path: root/gentree.py
2017-02-06gentree: create Kconfig.local, use it to restrict compatJohannes Berg
Not all the compat code is always necessary, for example code enabled by BPAUTO_CRYPTO_SKCIPHER and by BPAUTO_RHASHTABLE is gated on other symbols being selected. Checking against the Kconfig symbols as it's done right now is wrong though, since the base kernel's Kconfig symbols would be used, selecting, for example, BPAUTO_CRYPTO_SKCIPHER when the base kernel has CONFIG_BT set, but doing that when BT isn't even part of the backport, or when it's disabled in the backport. To fix this, keep track of all the local Kconfig symbols, similar to the .local-symbols files but as a Kconfig.local, and add for each local symbol a symbol that just mirrors the state of the symbol as selected by the user. This effectively allows checking the source of the symbol. Make the relevant backported items use the new BACKPORTED_* symbols for dependencies, instead of the original ones, thus avoiding the above-mentioned "leakage" of kernel symbols. When the symbol isn't even present in the backport, it'll be simply regarded as false by the kconfig system. Reported-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-02-06gentree: don't throw exceptions when applying patches failLuca Coelho
In commit 4e84c2d807d5 ("backports: move legacy and SmPL patch application into helper"), the functionality was changed by raising exceptions instead of return an error when applying patches fail. This breaks git-tracker, because it expects errors to be returned in such cases, to exit gracefully and print the error messages. Fixes: 4e84c2d807d5 ("backports: move legacy and SmPL patch application into helper") Signed-off-by: Luca Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2016-11-15backports: rename .local-symbols to local-symbolsJohannes Berg
Remove the leading . in the file, which has tripped up people a few times already because it's hidden, and not always copied. Change-Id: I48729af712f01b56cf43c4982321b989e33259f3 Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2016-07-13gentree.py: print some more error messages when spatch fails.Hauke Mehrtens
I saw some problems here, add more debug output. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07gentree: fix Makefile symbol disablingJohannes Berg
Currently, a Makefile line like this: obj-$(CONFIG_IPW2100) += ipw2x00/ will get mangled into #obj-$(CONFIG_IPW2100+= ipw2x00/ when disabled by the gentree script. Fix the regular expression to contain the entire match as the first group, so it gets all preserved when replaced later by "#\1" using expression.sub(). This then makes it come out as #obj-$(CONFIG_IPW2100) += ipw2x00/ Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-11backports: fix incorrect disabling of CONFIG optionsStefan Assmann
gentree.py incorrectly disabled CONFIG options that share part of the name with another already disabled CONFIG option. For example if CONFIG_E100 was disabled you no longer could enable CONFIG_E1000 or CONFIG_E1000E. Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-22backports: require coccinelle version 1.0.0-rc24Stefan Assmann
The new more generic ethernet patches require spatch 1.0.0-rc24. Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-11-18backports: fix breakage from integration patchsetJohannes Berg
Various small things broken in the integration patchset, fix them to actually make backports useful again. For example, a driver using devcoredump wouldn't have worked without these changes as it would depend on devcoredump, and that wasn't backported due to the bugs, despite being in the backport Kconfig file. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-11-14backports: add full kernel integration supportLuis R. Rodriguez
This enables support for using the backports project to integrate device drivers from a future version of Linux into an older version of Linux. What you end up seeing is a backports submenu when configuring your kernel and the ability to select specific device drivers from subsystems supported through the Linux backports project. At this time enabling one device driver from a future version of Linux will require using only the latest version of the subsystem modules and other subsystem drivers. For example enabling cfg80211 and mac80211 from a future version of Linux will require you to only use future version of the respective device drivers. In order to enable the backported version of 802.11 drivers for example, you will have to enable first: Networking support --> Wireless --> But under that menu disable all options, then jump to the backports submenu to now enable: Backports --> cfg80211 mac80211 Wireless LAN ---> etc You build these device drivers modular or built-in to the kernel. Integration support requires only slight modifications to the