When using backports against for packaging with --gitdebug you either
have to use --clean or assume the directory is empty already. In either
case you start fresh. With integration this will be a bit different, you
could end up with a project directory where the git tree was present but
only the target directory was empty.
Calling git init on an already existing git directory will reinitialize
your git tree, that can reset some config stuff, let's avoid that.
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
The output directory is always the same as the project directory
for packaging backports but for integration these will differ,
to make introduction of integration easier to follow use the
outdir as both project directory and target directory and fold
the existing args.outdir under the backport identity object as
both "project_dir" and "target_dir".
This commit has no functional changes.
When integrating we need the BACKPORT prefix added to
dependency symbols.
The way we backport when packaging is to minimize the amount of
changes required by taking advantage of the fact that Kconfig
can treat CONFIG_ as an environment variable with getenv()
when parsing menu entries. When doing integration we don't want
to do this so instead we'll rely on the CONFIG_BACKPORT prefix.
This requires a bit of work on our current parsers, so to do that
identify the backport and provide that to helpers.
This also provides initial basic support for integration where no
additional code was required other than prefixes or ensuring certain
things are not done for integration. Before we expose integration
support we'll need to add quite a bit more things so this just assumes
integration is never desired.
We'll later want to do some modifications of symbols we backport
when integrating, but before we do any modification on kconfig
files we should keep track of the original source symbols.
This commit introduces no functional changes right now, it will
become more useful after we start adjusting kconfig entries
for integration.
Move packaging kconfig hacks to its own file, we'll be ignoring
this file later for postprocessing. Keeping this in a separate
file will make parsing much simpler.
This allows us to extend how backports uses patches for
different types of applications. This will later be used
for kernel integration support, for example.
This should have no functional change.
pycocci failure.
While running gentree.py I got error messages such as 'Failed to
process SmPL patch
collateral-evolutions/generic/0001-group-attr/0001-group_attr_class.cocci',
due to incorrect path handling. This patch always makes gentree always
call pycocci with the absolute path to the output directory.
Signed-off-by: Jacob Siverskog <jacob@teenageengineering.com>
My previous commit to restrict the defconfig files left
a debugging print statement, remove it.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
If a defconfig file has symbols that can't be satisfied
with the given copy-list file, then there's no point in
shipping it, so just copy selectively the ones needed.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
This lets us share it for general use as a generic tool, we'll upkeep
it here for now and if Coccinelle picks it up we can drop it and just
require folks to install it.
This lets us use the same solution for standard testing / regular
development and also for backports without any discrepencies.
Cc: Peter Senna <peter.senna@gmail.com>
Cc: Julia Lawall <julia.lawall@lip6.fr>
Cc: Gilles Muller <Gilles.Muller@lip6.fr>
This uses --use-coccigrep on our Cocccinelle library and removes
the CPU adjustments depending on whether we are testing or not.
The flag --use-coccigrep will tell Coccinelle to only kick off a
worker on a file until it has determined that a rule being
evaluated applies to a file. This does however mean that all files
on its bucket list will be evaluated first, but this yields better
CPU usage without having us to ramp up on the number of threads
depending on the situation. Without this patch we were kicking off
more threads to account for the fact that a Coccinelle thread will
stop working on a file if it had little or nothing to do on a file.
Possible work improvement: see how we can do away with tmp files
for Coccinelle output and just use memory to for the ouput, or
perhaps even disregard the stdout and only care for it if
--debug-cocci is provided.
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean
/home/mcgrof/linux-next /home/mcgrof/build/next-20140411
Copy original source files ...
Apply patches ...
Modify Kconfig tree ...
Rewrite Makefiles and Kconfig files ...
Done!
real 1m14.880s
user 10m47.824s
sys 0m36.796s
This optimization was introduced by Johannes to help with
performance before we had parallelism. With parallelism
we get better results by splitting rules up. Also some
feedback from Julia on this:
I don't think this is a good idea. You would have to be careful about
naming. And You may lose on some performance benefits of the prefiltering.
Suppose you have an easy semantic patch that references function A and a
hard semantic patch that references function B. The hard semantic patch
specifically contains one rule that is very complicated but that does not
use B. That very complicated rule will now be applied to the 5000 files
that use A as well as to the 3 files that use B. So you get a big
performance slowdown.
