path: root/patches/0052-deactivate-ptp-pin
2018-09-19backports: Remove unused partsHauke Mehrtens
This removes parts which were only used by subsystems which are not included in backports any more, for example media, bluetooth and Ethernet. The patches which are removed in this commit are not applied to the kernel tree anyway with the default configuration because non of the files get copied. The freezer, media, regulator and sound parts were only used by the already removed media drivers. The flow dissector file is not copied any more. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-02-09backports: always use new version compare macrosJohannes Berg
2017-02-07backports: get rid of patch directory structureJohannes Berg
This directory structure was never really managed well, simply get rid of it. With the patch system that only applies patches when the modified file exists, and with a lot of spatches applying everywhere anyway, it's no longer really useful either. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