original kernel sources, one to the top level Kconfig to add our entry, and also the top level Makefile to enable backports code to be part of the built-in vmlinux. Support for integration takes advantage over the existing infrastructure added by Johannes to keep track of each indvidual change done by the backports infrastructure if --gitdebug is used. mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean \ /home/mcgrof/linux-next /home/mcgrof/build/backports-20141023 Copy original source files ... Applying patches from patches to /home/mcgrof/build/backports-20141023 ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m27.942s user 13m23.752s sys 0m47.608s 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.104 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.58 [ OK ] 12 3.11.10 [ OK ] 13 3.12.31 [ OK ] 14 3.13.11 [ OK ] 15 3.14.22 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.1 [ OK ] 19 3.18-rc1 [ OK ] real 42m44.838s user 1190m5.092s sys 140m37.208s Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: remove extra BACKPORT_ prefix from kernel versioningLuis R. Rodriguez
The CPTCFG_ prefix already implies backport, when integration is used we'd end up with a double BACKPORT_ prefix, so just remove the existing one as its not needed. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: prefix c-file / h-file auto backport with BPAUTOLuis R. Rodriguez
Things we backport are now prefixed with BACKPORT_, when we copy over libraries with the c-files / h-files trick on the compat/Kconfig trick we prefix these with BACKPORT_ already so in order to help distinguish them use BACKPORT_BPAUTO_ for them and prevent a double BACKPORT_ prefix. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: add backport version parsing for kernel integrationLuis R. Rodriguez
The way we'll define backports versioning information for kernel integration is slightly different, we'll rely completely on Kconfig for the job, but in the end share the same C code defines. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: move version file generation to run earlierLuis R. Rodriguez
The version file contains: * BACKPORTS_VERSION * BACKPORTED_KERNEL_VERSION * BACKPORTED_KERNEL_NAME This file is used by the Makefile to export variable definitions used to identify the backport. For kernel integration we'll be using a generated Kconfig file instead and since these are needed when processing kconfig logic this will need to be defined earlier. Just move the generation of the version file for packaging up early to match where we will generate the Kconfig with the backports versioning identification. This change has no real functional change other than the move of some code running earlier. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: split Kconfig into Kconfig.package and Kconfig.sourcesLuis R. Rodriguez
This splits up the Kconfig from things which are needed due to our copy of code from the kernel and things which we need specifically only for packaging backports. We will later then share the Kconfig.souce for instance for kernel integration. While at it, split up the list of files that we need to copy into what we know could be shared for integration. The the case of backport packaging Kconfig.package will be copied to the package's Kconfig when building the package with gentree.py. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: use BACKPORT_DIR prefix on kconfig sourcesLuis R. Rodriguez
This will allow us to do less work for built-in integration support. When packaging we only use BACKPORT_DIR for Kconfig sources we control, to avoid a large change we avoid doing this for other Kconfig files. For integration we'll always have to use BACKPORT_DIR on kconfig sources. Suporting requires a bit of self evaluation of the variable within our kconfig library, ideally we'd have support for groking all variables defined within the Kconfig setup but that requires quite a lot more work as it means also parsing Makefiles and inheriting these definitions within config symbols when used. Since we only define one right now and its used for built-in support we deal with it ourselves for now. Please consider the complexity of adding others, it doesn't seem like there would be much need for others though. If others wanted to use a different BACKPORT_DIR path other than 'backports' that would require tweaking here, but we'll start by assuming no one will want to do that. $ time /home/mcgrof/backports/devel/ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.104 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.58 [ OK ] 12 3.11.10 [ OK ] 13 3.12.31 [ OK ] 14 3.13.11 [ OK ] 15 3.14.22 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.1 [ OK ] 19 3.18-rc1 [ OK ] real 42m41.825s user 1187m38.880s sys 141m11.760s Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: modify kconfig parser to use bpid and target_dirLuis R. Rodriguez
