path: root/backport
2014-06-17backports: do not include net_ieee802154_lowpan in kernel >= 3.16Hauke Mehrtens
In kernel >= 3.16 this backport is not needed at all. When CPTCFG_IEEE802154_6LOWPAN is not set it should not get build, we do not have to check if we are kernel > 3.5, because in an other case ieee802.15.4 will not get build. Kernel version 3.15 needs a different backport than the older versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-17backports: Revert "remove parameter from dma_buf_export()"Hauke Mehrtens
The linux commit which made backports need this patch was removed from linux-next. This reverts commit 6e1b080e83f1537d8d198917180d0a8bdfd7e0c9. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-17backports: add __pskb_copy_fclone()Hauke Mehrtens
__pskb_copy() was renamed to __pskb_copy_fclone() in most places and got an extra parameter, it should be safe to just ignore this extra parameter. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: add split_page()Hauke Mehrtens
2014-06-16backports: add of_match_ptr()Hauke Mehrtens
2014-06-16backports: add of_node_put()Hauke Mehrtens
2014-06-16backports: remove parameter from dma_buf_export()Hauke Mehrtens
dma_buf_export() got a new parameter which is not available in older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: add crc7_be()Hauke Mehrtens
This was added in: commit 1836eea209546b870dd83f3f4ef234d6598a560d Author: George Spelvin <linux@horizon.com> Date: Sat May 10 10:32:57 2014 -0400 lib/crc7: Shift crc7() output left 1 bit Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: add prandom_u32_max()Hauke Mehrtens
This was added in: commit f337db64af059c9a94278a8b0ab97d87259ff62f Author: Daniel Borkmann <dborkman@redhat.com> Date: Wed Jan 22 02:29:39 2014 +0100 random32: add prandom_u32_max and convert open coded users Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: add U32_MAXHauke Mehrtens
This was added in: commit 89a0714106aac7309c7dfa0f004b39e1e89d2942 Author: Alex Elder <alex.elder@linaro.org> Date: Thu Jan 23 15:54:00 2014 -0800 kernel.h: define u8, s8, u32, etc. limits Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: remove USHORT_MAX from kernel.hHauke Mehrtens
This define is not in the kernel any more. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-15backports: add I2C_CLIENT_SCCBHauke Mehrtens
This is needed for some newly activated media driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-15backports: add i2c_add_mux_adapter()Hauke Mehrtens
This adds i2c_add_mux_adapter() also for kernel < 3.5. This is needed for some newly activated media driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-15backports: remove backport of DMA shared buffersHauke Mehrtens
This DMA shared buffer backport was used for kernel < 3.5, more recent kernel versions already have a working version of the DMA shared buffers. The DMA shared buffers are only used by some media drivers, but non of these media drivers, which are actually using this API, are compiled on kernel < 3.5. The DMA shared buffer part would need some more attention in the next backports version, because there are some bigger changes and instead we removed it. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-08backports: add RSI driverHauke Mehrtens
This adds Redpine Signals Inc 91x WLAN driver support Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-07backports: add mmc_card_hs()Hauke Mehrtens
This is needed by the RSI driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-07backports: add ether_addr_copy()Hauke Mehrtens
This is needed by the rsi driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-07backports: rename irq_get_trigger_type()Hauke Mehrtens
This should avoid possible name conflicts. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-07backports: revert rename of __vlan_find_dev_deep()Hauke Mehrtens
This function was renamed in this commit in mainline linux: commit f06c7f9f92295faf701a9628b383156c4efb6119 Author: dingtianhong <dingtianhong@huawei.com> Date: Fri May 9 14:58:05 2014 +0800 vlan: rename __vlan_find_dev_deep() to __vlan_find_dev_deep_rcu() Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: set defconfig media to mbackports-20140501Hauke Mehrtens
Set the default option to module. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: update default configsHauke Mehrtens
Remove some config options which were not available in the kernel any more and add some missing new options. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: add irq_get_trigger_type()Hauke Mehrtens
This function is needed by some drivers. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: add devm_gpio_request{_one}()Hauke Mehrtens