The performance before this change:
--refresh \
/home/mcgrof/linux-next /home/mcgrof/build/next-20140409
Apply patches ...
Done!
real 1m30.186s
user 9m25.180s
sys 0m24.428s
After:
Apply patches ...
Done!
real 1m3.071s
user 3m39.388s
sys 0m21.812s
commit 3c71184d3a2843c9a1d5a289c71bfbbc126d71fd
Author: Johannes Berg <johannes.berg@intel.com>
Date: Wed Jan 1 20:37:13 2014 +0100
gentree: combine spatches (unless using --gitdebug)
Since spatch is rather slow, but can handle multiple spatches
concatenated in a single file, just do that and run it only
once rather than for each spatch. That shaves off some of the
runtime (startup etc. and finding affected files.)
On my system, I go from
real 9m42.616s
user 8m48.352s
sys 0m22.884s
to
real 9m1.948s
user 8m40.108s
sys 0m12.088s
Apply patches ...
Done!
real 1m30.186s
user 9m25.180s
sys 0m24.428s
mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.54 [ OK ]
4 3.3.8 [ OK ]
5 3.4.79 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.29 [ OK ]
12 3.11.10 [ OK ]
13 3.12.10 [ OK ]
14 3.13.2 [ OK ]
15 3.14-rc1 [ OK ]
real 26m54.859s
user 744m15.764s
sys 83m47.440s
This adds support to let you pass --profile when running Coccinelle.
This will skip all patches, rewriting Makefiles, Kconfigs, etc, and
it will also keep a copy of the original src directory prior to
applying the spatch. You pass the spatch file as an argument when
using this.
Screenshot of relevant output on 11-dev-pm-ops.cocci:
$ time ./gentree.py --clean --verbose --profile-cocci 11-dev-pm-ops.cocci \
/home/mcgrof/linux-next/ \
/home/mcgrof/build/backports-20140311
Apply patches ...
Profiling Coccinelle SmPL patch: 11-dev-pm-ops.cocci
Applying SmPL patch collateral-evolutions/network/11-dev-pm-ops.cocci
> init_defs_builtins: /usr/local/share/coccinelle/standard.h
> warning: line 15: should pci be a metavariable?
> (ONCE) Expected tokens pm pci_driver driver pci SIMPLE_DEV_PM_OPS
> MODULE_DEVICE_TABLE
> Skipping:./net/mac802154/ieee802154_dev.c
> Skipping:./net/mac802154/mac_cmd.c
> Skipping:./net/mac802154/mib.c
> Skipping:./net/mac802154/monitor.c
> Skipping:./net/mac802154/rx.c
> Skipping:./net/mac802154/tx.c
> Skipping:./net/mac802154/wpan.c
> starting: Common.group_assoc_bykey_eff
> ending: Common.group_assoc_bykey_eff, 0.000114s
> profiling result
> Main total : 0.584 sec 1 count
> parse cocci : 0.422 sec 1 count
> pre_engine : 0.422 sec 1 count
> Main.infiles computation : 0.156 sec 1 count
> HACK : 0.069 sec 1 count
> C parsing.tokens : 0.043 sec 1 count
> C parsing.fix_define : 0.022 sec 1 count
> get_glimpse_constants : 0.021 sec 1 count
> C parsing.lex_ident : 0.006 sec 673 count
> Common.full_charpos_to_pos_large : 0.006 sec 1 count
> Main.outfiles computation : 0.004 sec 1 count
> worth_trying : 0.004 sec 7 count
> Common.full_charpos_to_pos : 0.003 sec 2 count
> Common.=~ : 0.000 sec 4 count
> check_duplicate : 0.000 sec 1 count
> Main.result analysis : 0.000 sec 1 count
> Common.group_assoc_bykey_eff : 0.000 sec 1 count
> asttoctl2 : 0.000 sec 1 count
> post_engine : 0.000 sec 1 count
> show_xxx : 0.000 sec 2 count
This goes on... and a page per thread spawned and the results will be
specific to the files tha the thread worked on. On the above results
we can see Coccinelle spent little to no time working on the above
files as it determined it had nothing to do there.
