path: root/copy-list
2014-01-19backports: add sdio device id listHauke Mehrtens
This copies the sdio device id list into backprots, this is used by brcmfmac. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-18backports: add missing header fileHauke Mehrtens
The act8865 regulator driver needs this header file. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-18backports: copy include/uapi/linux/vsp1.hHauke Mehrtens
This header file is now needed by a media driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-18backports: add include/net/af_ieee802154.h fileHauke Mehrtens
This file was added in kernel 2.6.32 and is now needed by bluetooth. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-18backports: add include/trace/events/v4l2.h fileHauke Mehrtens
v4l2 now supports tracing and needs a new header file that was missing. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-11-24backports: remove own version of include/linux/unaligned/*.hbackports-20131122-2Hauke Mehrtens
These files are now copied from the kernel like normal files we take from the kernel. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-11-24backports: remove own version of include/linux/wireless.hHauke Mehrtens
This file is now copied from the kernel like a normal file we take from the kernel. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-11-24backports: remove eeprom_93cx6.h headerHauke Mehrtens
The driver is not included in backports and we should use the in kernel headers. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-11-24backports: remove mdio driver codeHauke Mehrtens
There is some code for the mdio driver in backports, but it does not get build on any kernel, just remove it till someone wants to make it work. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: add platform driver for media driversHauke Mehrtens
2013-10-23backports: remove platform driversHauke Mehrtens
The platform drivers were only needed by some DRM drivers and are not needed any more with the DRM driver being removed. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: remove DRM driverHauke Mehrtens
Maintaining the DRM driver takes a lot of recourses as there they are depending on many API changes done to the core kernel code and currently we do not have that many recourses to follow them. On the other side one needs also new userspace drivers to make use of the new features added to the DRM kernel drivers and it is not easy to update the X drivers. Therefore we came to the conclusion to remove the drm drivers for now. There were also some problems with some DRM drivers, like the Intel i915 driver caused kernel panic on some systems and was probably only usable on some very recent kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: copy include/drm/drm_flip_work.hHauke Mehrtens
This file was newly added to drm. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: add include/drm/drm_agpsupport.hHauke Mehrtens
This adds the missing file include/drm/drm_agpsupport.h Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: fix intel i915 drm driverHauke Mehrtens
The intel i915 drm driver uses the declarations from intel-gtt.h to interact with drivers/char/agp/intel-gtt.c which is not backported by backports project. To prevent some strange problems when using i915, use the headers from the kernel and do not use our own. This causes some compile problems which where runtime problems before and bumps the minimal kernel version to 3.7. This i915 still crash on my device with kernel 3.7. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-08-27backports: add include/linux/regulator/pfuze100.hHauke Mehrtens
This is a new driver which needs a new header file. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: do not copy wrong header files for regulatorsHauke Mehrtens
Some of the header files for the regulators framework where used by regulator core, which does not get backported or some of them are also used by mfd drivers. Now only the headers which are only used by the regulator driver are copied, it could still be that these headers are also used in some platform specific code where the driver gets registered. This patch then fixed some dependencies which where wrong because of using the wrong header files. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-15backports: Include drivers/net/wireless/cw1200Solomon Peachy
The cw1200 WLAN driver was added in 3.11-rc; include it in backports. Signed-off-by: Solomon Peachy <pizza@shaftnet.org> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-15backports: add wwan device driversPatrick Ziegler