The kconfig parser sets a base directory using the directory in which the Kconfig file passed lives in. This strategy assumes the kernel uses relative paths, while this is truly supported in practice though upstream only deals with full paths based on the actual root directory of the kernel. Its safer, cleaner and much simpler to support full paths, and since the kernel uses full paths anyway lets stick to that and complain when relative paths are found. This also modifies our own provided Kconfig to use full paths as well, we'll need this later to adjust our Kconfigs for kernel integration. $ time /home/mcgrof/backports/devel/ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.104 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.58 [ OK ] 12 3.11.10 [ OK ] 13 3.12.31 [ OK ] 14 3.13.11 [ OK ] 15 3.14.22 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.1 [ OK ] 19 3.18-rc1 [ OK ] real 44m3.002s user 1188m20.708s sys 140m25.540s Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: avoid git tree reinitializationLuis R. Rodriguez
When using backports against for packaging with --gitdebug you either have to use --clean or assume the directory is empty already. In either case you start fresh. With integration this will be a bit different, you could end up with a project directory where the git tree was present but only the target directory was empty. Calling git init on an already existing git directory will reinitialize your git tree, that can reset some config stuff, let's avoid that. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: fold outdir as a backport identity targetLuis R. Rodriguez
The output directory is always the same as the project directory for packaging backports but for integration these will differ, to make introduction of integration easier to follow use the outdir as both project directory and target directory and fold the existing args.outdir under the backport identity object as both "project_dir" and "target_dir". This commit has no functional changes. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: add prefix for integration on dependenciesLuis R. Rodriguez
When integrating we need the BACKPORT prefix added to dependency symbols. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: allow for different backport prefix and simple integration supportLuis R. Rodriguez
The way we backport when packaging is to minimize the amount of changes required by taking advantage of the fact that Kconfig can treat CONFIG_ as an environment variable with getenv() when parsing menu entries. When doing integration we don't want to do this so instead we'll rely on the CONFIG_BACKPORT prefix. This requires a bit of work on our current parsers, so to do that identify the backport and provide that to helpers. This also provides initial basic support for integration where no additional code was required other than prefixes or ensuring certain things are not done for integration. Before we expose integration support we'll need to add quite a bit more things so this just assumes integration is never desired. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: keep track of original backported source symbols early onLuis R. Rodriguez
We'll later want to do some modifications of symbols we backport when integrating, but before we do any modification on kconfig files we should keep track of the original source symbols. This commit introduces no functional changes right now, it will become more useful after we start adjusting kconfig entries for integration. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: move packaging kconfig hacks to its own fileLuis R. Rodriguez
Move packaging kconfig hacks to its own file, we'll be ignoring this file later for postprocessing. Keeping this in a separate file will make parsing much simpler. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: move legacy and SmPL patch application into helperLuis R. Rodriguez
This allows us to extend how backports uses patches for different types of applications. This will later be used for kernel integration support, for example. This should have no functional change. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-09-06backports: always use absolute path to output directory, less probability of ↵backports-20140822Jacob Siverskog
pycocci failure. While running gentree.py I got error messages such as 'Failed to process SmPL patch collateral-evolutions/generic/0001-group-attr/0001-group_attr_class.cocci', due to incorrect path handling. This patch always makes gentree always call pycocci with the absolute path to the output directory. Signed-off-by: Jacob Siverskog <jacob@teenageengineering.com>
2014-06-01gentree: remove stray printJohannes Berg