On big iron backports server:
real 0m31.226s
user 7m25.712s
sys 0m34.492s
You can just pass now one cocci file with the --test-cocci to test
only that single Coccinelle SmPL patch. If you are not sure what
an SmPL patch produces and you only want to study the results of
applying only a single SmPL patch you can use this flag to trigger
enabling git on the target directory, a commit will be done before
applying the SmPL patch and then another commit will be performed
after the SmPL patch is applied. You can then use git show as you'd
expect to inspect the results.
Note that if you don't use --test-cocci and run gentree.py regularly
you can always still use --git-debug to see atomically what is happening
after each patch, including Coccinelle patches.
This modifies the coccinelle library to use 10 * num_cpus threads
for when in testing Coccinelle mode.
$ time ./gentree.py --clean --verbose --test-cocci 11-dev-pm-ops.cocci \
/home/mcgrof/build/next-20140311
real 0m28.964s
user 6m57.848s
sys 0m25.124s
Note that you can pass either a full path or the file name alone
of the target Coccinelle SmPL patch you want to test.
Turns out Coccinelle has threaded support, it lets you
break down the target code you need to parse for a spatch
file into separate buckets, each bucket handling a subset of
the target files needed to be evaluated. This adds support
for that and shaves down the amount of time it gets to
generate target code by 97.19%.
Using:
mcgrof@drvbp1 ~/backports (git::master)$ time \
./gentree.py --verbose \
--clean \
--refresh \
Before this patch:
real 19m34.867s
user 18m43.492s
sys 0m21.244s
After this patch by using num_cpus threads:
real 2m42.012s
user 21m53.616s
sys 0m22.748s
After this patch by using 3 * num_cpus threads:
real 1m33.316s
user 24m6.080s
sys 0m28.264s
Using num_cpus threads alone was giving 2m42.012s, its why I
experimented in increasing this. I also experimented with
6 * num_cpus threads as well but the amount of time spent
running didn't reduce, lets keep this at 3 * num_cpus for now
and we can experiment and empirically find the best setting for
any system or just make this configurable.
We had SmPL patch integration first committed via
86d99c9d4 back then we were able to scale to a reasonable
similar time:
mcgrof@drvbp1 ~/backports (git::cocci-added)$ time \
./gentree.py --verbsose \
--clean \
--refresh \
/home/mcgrof/build/next-20131113
real 1m1.967s
user 0m49.304s
sys 0m11.880s
For history's purpose here's our run time without Coccinelle on
commit 338c4388cc:
mcgrof@drvbp1 ~/backports (git::before-smpl)$ time \
--clean \
--refresh \
/home/mcgrof/build/next-20131029
real 0m29.639s
user 0m17.508s
sys 0m11.568s
This new changes sets us back on track with the timing for when we first
introduced Coccinelle support we just have a lot 5 Coccinelle patches
now. I hope this shows we should be able to scale with Coccinelle much more
efficiently for collateral evolutions that sprinkle through tons of
files.
Screenshots available using htop before [0] and after the patch [1]
while coccinelle is running, this shows how the system is using
resources much more efficiently when doing spatch evaluation for
patch generation on target code.
[0] http://drvbp1.linux-foundation.org/~mcgrof/images/coccinelle-backports/before-threaded-cocci.png
[1] http://drvbp1.linux-foundation.org/~mcgrof/images/coccinelle-backports/after-threaded-cocci.png
kernel.org does not support bzip2 any more, use gzip instead.
real 9m42.616s
user 8m48.352s
sys 0m22.884s
to
real 9m1.948s
user 8m40.108s
sys 0m12.088s
Introduce the infrastructure to apply semantic patches
and make use of it for the (frequently breaking) portid
patch for netlink.
Unfortunately this is significantly slower:
before:
real 0m14.312s
user 0m12.144s
sys 0m1.784s
after:
real 0m25.932s
user 0m21.768s
sys 0m2.932s
The folder name did not started with an v.
Without this slash it wants to use the directory /backportsstable/
the filename in kup put should end with a slash otherwise it tried to
overwrite this file.
Add a logging of the next command to be executed.
The full path has to be provided not just the new directory to create.
dir_to_tar could be the absolute path to the directory to to tar, but
we do not want the full patch in the tar, just the basename.
In addition the second close is not necessary.
This streamlines our release process making it easier for
transitioning releases onto other backport developers.
