path: root/devel/backports-update-manager
2015-11-02devel: update the test kernel versionsbackports-20150923Hauke Mehrtens
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-09-14devel: update test kernel versionsHauke Mehrtens
2015-07-23devel: update the test kernel versionsbackports-20150710Hauke Mehrtens
2015-07-23devel: convert backports-update-manager to python3Hauke Mehrtens
This converts the backports-update-manager to use python3 instead of python2. python3 is needed because new Debian packages are compressed with the xz algorithm and only the tar module of python3 supports this algorithm. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-25backports-update-manager: bump 4.1-rc1 to 4.1-rc8Luis R. Rodriguez
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-04-28devel: update the test kernelsHauke Mehrtens
2015-04-03devel: update the test kernelsbackports-20150222Hauke Mehrtens
2015-02-22devel: update the test kernelsHauke Mehrtens
2014-12-21devel: update the test kernelsbackports-20141201Hauke Mehrtens
2014-10-25devel: update the test kernelsHauke Mehrtens
2014-09-06backports: update test kernel versionsHauke Mehrtens
2014-08-09backports: update test kernel versionsbackports-20140808Hauke Mehrtens
This updates the kernel versions to test against to the most recent versions. Do not use 3.15.9, but 3.15.7 because there are some problems with the define UTS_UBUNTU_RELEASE_ABI in the more recent kernel version, see: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1347879 Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-17backports: update test kernel versionsv3.16-rc1-1backports-20140616Hauke Mehrtens
This adds kernel 3.16 and updates some other kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: update test kernel versionsHauke Mehrtens
This updates the kernel versions to test against to the most recent versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-05-01backports: devel/backports-update-manager: fix for older shutil.moveLuis R. Rodriguez
Older shutil.move does not seem to like it when there are symlinks on a target, to account for this and to make things clearer just split up the work on the lib/modules and usr/src directory. This fixes running devel/backports-update-manager on OpenSUSE 13.1 base install. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-05-01backports: add backports-update-manager binary requirementsLuis R. Rodriguez
2014-04-17backports: nuke support for kernels < 3.0Luis R. Rodriguez
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-02-08backports: update test kernel versionsHauke Mehrtens
2014-01-18backports: update kernel versionsHauke Mehrtens
Update to current versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-12-08backports: add Python based backports-update-managerLuis R. Rodriguez
This replaces the old shell scripts: * get-compat-kernels * get-compat-trees with a shiny central Python based backpor update manager: * backports-update-manager The new version provides a few features which were simply a difficult to implement and quite frankly pointless to try to implement in shell. Things worth mentioning: * This will now monitor your old directories and packages and remove any stale old directory or packages. You should feel comfortable with now just getting the latest code from the repo and always just running the script, it will do everything you wished it did for you. * This will always check the URLs and ensure your file size matches the target upstream size, we used to only check if you had the file or not * The compat-ksrc directory was renamed to ksrc-backports which goes inline with our rebranding crusade. The tool is smart enough to figure out if you had the old name and rename it for you. Its also smart enough to figure out if you had your old compat-ksrc as a symlink and preserve things just as you intended following the old real path. * The debs/ directory is now moved into ksrc-backports, making it easier to manage and detect what is or not part of backports. * I found no way to deal with objects to extract GNU archive items with Python, so we're stuck with requiring GNU ar, this provides a simple wrapper for our usage. * For the tree updater we instead or relying on Linus' tree to be a remote we leave it separately but always use --reference and allow users to provide their own --reference override for new clones. It should be easy to extend this should others have other custom work spaces through a config file or the like. * To keep backports up to date on a system after an initial run one should only need to run through a cronjob: backports-update-manager --force To only update the git trees: backports-update-manager --force --git-trees-only Relying on an continued update list is dumb though, in the future we should look into putting out new builds through without requiring GNU ar and also updating the list through a json file just as the kernel has its own now: https://www.kernel.org/releases.json Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
