path: root/lib
2013-10-21lib/bpkup.py: add or own kernel uploader helper libLuis R. Rodriguez
kup is written in perl, add some basic python interfaces for it to allow us to upload to kernel.org backport releases. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgpg.py: add simple gpg helper for gpg signingLuis R. Rodriguez
Note that kup expects --armor --detach-sign, we'll pass that as part of our extra_args. The python gpg lib doesn't provide support for random arguments as this one, so just add our own little helper and carry it over. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgit.py: add support for git paranoiaLuis R. Rodriguez
This cleans sanitizes a source tree and ensures no content is present from what was intended. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgit.py: add git tree verification supportLuis R. Rodriguez
This verifies that the tree provided has its last commit both tagged and also digitally signed. In short it does: git tag -v $(git describe --dirty) This will be used later. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgit.py: add git clean supportLuis R. Rodriguez
We'll use this later. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgit.py: add git status supportLuis R. Rodriguez
We use --porcelain given that this spits out the results in an easy-to-parse format for scripts and will remain stable across git versions and regardless of user configuration. We will use this later. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgit.py: enable extra arguments on git describeLuis R. Rodriguez
This lets us throw at it whatever extra stuff we want. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-23backports: simplify space regexp for src_lineLuis R. Rodriguez
The regexp doesn't require the extra brackets. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-19backports: lib/kconfig.py - fix src line regexpLuis R. Rodriguez
The source line can be prefixed by spaces and tabs. Without this a slew of kconfig options were not being parsed for dependency checking and at compile time they'd obviously fail. Tested with ckmake against next-20130627 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] real 34m5.379s user 921m5.112s sys 128m8.156s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05gentree/git-tracker: make python 3 compatibleJohannes Berg
Make the python scripting compatible with python 3 (as tested with python 3.3). The patch library was a bit tricky. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-08lib/patch.py: add top header parsing supportLuis R. Rodriguez
Add a top_header for cases where a patchset might have a full header that we may want users to keep around. Cc: techtonik@gmail.com Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-08backports: update patch Python libraryLuis R. Rodriguez
This updates the backports project up to synch with the latest patch.py from svn trunk. Cc: techtonik@gmail.com Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> [remove HG/GIT patch path detection as we used to] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-08gentree: use git library to speed up --git-revisionJohannes Berg
If the git library is available (on many distros, just install python-git or similar) then use it to read the git blobs from disk if --git-revision is used. On my system (with an SSD) this speeds up the entire backport generation process significantly (when using --git-revision): before: real 0m39.280s user 0m13.464s sys 0m16.644s after: real 0m22.554s user 0m16.404s sys 0m5.724s Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-08python support: rename git library to bpgitJohannes Berg
There's a python git library, and our name conflicts with it since it's also just called "git". I want to use the python library (optionally) to speed up the git accesses so this is now relevant. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-16patch library: fix previous patchJohannes Berg
I accidentally removed one line too many ... Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-16patch library: don't use -p1 for git patchesJohannes Berg
For git patches, the patch library will automatically use -p1 and strip the a/ b/ filename prefix, while for other patches it uses -p0 and doesn't strip anything. We usually use a/ b/ prefixes even when the patches aren't in the git format and strip a path in gentree, so remove this from the library. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-08gentree: add automatic backports only if neededJohannes Berg
If the automatic backports aren't selected by any driver then they don't need to be added to the output, so ignore them in that case. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-08gentree: make automatic backport filenames uniqueJohannes Berg
Instead of copying drivers/base/hdmi.c to just hdmi.c copy it to drivers-base-hdmi.c as there can be multiple files with the same name (e.g. "core.c"). While at it, also fix this mechanism for modules -- before having more than a single file for a module would have caused multiple modules which clearly can't work, now it's needed to give a #module-name and it will be added to the Makefile correctly. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-05make lib: don't require a space after assignmentsJohannes Berg
Some makefiles have just obj-$(...)+= which wasn't parsed correctly. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-05gentree: add ability to create automatic backportsJohannes Berg
Instead of manually copying code like HDMI and dma-buf, add the ability to just specify such backports in the Kconfig file for compat. This will then always update to the lastest code as well. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-05kconfig lib: make tree walking a generatorJohannes Berg
Instead of building the list in memory first, just use a generator. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-04git lib: suppress messages from shortlogJohannes Berg
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-04-04devel: add git tracker helper scriptJohannes Berg
This allows creating a git tree based on the backport output automatically, to track an upstream kernel tree. Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-04-04gentree: make lib directory a python moduleJohannes Berg
That will make it easier to use gentree and/or git helpers from other scripts. Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-04-02add ability to read source files from gitJohannes Berg
Instead of having to have a checked-out kernel tree the script can now read the files from a git revision when passed the --git-revision <rev> argument. In this case the kerneldir is taken as the git tree to use. This helps when generating for multiple different trees. Note that due to the need to invoke git many times this is considerably slower than copying from a checkout. If taking into account the time to create the checkout it's still faster though. Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-04-02add kernel version dependenciesJohannes Berg
Some drivers/subsystems/... can only build on certain newer kernels, or were never tested elsewhere. Insert their version dependencies into the output Kconfig. Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-04-01allow backported drivers to select backport optionsJohannes Berg
This allows to have, for example, CRC8 still selected by drivers (modified to BACKPORT_CRC8) and then build the CRC8 code only conditionally on not having it in the base kernel and being required by a driver. Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-03-31add -a git commit to catch deleted files in debugJohannes Berg
2013-03-31disable impossible symbolsJohannes Berg
2013-03-30remove unused os.getcwd()Johannes Berg
2013-03-30add debug mode that commits each step in gitJohannes Berg
This allows checking easily what the code generation scripting did to the copied sources. Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-03-30parse "menuconfig" as local symbolJohannes Berg
2013-03-30add first attempt at new copy script and build infrastructureJohannes Berg
2013-03-30split patchesJohannes Berg
This splits all patches into per-file patches. I've added the little tool I wrote as well (but it's hard to use). Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