These two functions are used by some drivers, but not available in all kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: move net_device_priv_flagsHauke Mehrtens
These flags are now defined in linux/netdevice.h and not in linux/if.h any more. This patch also removed some defined in all kernel versions since 3.0. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: only add net_get_random_once() when not availableHauke Mehrtens
net_get_random_once() was added unconditionally also when the kernel we are compiling against already provided this function, this patch checks that first. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: fix build if CONFIG_PTP_1588_CLOCK=mHauke Mehrtens
ifdef just checked if this was build into the kernel and not if it was build as a module. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: add smp_mb__after_atomic()Hauke Mehrtens
smp_mb__after_clear_bit() was renamed to smp_mb__after_atomic() in more recent kernel version, this patch adds compatibility for older kernel versions. In addition it also removes a useless include of asm/atomic.h which would include this same file. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: Avoid multiple definition of DEVICE_ATTR_RW for older kernelsJonathan DE CESCO
This definition may exists on non-vanilla kernels. Signed-off-by: Jonathan DE CESCO <jonathan.de.cesco@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backport: CCM: set correct dependenciesJohannes Berg
If these aren't actually compiled in, then the mac80211 code will fail at runtime. Add these dependencies so we at least get a warning at compile time about this. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: provide net_ieee802154_lowpan only when neededJohannes Berg
If 802.15.4 isn't configured, there's no need to provide the network namespace support for it, so don't. Signed-off-by: Johannes Berg <johannes.berg@intel.com> [use IS_ENABLED to hanle CPTCFG_IEEE802154_6LOWPAN=m] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-01backports: backport-3.15: Include fixRichard Röjfors
In this version the correct linux string.h is included. Include string.h to avoid compile issues if warnings are treated as errors: backports-3.14-1/compat/backport-3.15.c: In function 'backport_devm_kstrdup': backports-3.14-1/compat/backport-3.15.c:33:2: error: implicit declaration of function 'strlen' [-Werror=implicit-function-declaration] size = strlen(s) + 1; ^ backports-3.14-1/compat/backport-3.15.c:33:9: warning: incompatible implicit declaration of built-in function 'strlen' [enabled by default] size = strlen(s) + 1; ^ backports-3.14-1/compat/backport-3.15.c:36:3: error: implicit declaration of function 'memcpy' [-Werror=implicit-function-declaration] memcpy(buf, s, size); ^ backports-3.14-1/compat/backport-3.15.c:36:3: warning: incompatible implicit declaration of built-in function 'memcpy' [enabled by default] Signed-off-by: Richard Röjfors <richard@puffinpack.se> [refreshed patch on current master] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-05-01Makefile: add savedefconfig target.Avery Pennarun
This writes a file called 'defconfig' which contains only the deltas from the default configuration. It's suitable for use as an input defconfig file for later builds. Signed-off-by: Avery Pennarun <apenwarr@gmail.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-05-01backports: remove IWLWIFI_P2P from iwlwifi defconfigJohannes Berg
This symbol is obsolete, it was removed upstream, so just remove it from the defconfig file as well. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-05-01backports: remove more old ifdef/compat codeJohannes Berg
Since support for kernels < 3.0 was removed, there's now a bunch of dead code that can be removed - do it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-05-01backports: remove mac80211.hJohannes Berg
As support for old kernels has been removed, there's no need to keep around the mac80211.h file that redefines the ieee80211_rx() symbol; In 2.6.32 this name was changed to belong to mac80211. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-05-01backports: ifdef code already present in RHEL7.0Stefan Assmann
Avoid conflicts with RHEL7.0 as DEVICE_ATTR_* defines, enum pkt_hash_types, skb_set_hash(), dma_common_get_sgtable() are already present. Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-05-01backports: wrap dma_set_mask_and_coherent in LINUX_BACKPORT()Stefan Assmann
To avoid conflicts with any distribution kernel wrap dma_set_mask_and_coherent with LINUX_BACKPORT(). Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: nuke support for kernels < 3.0Luis R. Rodriguez
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: backport define of SIOCGHWTSTAMPLuis R. Rodriguez