Add cdc_mbim, cdc_ncm, sierra_net, qmi_wwan device drivers. Signed-off-by: Patrick Ziegler <patrick.ziegler@fh-kl.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-29backports: copy over s2mps11.hLuis R. Rodriguez
This is required by s2mps11 as of at least next-20130709. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-27backports: copy over mfd/max8998.h mfd/max8998-private.hLuis R. Rodriguez
This is required by CONFIG_REGULATOR_MAX8998 which builds drivers/regulator/max8998.c as of next-20130703. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-19backports: enable REGULATOR_MAX77693 on >= 3.6Luis R. Rodriguez
There is a symbol missing otherwise that is currently only provided by the core, ie, non modular. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-19backports: copy the max77693-private.h header fileLuis R. Rodriguez
2013-06-19backports: add ieee802154Hauke Mehrtens
This adds the ieee802154 subsystem. == ckmake-report.log == 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-05-17backport: remove redundant copy-list entriesbackports-20130502Johannes Berg
Directory copying is recursive, so there's no need to list subdirectories. All atheros ethernet drivers are copied, so don't list them one by one. The same is true for the Bluetooth include files. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-17backports: address NFC LLCP code shiftLuis R. Rodriguez
Samuel folded code under net/nfc/llcp/ onto the parent net/nfc/ directory with llcp_ prefixes for the files. Address this change introduced as of next-20130430. commit 30cc4587659e1c9b1bfade8b2a757d91e04758ab Author: Samuel Ortiz <sameo@linux.intel.com> Date: Fri Apr 26 11:49:40 2013 +0200 NFC: Move LLCP code to the NFC top level diirectory And stop making it optional. LLCP is a fundamental part of the NFC specifications and making it optional does not make much sense. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-14backports: don't backport rfkill, only APIJohannes Berg
There's not much point in backporting rfkill, if the base kernel doesn't have it then providing the it as /dev/rfkill_backport won't be picked up by any apps, and if the base kernel has it then it would cause odd behaviour as the base kernel's platform drivers using the rfkill API would not talk to the backported modules rfkill. An unusable backported rfkill isn't much better than not having it at all, so change the way we backport rfkill and don't carry the code but simply provide the API as wrappers. If the base kernel is 3.10 or higher (the current version) then don't change anything at all. If the base kernel is 2.6.33 or higher (with the new rfkill API) then just wrap the API and disable rfkill registrations for any types that the base kernel doesn't know about. For all other kernels, provide only static inlines that behave like the rfkill API when rfkill isn't compiled in. The downside is that we need to copy the rfkill API. This is, however, very very stable (it essentially hasn't changed since 2.6.33), so that's not a problem. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-13backports: copy brcmfmac-sdio.hLuis R. Rodriguez
On next-20130415 commit 668761ac0 added platform specific data for brcmfmac for SDIO. Copy that over. This is the first in a series of changes required for next-20130415. commit 668761ac01d6f5a36b8e5a24d4e154550e2c4c3b Author: Hante Meuleman <meuleman@broadcom.com> Date: Fri Apr 12 10:55:55 2013 +0200 brcmfmac: define and use platform specific data for SDIO. This patch adds support for platform specific data for SDIO fullmac devices. Currently OOB interrupts are configured by Kconfig BRCMFMAC_SDIO_OOB but that is now determined dynamically by checking availibility of platform data. Cc: Hauke Mehrtens <hauke@hauke-m.de> Reviewed-by: Arend Van Spriel <arend@broadcom.com> Reviewed-by: Franky (Zhenhui) Lin <frankyl@broadcom.com> Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com> Reviewed-by: Piotr Haber <phaber@broadcom.com> Signed-off-by: Hante Meuleman <meuleman@broadcom.com> Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-15backports: add rndis_wlan usbnet requirementsJohannes Berg
Apparently I missed this during the conversion to the new copy-list etc. The rndis_wlan driver requires some usbnet and rndis code, if that's not present then it is either not selectable or can be compiled but won't link against older kernels that don't have the right requirements (or don't have the symbols exported.) For now, because the makefile parser is stupid, patch out the asix driver objects because otherwise it's possible to select it and fail the build. Improving the parser is possible but I need to finish other things first. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-13backports: add intel_ips supportLuis R. Rodriguez