My previous commit to restrict the defconfig files left a debugging print statement, remove it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-05-01backports: add gentree.py binary requirementsLuis R. Rodriguez
2014-05-01gentree: strip useless defconfig filesJohannes Berg
If a defconfig file has symbols that can't be satisfied with the given copy-list file, then there's no point in shipping it, so just copy selectively the ones needed. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: pycocci - make the Coccinelle wrapper a standalone toolLuis R. Rodriguez
This lets us share it for general use as a generic tool, we'll upkeep it here for now and if Coccinelle picks it up we can drop it and just require folks to install it. This lets us use the same solution for standard testing / regular development and also for backports without any discrepencies. Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: use --use-coccigrep for CoccinelleLuis R. Rodriguez
This uses --use-coccigrep on our Cocccinelle library and removes the CPU adjustments depending on whether we are testing or not. The flag --use-coccigrep will tell Coccinelle to only kick off a worker on a file until it has determined that a rule being evaluated applies to a file. This does however mean that all files on its bucket list will be evaluated first, but this yields better CPU usage without having us to ramp up on the number of threads depending on the situation. Without this patch we were kicking off more threads to account for the fact that a Coccinelle thread will stop working on a file if it had little or nothing to do on a file. Possible work improvement: see how we can do away with tmp files for Coccinelle output and just use memory to for the ouput, or perhaps even disregard the stdout and only care for it if --debug-cocci is provided. mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140411 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m14.880s user 10m47.824s sys 0m36.796s Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: revert unification of cocci filesLuis R. Rodriguez
This optimization was introduced by Johannes to help with performance before we had parallelism. With parallelism we get better results by splitting rules up. Also some feedback from Julia on this: === I don't think this is a good idea. You would have to be careful about naming. And You may lose on some performance benefits of the prefiltering. Suppose you have an easy semantic patch that references function A and a hard semantic patch that references function B. The hard semantic patch specifically contains one rule that is very complicated but that does not use B. That very complicated rule will now be applied to the 5000 files that use A as well as to the 3 files that use B. So you get a big performance slowdown. === The performance before this change: mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean --refresh \ /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s After: mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140411 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m3.071s user 3m39.388s sys 0m21.812s commit 3c71184d3a2843c9a1d5a289c71bfbbc126d71fd Author: Johannes Berg <johannes.berg@intel.com> Date: Wed Jan 1 20:37:13 2014 +0100 gentree: combine spatches (unless using --gitdebug) Since spatch is rather slow, but can handle multiple spatches concatenated in a single file, just do that and run it only once rather than for each spatch. That shaves off some of the runtime (startup etc. and finding affected files.) On my system, I go from real 9m42.616s user 8m48.352s sys 0m22.884s to real 9m1.948s user 8m40.108s sys 0m12.088s Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: nuke support for kernels < 3.0Luis R. Rodriguez
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: add Coccinelle SmPL profiling support to gentree.pyLuis R. Rodriguez
This adds support to let you pass --profile when running Coccinelle. This will skip all patches, rewriting Makefiles, Kconfigs, etc, and it will also keep a copy of the original src directory prior to applying the spatch. You pass the spatch file as an argument when using this. Screenshot of relevant output on 11-dev-pm-ops.cocci: $ time ./gentree.py --clean --verbose --profile-cocci 11-dev-pm-ops.cocci \ /home/mcgrof/linux-next/ \ /home/mcgrof/build/backports-20140311 Copy original source files ... Apply patches ... Profiling Coccinelle SmPL patch: 11-dev-pm-ops.cocci Applying SmPL patch collateral-evolutions/network/11-dev-pm-ops.cocci > init_defs_builtins: /usr/local/share/coccinelle/standard.h > warning: line 15: should pci be a metavariable? > (ONCE) Expected tokens pm pci_driver driver pci SIMPLE_DEV_PM_OPS > MODULE_DEVICE_TABLE > Skipping:./net/mac802154/ieee802154_dev.c > Skipping:./net/mac802154/mac_cmd.c > Skipping:./net/mac802154/mib.c > Skipping:./net/mac802154/monitor.c > Skipping:./net/mac802154/rx.c > Skipping:./net/mac802154/tx.c > Skipping:./net/mac802154/wpan.c > starting: Common.group_assoc_bykey_eff > ending: Common.group_assoc_bykey_eff, 0.000114s > --------------------- > profiling result > --------------------- > Main total : 0.584 sec 1 count > parse cocci : 0.422 sec 1 count > pre_engine : 0.422 sec 1 count > Main.infiles computation : 0.156 sec 1 count > HACK : 0.069 sec 1 count > C parsing.tokens : 0.043 sec 1 count > C parsing.fix_define : 0.022 sec 1 count > get_glimpse_constants : 0.021 sec 1 count > C parsing.lex_ident : 0.006 sec 673 count > Common.full_charpos_to_pos_large : 0.006 sec 1 count > Main.outfiles computation : 0.004 sec 1 count > worth_trying : 0.004 sec 7 count > Common.full_charpos_to_pos : 0.003 sec 2 count > Common.=~ : 0.000 sec 4 count > check_duplicate : 0.000 sec 1 count > Main.result analysis : 0.000 sec 1 count > Common.group_assoc_bykey_eff : 0.000 sec 1 count > asttoctl2 : 0.000 sec 1 count > post_engine : 0.000 sec 1 count > show_xxx : 0.000 sec 2 count This goes on... and a page per thread spawned and the results will be specific to the files tha the thread worked on. On the above results we can see Coccinelle spent little to no time working on the above files as it determined it had nothing to do there. On big iron backports server: real 0m31.226s user 7m25.712s sys 0m34.492s Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: add support for testing only a single Coccinelle SmPL patchLuis R. Rodriguez
You can just pass now one cocci file with the --test-cocci to test only that single Coccinelle SmPL patch. If you are not sure what an SmPL patch produces and you only want to study the results of applying only a single SmPL patch you can use this flag to trigger enabling git on the target directory, a commit will be done before applying the SmPL patch and then another commit will be performed after the SmPL patch is applied. You can then use git show as you'd expect to inspect the results. Note that if you don't use --test-cocci and run gentree.py regularly you can always still use --git-debug to see atomically what is happening after each patch, including Coccinelle patches. This modifies the coccinelle library to use 10 * num_cpus threads for when in testing Coccinelle mode. $ time ./gentree.py --clean --verbose --test-cocci 11-dev-pm-ops.cocci \ /home/mcgrof/linux-next/ \ /home/mcgrof/build/next-20140311 real 0m28.964s user 6m57.848s sys 0m25.124s Note that you can pass either a full path or the file name alone of the target Coccinelle SmPL patch you want to test. Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: add threaded Coccinelle spatch supportLuis R. Rodriguez
Turns out Coccinelle has threaded support, it lets you break down the target code you need to parse for a spatch file into separate buckets, each bucket handling a subset of the target files needed to be evaluated. This adds support for that and shaves down the amount of time it gets to generate target code by 97.19%. Using: mcgrof@drvbp1 ~/backports (git::master)$ time \ ./gentree.py --verbose \ --clean \ --refresh \ /home/mcgrof/linux-next/ \ /home/mcgrof/build/next-20140311 Before this patch: real 19m34.867s user 18m43.492s sys 0m21.244s After this patch by using num_cpus threads: real 2m42.012s user 21m53.616s sys 0m22.748s After this patch by using 3 * num_cpus threads: real 1m33.316s user 24m6.080s sys 0m28.264s Using num_cpus threads alone was giving 2m42.012s, its why I experimented in increasing this. I also experimented with 6 * num_cpus threads as well but the amount of time spent running didn't reduce, lets keep this at 3 * num_cpus for now and we can experiment and empirically find the best setting for any system or just make this configurable. We had SmPL patch integration first committed via 86d99c9d4 back then we were able to scale to a reasonable similar time: mcgrof@drvbp1 ~/backports (git::cocci-added)$ time \ ./gentree.py --verbsose \ --clean \ --refresh \ /home/mcgrof/linux-next /home/mcgrof/build/next-20131113 real 1m1.967s user 0m49.304s sys 0m11.880s For history's purpose here's our run time without Coccinelle on commit 338c4388cc: mcgrof@drvbp1 ~/backports (git::before-smpl)$ time \ ./gentree.py --verbose \ --clean \ --refresh \ /home/mcgrof/linux-next/ \ /home/mcgrof/build/next-20131029 real 0m29.639s user 0m17.508s sys 0m11.568s This new changes sets us back on track with the timing for when we first introduced Coccinelle support we just have a lot 5 Coccinelle patches now. I hope this shows we should be able to scale with Coccinelle much more efficiently for collateral evolutions that sprinkle through tons of files. Screenshots available using htop before [0] and after the patch [1] while coccinelle is running, this shows how the system is using resources much more efficiently when doing spatch evaluation for patch generation on target code. [0] http://drvbp1.linux-foundation.org/~mcgrof/images/coccinelle-backports/before-threaded-cocci.png [1] http://drvbp1.linux-foundation.org/~mcgrof/images/coccinelle-backports/after-threaded-cocci.png Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-01-18gentree: create *.tar.gz instead of *.tar.bz for kernel.orgbackports-20131224-2Hauke Mehrtens