Ben added ioctl support for the unprivileged SIOCGHWTSTAMP which is designed to just get the configuration, unlike SIOCSHWTSTAMP which requires you to set it and only after it returns the configuration. Since we are carrying over a small addition to a UAPI header without carrying it over completely (we use copy-list to carry over full UAPI headers) its worth making a design note about this. We carry UAPI headers for backports to enable compilation of kernel / driver code to compile without any changes. If it so happens that a feature is backported it can be added here but notice that if full subsystems are backported you should just include the respective full header onto the copy-list file so that its copied intact. The strategy on this patch can be used to either backport a specific feature or to just avoid having to do ifdef changes to compile kernel or driver carried over by backports. Userspace is *not expected* to copy over backports headers to compile userspace programs, userspace programs can and should consider carrying over a respective copy-list of the latest UAPI kernel headers they need in their upstream sources, the kernel the user uses, whether with backports or not should be able to return -EOPNOTSUPP if the feature is not available and let it through if its supported and meats the expected form. In this particular case if userspace tries to send the SIOCGHWTSTAMP they'd end up with -ENOTTY. mcgrof@ergon ~/linux (git::master)$ git describe --contains fd468c74 v3.14-rc1~94^2~622^2~12 commit fd468c74bd4d6949736810a80d6ca05eb20fba84 Author: Ben Hutchings <bhutchings@solarflare.com> Date: Thu Nov 14 01:19:29 2013 +0000 net_tstamp: Add SIOCGHWTSTAMP ioctl to match SIOCSHWTSTAMP SIOCSHWTSTAMP returns the real configuration to the application using it, but there is currently no way for any other application to find out the configuration non-destructively. Add a new ioctl for this, making it unprivileged. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: backport dev_consume_skb_any()Luis R. Rodriguez
dev_consume_skb_any() was added by Eric via commit e6247027e added as of v3.14 to help do analysis on the different reasons why an skbs are free'd in particular to let us know how many get dropped or consumed. The new dev_consume_skb_any() spawned the inception of an optimization for dev_kfree_skb_irq() which was implemented through __dev_kfree_skb_irq() which dev_kfree_skb_irq() now uses. We could have taken advantage of both if kernels had exported raise_softirq_irqoff() but they don't and as such we can't reimplement that on backports as it stands right now. If we'd be building backports in-kernel we could just take the new implementation of __dev_kfree_skb_irq() as raise_softirq_irqoff() would be available and we could reap the benefits of the change. That implemention can be seen as a reference - for now - here: http://drvbp1.linux-foundation.org/~mcgrof/patches/2014/04/11/pend-2014-04-07.patch For older kernels for now we just use the singular old version of dev_kfree_skb_irq() and dev_kfree_skb_any(). mcgrof@ergon ~/linux (git::master)$ git describe --contains e6247027e v3.14-rc1~94^2~585 commit e6247027e5173c00efb2084d688d06ff835bc3b0 Author: Eric Dumazet <edumazet@google.com> Date: Thu Dec 5 04:45:08 2013 -0800 net: introduce dev_consume_skb_any() Some network drivers use dev_kfree_skb_any() and dev_kfree_skb_irq() helpers to free skbs, both for dropped packets and TX completed ones. We need to separate the two causes to get better diagnostics given by dropwatch or "perf record -e skb:kfree_skb" This patch provides two new helpers, dev_consume_skb_any() and dev_consume_skb_irq() to be used for consumed skbs. __dev_kfree_skb_irq() is slightly optimized to remove one atomic_dec_and_test() in fast path, and use this_cpu_{r|w} accessors. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Eric Dumazet <edumazet@google.com> Cc: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: device: don't redefine DEVICE_ATTR_ROArik Nemtsov
Some old custom kernels have it defined. Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: add napi_gro_flush()Johannes Berg
napi_gro_flush() got a second argument in kernel 3.7, but it can be ignored for prior kernel versions. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: add hwsim defconfigJohannes Berg
This can be useful for pure testing scenarios. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: backport 3.6 fix on non CONFIG_COMMON_CLK kernelsLuis R. Rodriguez
