Upstream commit: 72657d3ff7c144a85b0b916c81bfeaa54e2d623f
The folder name did not started with an v.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Upstream commit: 4fb89169e8a5969388b16771695452f55ceb43e6
Without this slash it wants to use the directory /backportsstable/
Upstream commit: 3455026991cda1129ae313830ecd7386f75362a5
the filename in kup put should end with a slash otherwise it tried to
overwrite this file.
Upstream commit: fdda21c96cc00461127a394e22eea3f7cb1119a5
Add a logging of the next command to be executed.
Upstream commit: efdb6bbb9cd89d3174dbdecf02b79c0f294e3d10
The full path has to be provided not just the new directory to create.
Upstream commit: 515e82602216fc40a224f02f34d0a0f0c03c8309
dir_to_tar could be the absolute path to the directory to to tar, but
we do not want the full patch in the tar, just the basename.
In addition the second close is not necessary.
Upstream commit: 10eca9f5bef1821de09601a3a7db7eb337c56ba0
This streamlines our release process making it easier for
transitioning releases onto other backport developers.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Upstream commit: ea70308d746325654d44851be602fe02492b59f9
This lets us throw at it whatever extra stuff we want.
Certain complex features that are backported may be be
limitted to a certain target build configuration. An example
can be if a backported feature is not yet backported with
support for lockdep. In order to avoid build failures with
these types of restrictions allow for specifying build
configuration dependencies on backported upstream kconfig
symbols other than just kernel versioning contstraints.
This adds support for specifying upstream kconfig constaints
other than kernel versioning by adding kconfig language
extensions on the dependencies file. This will update the
copied over upstream Kconfig file for the symbol specified
with the kconfig constraints specified.
When an automatic backport isn't included due to not
being used (see commit 6e0475b599217eceb8e01a1e572c,
"gentree: add automatic backports only if needed"),
selecting BACKPORT_USERSEL_BUILD_ALL will make the
build fail. Avoid this by disabling such symbols in
the Kconfig.
Make the python scripting compatible with python 3
(as tested with python 3.3). The patch library was
a bit tricky.
Having the kconfig code in a directory called "kconfig"
and having a file called "Kconfig" causes issues if the
code is ever stored on a case-insensitive filesystem.
Avoid these by just calling the kconfig directory kconf
instead.
I failed to see v2 patch.
This reverts commit 7f1b4e0258ade60670cf60f2bd46996005843cea.
instead.
This doesn't make sense since we'd have no way of knowing
when such a patch should be applied. Right now the patch
would be ignored, but make it extra obvious and error out
on such patches.
Without this change we were removing patch headers
when refreshing patches.
Cc: techtonik@gmail.com
There's a python git library, and our name conflicts
with it since it's also just called "git". I want to
use the python library (optionally) to speed up the
git accesses so this is now relevant.
The kernel's "make clean" will recurse into subdirectories, even
into those that aren't enabled in Kconfig. Thus, the previous
trick of changing symbols from CONFIG_* to IMPOSSIBLE_* doesn't
work any more. Change this to comment out the lines instead and
then support "make clean" and "make mrproper".
We don't want to compare the second-to-last letter with a
two-character string, that'll never be true anyway ... It
should compare the last two letters.
This first step in reorganising the header files moves all the
header files into a new backport-include/ directory that gets
priority over the regular include/ where we copy the files we
want to backport from the kernel. This will help split all the
header files into logical units.
While at it, move and rename compat_2.6.h and compat_autoconf.h
to backport/backport.h and backport/autoconf.h respectively.
At times we may want to disable a config option completely.
Add support for this. All you have to is list the config
on the depdependencies file with DISABLE instead of a kernel
version.
The Linux kernel uses srctree to help prefix header files
and scripts. When backporting we want to be able to override
driver's Makefiles' usage of srctree with our own. Since we
can't easily and sanely override the srctree itself without
causing a lot of issues just use the python generator to
do the change for us on the target Makefiles. This addresses
the srctree usage case and where ccflags was used without
prefixing any parent directory when used with drivers, the
kernel tends to fix that with addtree command.
[also remove now unnecessary patches]
This lets us provide a simple map of new drivers and old
drivers that it replaces at install time. This generates
a blacklist via the file:
/etc/modprobe.d/backports.conf
In output trees created with the git tracker, we avoid changing
the "versions" file all the time and just put "(see git)" into
the versions. However, it's useful to still be able to identify
it, and when using this the backport is (usually) built in the
git tree. Use this fact and add the git tree commit into a new
variable to put it into the MODULE_VERSION and also print it at
runtime.
If the automatic backports aren't selected by any
driver then they don't need to be added to the
output, so ignore them in that case.
Instead of copying drivers/base/hdmi.c to just hdmi.c copy it to
drivers-base-hdmi.c as there can be multiple files with the same
name (e.g. "core.c"). While at it, also fix this mechanism for
modules -- before having more than a single file for a module
would have caused multiple modules which clearly can't work, now
it's needed to give a #module-name and it will be added to the
Makefile correctly.
Instead of trying to infer the directory structure, which
was only used for verbose output and the git debug option,
just apply the patches on by one in the correct order.
Also warn if finding a .patch file that doesn't contain a
patch, just in case the patch library doesn't understand
some patches properly, for debugging purposes mostly.
This helps not have to ignore any other random
editor backup files etc.
Instead of manually copying code like HDMI and dma-buf,
add the ability to just specify such backports in the
Kconfig file for compat. This will then always update
to the lastest code as well.
The --git-revision option didn't handle file/dir renames
correctly, fix that.
This generally makes patches more readable to humans
and has no impact on the tools.
With the --git-revision option, that revision needs
to be used for the output version, not 'HEAD'.
Otherwise it keeps changing.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
When using the git-tracker, this is very useful.
There's no need to join a path with nothing ...
That will make it easier to use gentree and/or git
helpers from other scripts.
This enables users to more easily select the driver that
they need, and us to ship default configurations that we
prefer for that driver. Add iwlwifi as the first example.
It might not always have to go to stdout, so make
a function to print it and use that.
The recent shuffling broke the return value, return it.
Due to reordering the steps, the makefile and kconfig
mangling needs to be changed a bit, make it more robust.
Change the scripting a bit to make it possible to
import the gentree script as a module to call it.
This avoids accidentally copying files that are in the
local, possibly dirty, working directory.
Otherwise some patches might not apply, and anything
added in patches to the Kconfig won't work correctly.
Instead of having to have a checked-out kernel tree the
script can now read the files from a git revision when
passed the --git-revision <rev> argument. In this case
the kerneldir is taken as the git tree to use.
This helps when generating for multiple different trees.
Note that due to the need to invoke git many times this
is considerably slower than copying from a checkout. If
taking into account the time to create the checkout it's
still faster though.
If you get this wrong, it will error out while copying anyway.