kernel.org does not support bzip2 any more, use gzip instead. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-18gentree: combine spatches (unless using --gitdebug)Johannes Berg
Since spatch is rather slow, but can handle multiple spatches concatenated in a single file, just do that and run it only once rather than for each spatch. That shaves off some of the runtime (startup etc. and finding affected files.) On my system, I go from real 9m42.616s user 8m48.352s sys 0m22.884s to real 9m1.948s user 8m40.108s sys 0m12.088s Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-31backports: replace netlink portid by semantic patchJohannes Berg
Introduce the infrastructure to apply semantic patches and make use of it for the (frequently breaking) portid patch for netlink. Unfortunately this is significantly slower: before: real 0m14.312s user 0m12.144s sys 0m1.784s after: real 0m25.932s user 0m21.768s sys 0m2.932s Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-28gentree.py: add v as prefix for stable folder nameHauke Mehrtens
The folder name did not started with an v. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-28genlib: add missing slash to korg_path for stableHauke Mehrtens
Without this slash it wants to use the directory /backportsstable/ Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: add ending slash to upload pathHauke Mehrtens
the filename in kup put should end with a slash otherwise it tried to overwrite this file. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: log kup command before executingHauke Mehrtens
Add a logging of the next command to be executed. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: fix directory creatingHauke Mehrtens
The full path has to be provided not just the new directory to create. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: do not add full path into tarHauke Mehrtens
dir_to_tar could be the absolute path to the directory to to tar, but we do not want the full patch in the tar, just the basename. In addition the second close is not necessary. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: add kernel upload supportLuis R. Rodriguez
This streamlines our release process making it easier for transitioning releases onto other backport developers. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgit.py: enable extra arguments on git describeLuis R. Rodriguez
This lets us throw at it whatever extra stuff we want. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-29backports: enable kconfig language on dependencies fileLuis R. Rodriguez
Certain complex features that are backported may be be limitted to a certain target build configuration. An example can be if a backported feature is not yet backported with support for lockdep. In order to avoid build failures with these types of restrictions allow for specifying build configuration dependencies on backported upstream kconfig symbols other than just kernel versioning contstraints. This adds support for specifying upstream kconfig constaints other than kernel versioning by adding kconfig language extensions on the dependencies file. This will update the copied over upstream Kconfig file for the symbol specified with the kconfig constraints specified. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-23backport: disable unused automatic backportsJohannes Berg
When an automatic backport isn't included due to not being used (see commit 6e0475b599217eceb8e01a1e572c, "gentree: add automatic backports only if needed"), selecting BACKPORT_USERSEL_BUILD_ALL will make the build fail. Avoid this by disabling such symbols in the Kconfig. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05gentree/git-tracker: make python 3 compatibleJohannes Berg
Make the python scripting compatible with python 3 (as tested with python 3.3). The patch library was a bit tricky. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-28backport: move kconfig code to "kconf" directoryJohannes Berg
Having the kconfig code in a directory called "kconfig" and having a file called "Kconfig" causes issues if the code is ever stored on a case-insensitive filesystem. Avoid these by just calling the kconfig directory kconf instead. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-28Revert "backport: move kconfig code to "kconf" directory"Luis R. Rodriguez
I failed to see v2 patch. This reverts commit 7f1b4e0258ade60670cf60f2bd46996005843cea.