This lets us throw at it whatever extra stuff we want.
Certain complex features that are backported may be be
limitted to a certain target build configuration. An example
can be if a backported feature is not yet backported with
support for lockdep. In order to avoid build failures with
these types of restrictions allow for specifying build
configuration dependencies on backported upstream kconfig
symbols other than just kernel versioning contstraints.
This adds support for specifying upstream kconfig constaints
other than kernel versioning by adding kconfig language
extensions on the dependencies file. This will update the
copied over upstream Kconfig file for the symbol specified
with the kconfig constraints specified.
When an automatic backport isn't included due to not
being used (see commit 6e0475b599217eceb8e01a1e572c,
"gentree: add automatic backports only if needed"),
selecting BACKPORT_USERSEL_BUILD_ALL will make the
build fail. Avoid this by disabling such symbols in
the Kconfig.
Make the python scripting compatible with python 3
(as tested with python 3.3). The patch library was
a bit tricky.
Having the kconfig code in a directory called "kconfig"
and having a file called "Kconfig" causes issues if the
code is ever stored on a case-insensitive filesystem.
Avoid these by just calling the kconfig directory kconf
instead.
I failed to see v2 patch.
This reverts commit 7f1b4e0258ade60670cf60f2bd46996005843cea.
instead.
This doesn't make sense since we'd have no way of knowing
when such a patch should be applied. Right now the patch
would be ignored, but make it extra obvious and error out
on such patches.
Without this change we were removing patch headers
when refreshing patches.
Cc: techtonik@gmail.com
There's a python git library, and our name conflicts
with it since it's also just called "git". I want to
use the python library (optionally) to speed up the
git accesses so this is now relevant.
The kernel's "make clean" will recurse into subdirectories, even
into those that aren't enabled in Kconfig. Thus, the previous
trick of changing symbols from CONFIG_* to IMPOSSIBLE_* doesn't
work any more. Change this to comment out the lines instead and
then support "make clean" and "make mrproper".
We don't want to compare the second-to-last letter with a
two-character string, that'll never be true anyway ... It
should compare the last two letters.
This first step in reorganising the header files moves all the
header files into a new backport-include/ directory that gets
priority over the regular include/ where we copy the files we
want to backport from the kernel. This will help split all the
header files into logical units.
While at it, move and rename compat_2.6.h and compat_autoconf.h
to backport/backport.h and backport/autoconf.h respectively.
At times we may want to disable a config option completely.
Add support for this. All you have to is list the config
on the depdependencies file with DISABLE instead of a kernel
version.
The Linux kernel uses srctree to help prefix header files
and scripts. When backporting we want to be able to override
driver's Makefiles' usage of srctree with our own. Since we
can't easily and sanely override the srctree itself without
causing a lot of issues just use the python generator to
do the change for us on the target Makefiles. This addresses
the srctree usage case and where ccflags was used without
prefixing any parent directory when used with drivers, the
kernel tends to fix that with addtree command.
[also remove now unnecessary patches]
This lets us provide a simple map of new drivers and old
drivers that it replaces at install time. This generates
a blacklist via the file:
/etc/modprobe.d/backports.conf
In output trees created with the git tracker, we avoid changing
the "versions" file all the time and just put "(see git)" into
the versions. However, it's useful to still be able to identify
it, and when using this the backport is (usually) built in the
git tree. Use this fact and add the git tree commit into a new
variable to put it into the MODULE_VERSION and also print it at
runtime.
If the automatic backports aren't selected by any
driver then they don't need to be added to the
output, so ignore them in that case.
Instead of copying drivers/base/hdmi.c to just hdmi.c copy it to
drivers-base-hdmi.c as there can be multiple files with the same
name (e.g. "core.c"). While at it, also fix this mechanism for
modules -- before having more than a single file for a module
would have caused multiple modules which clearly can't work, now
it's needed to give a #module-name and it will be added to the
Makefile correctly.
Instead of trying to infer the directory structure, which
was only used for verbose output and the git debug option,
just apply the patches on by one in the correct order.
Also warn if finding a .patch file that doesn't contain a
patch, just in case the patch library doesn't understand
some patches properly, for debugging purposes mostly.
This helps not have to ignore any other random
editor backup files etc.