1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.65 [ OK ] 18 3.1.10 [ OK ] 19 3.2.38 [ OK ] 20 3.3.8 [ OK ] 21 3.4.32 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.9 [ OK ] 25 3.8.0 [ OK ] 26 3.9-rc1 [ OK ] real 39m35.615s user 1068m47.428s sys 155m55.657s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-13backports: add media subsystem driversLuis R. Rodriguez
This adds backport support for all media subsystem drivers. This is enabled only for >= 3.2. Some media drivers rely on the new probe deferrral mechanism (-EPROBE_DEFER see commit d1c3414c), those are only enabled for kernels >= 3.4. Some media drivers only depend on the regulatory but since we only support backporting the regulatory on kernels >= 3.4 we only enable those media drivers for >= 3.4. This backports 433 media drivers. 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.65 [ OK ] 18 3.1.10 [ OK ] 19 3.2.38 [ OK ] 20 3.3.8 [ OK ] 21 3.4.32 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.9 [ OK ] 25 3.8.0 [ OK ] 26 3.9-rc1 [ OK ] real 39m35.615s user 1068m47.428s sys 155m55.657s Cc: linux-media@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-13backports: add support for voltage / current regulator driversLuis R. Rodriguez
This backports the latest regulator drivers for kernels >= 3.4. We enable the regulator only on kernels >= 3.4 given that it relies on the new probe deferral mechanism which would otherwise mean having to support drivers that do not probe correctly. Note that 3.2 had a base regulator implementation but that was just stubs. I did look into a way to upgrade the core kernel regulator but given that it relies on late_initcall() and core_initcall() we can't update this part of the kernel. I even looked at using ksplice for this but it seems ksplice can't be used to update init sections on the vmlinux ELF. I also haven't much updates to these routines since 3.4 except for 86f5fcfc. 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.65 [ OK ] 18 3.1.10 [ OK ] 19 3.2.38 [ OK ] 20 3.3.8 [ OK ] 21 3.4.32 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.9 [ OK ] 25 3.8.0 [ OK ] 26 3.9-rc1 [ OK ] real 39m35.615s user 1068m47.428s sys 155m55.657s Cc: Liam Girdwood <lgirdwood@gmail.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-08backports: add NFC core and driversThierry Escande
This grabs NFC core and drivers files from your linux tree. Signed-off-by: Thierry Escande <thierry.escande@linux.intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-06backports: really enable DRMJohannes Berg
This was previously not really enabled because it wasn't in the Makefile.kernel, add it there. Also add a defconfig file for all DRM drivers. This passes ckmake --defconfig drm: 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.65 [ OK ] 18 3.1.10 [ OK ] 19 3.2.38 [ OK ] 20 3.3.8 [ OK ] 21 3.4.32 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.9 [ OK ] 25 3.8.0 [ OK ] 26 3.9-rc1 [ OK ] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-05backports: add DRM driversLuis R. Rodriguez
They are building just fine so enable them. 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.65 [ OK ] 18 3.1.10 [ OK ] 19 3.2.38 [ OK ] 20 3.3.8 [ OK ] 21 3.4.32 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.9 [ OK ] 25 3.8.0 [ OK ] 26 3.9-rc1 [ OK ] Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-02add ethernet backJohannes Berg
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-04-02copy rfkill headerJohannes Berg
2013-04-01add kernel license/maintainers file to outputJohannes Berg
2013-04-01add ssb/bcma includesJohannes Berg
2013-04-01enable all wireless/bluetooth driversJohannes Berg
Pretty much like the old compat ... However, ath5k doesn't build due to tracing, but I haven't found the bug yet. Also, brcm80211 make system is a big mess and doesn't quite work right with the simple makefile parser here. Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-04-01allow renaming while copyingJohannes Berg
This will be useful for the rfkill backport. Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-03-30copy needed includesJohannes Berg
Copy the necessary include files for the different components, without them obviously nothing builds. This necessitated using an own copytree() implementation that doesn't error when a target directory already exists. Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-03-30comment copy-listJohannes Berg
2013-03-30add first attempt at new copy script and build infrastructureJohannes Berg