Commit 93abe8e4 by Viresh added non CONFIG_COMMON_CLK static inlines that should have gone in for 3.5 as 3.5 assumed some declared routines would be exproted by the architecture, which was not true. We backport only the non CONFIG_COMMON_CLK case as CONFIG_COMMON_CLK requires core kernel architecture specific backport support which we currently do not support (and perhaps shouldn't). Since 3.5 is not a supported kernel there is no need to fix this there upstream but this then does require a paper wrap work around for those kernels of providing an export symbol for clk_enable() and clk_disable() for the !CONFIG_COMMON_CLK case which older kernels failed to address. mcgrof@ergon ~/linux-next (git::master)$ git describe --contains 93abe8e4 v3.6-rc1~41^2~117 Cc: Viresh Kumar <viresh.kumar@st.com> Cc: Wolfram Sang <w.sang@pengutronix.de> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: add GRO_* enums, and its new gro_result_t typedefLuis R. Rodriguez
This backports commit d1c76af9e added by Herbert which added the first enums and then commit 5b252f0c2 added by Ben which gave the enums a label and then pegged a typedef onto these. This backports these commits in a forward compatible way upkeeping the introduction and then the typedef. In order to make this work we use make backported code use enums with the BACKPORT_prefix but upkeep the same values, this lets us declare the typedef and peg it to a similar set. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: complete backport of translation of MMD EEE registersLuis R. Rodriguez
Commit b32607dd was already partially backported, this complets that backport. mcgrof@ergon ~/linux-next (git::master)$ git describe --contains b32607dd v3.7-rc1~145^2~292 Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: complete backport of frag size accessorsLuis R. Rodriguez
These are just helpers so carry them over, this was added via commit 9e903e0852 through v3.2. The skb frag size was in place for a long time but was changed from __u16 to __u32 via commit a309bb072b through v2.6.23 and since we backport for >= 2.6.25 just leave this as is. This was already only partly backported, this adds the missing helpers. mcgrof@ergon ~/linux-next (git::master)$ git describe --contains 9e903e0852 v3.2-rc1~182^2~85 mcgrof@ergon ~/linux-next (git::master)$ git describe --contains a309bb072b v2.6.23-rc2~35^2~11 commit 9e903e085262ffbf1fc44a17ac06058aca03524a Author: Eric Dumazet <eric.dumazet@gmail.com> Date: Tue Oct 18 21:00:24 2011 +0000 net: add skb frag size accessors To ease skb->truesize sanitization, its better to be able to localize all references to skb frags size. Define accessors : skb_frag_size() to fetch frag size, and skb_frag_size_{set|add|sub}() to manipulate it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: backport skb_set_hash()Luis R. Rodriguez
This backports skb_set_hash(). Two skb data structures are used introduced at different points in time, so ifdef around that as well. For older kernels this is a nop. mcgrof@ergon ~/linux (git::master)$ git describe --contains bdeab99191 v3.2-rc1~129^2~458 mcgrof@ergon ~/linux (git::master)$ git describe --contains 4031ae6edb v3.4-rc1~177^2~333^2 mcgrof@ergon ~/linux (git::master)$ git describe --contains 09323cc479 v3.14-rc1~94^2~474^2~1 Cc: Tom Herbert <therbert@google.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: backport APIs for manipulating skb page fragmentsLuis R. Rodriguez
This backports the APIs for manipulating skb page fragments introduced by Ian via commit 131ea6675c on v3.2. Use the LINUX_BACKPORT() namespace to avoid clashes with similar ports. We skip skb_frag_dma_map() as that was already backported. We also don't backport skb_frag_page() as that was already backported before. Since the skb fragment page was moved into its own struct as part of the fragment our backport ends up using the old access mechanisms for the framgement page. For details see a8605c6063. mcgrof@ergon ~/linux-next (git::master)$ git describe --contains 131ea6675c v3.2-rc1~129^2~421 mcgrof@ergon ~/linux-next (git::master)$ git describe --contains a8605c6063 v3.2-rc1~182^2~29 commit 131ea6675c761f655d43b808dd0fe83d15d5cdd3 Author: Ian Campbell <Ian.Campbell@citrix.com> Date: Fri Aug 19 06:25:00 2011 +0000 net: add APIs for manipulating skb page fragments. The primary aim is to add skb_frag_(ref|unref) in order to remove the use of bare get/put_page on SKB pages fragments and to isolate users from subsequent changes to the skb_frag_t data structure. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: backport u64_stats_fetch_begin_irq() and u64_stats_fetch_retry_irq()Luis R. Rodriguez
The bh version u64_stats_fetch_begin_bh() and u64_stats_fetch_retry_bh() got dropped in favor for an IRQ safe variant. We can now remove u64_stats_fetch_begin_bh() and u64_stats_fetch_retry_bh() as we work carrying over what is upstream and no drivers upstream use this anymore. Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
