIBLE_* doesn't
work any more. Change this to comment out the lines instead and
then support "make clean" and "make mrproper".
Change the "severity" of the message, it doesn't have to
be prefixed with "Warning:" since for many modules it'll
work without updating initramfs. Also reformat it so it's
aligned more nicely.
My "test ... && ..." trick won't work with set -e since
then the script will fail, use a proper if.
On some kernels, hid_match_id() exists, so mask it.
Some kernels apparently have this backported, and it doesn't
hurt to protect the symbol since we patch it in anyway for
those files needing it.
There's no need to pipe yes '' to make defconfig since
it will not ask for anything anyway, and even if it did
the user should probably be asked ...
New kernels do this, and some users rely on it.
This allows getting rid of the cfg80211 and ath6kl
patches to include it directly.
This allows us to get rid of the mac80211.h patch to
include net/if_inet6.h to get that declaration. Newer
kernels implicitly declare the struct by using it for
a pointer in struct net_device.
debian kernel 3.2 backports eth_hw_addr_random and this collides with
our backport without this patch.
Instead of patching, make a macro that casts the const out
from the function pointer arguments to avoid the warning.
There's no need to have those patches as struct device_type,
with its name field, has been available since kernel 2.6.22.
We can thus make the macro SET_NETDEV_DEVTYPE() an inline
instead (to avoid "unused variable" warnings) and thus get
rid of the patches for it.
When the kernel build system/configuration isn't present, warn
verbosely instead of later failing with crypting errors.
If the kernel's configuration changes for some reason or you
change the KLIB path then the Kconfig.kernel file is rebuilt
correctly, but the .config and autoconf header may be left
in inconsistent state. Make the autoconf header make target
depend on the Kconfig.kernel and Kconfig.versions file, this
fixes the issue since then oldconfig will run and the header
will be rebuilt.
This reverts commit 91bf647c3a157688ce8e94c0df512cde1b3f5a87.
Also fix the #ifdef for netdev_set_default_ethtool_ops() as
it was backported into kernel 3.7.8.
When the base kernel has LED support (partially) disabled,
currently many drivers cannot be built. Since LED support
is hardy critical, work around this by providing API stubs
for the LED support code to still compile (but not work.)
This passes allyesconfig (except for some stupid rtlwifi
issue) with next-20130405 against a 3.8 kernel that has
all the LED options disabled.
That ifdef got misplaced, vzalloc() shouldn't be inside.
The contents of our asm-generic/dma-mapping-common.h should really be
in asm/dma-mapping.h as that gets included by linux/dma-mapping.h and
the other one is just a helper header that arches *may* include.
This needs to be included for kernel 3.7.
I included that file always, but then when the copy-list
doesn't contain the drivers/net/usb/ directory it would
fail to build ... fix that by including that directory
only conditionally when USB_NET_RNDIS_WLAN is selected.
pci_platform_rom() actually made it into 3.9, so
only provide it for kernels before that.
This may not be the right thing to do, but it resolves
linking the TI driver on 2.6.36 where pm_wakeup_event()
is declared but not always exported.
Use the scripting to always copy the latest version.
This is needed as old versions of it didn't properly
declare struct pci_dev.
Additionally, not all versions included video/vga.h
which causes issues as that pulls in some required
definitions.
