1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.69 [ OK ]
4 3.3.8 [ OK ]
5 3.4.108 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.84 [ OK ]
12 3.11.10 [ OK ]
13 3.12.44 [ OK ]
14 3.13.11 [ OK ]
15 3.14.48 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.19 [ OK ]
20 3.19.8 [ OK ]
21 4.0.9 [ OK ]
22 4.1.3 [ OK ]
23 4.2-rc3 [ OK ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
This patch, adding a missing include to rhashtable.c, is not needed any
more, because it went into upstream in commit 6d7954130.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.106 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.73 [ OK ]
12 3.11.10 [ OK ]
13 3.12.39 [ OK ]
14 3.13.11 [ OK ]
15 3.14.37 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.10 [ OK ]
20 3.19.3 [ OK ]
21 4.0-rc6 [ OK ]
lib-rhashtable.c misses a #include <linux/export.h> on some kernel
versions.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.65 [ OK ]
4 3.3.8 [ OK ]
5 3.4.105 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.63 [ OK ]
12 3.11.10 [ OK ]
13 3.12.35 [ OK ]
14 3.13.11 [ OK ]
15 3.14.27 [ OK ]
16 3.15.10 [ OK ]
17 3.16.6 [ OK ]
18 3.17.7 [ OK ]
19 3.18.1 [ OK ]
manual changed were needed for the following patches:
backport-adjustments/crypto-ccm.patch
backport-adjustments/devcoredump.patch
Things we backport are now prefixed with BACKPORT_, when we copy
over libraries with the c-files / h-files trick on the compat/Kconfig
trick we prefix these with BACKPORT_ already so in order to help
distinguish them use BACKPORT_BPAUTO_ for them and prevent a double
BACKPORT_ prefix.
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
As drivers will start requiring the new framework and it has
been merged to linux/master during the 3.18 merge window, we
can include it into backports to compile if needed.
On kernels that do already have it but didn't want it built
honor that, but if building otherwise don't. This may need
to be revisited in the future.
This DMA shared buffer backport was used for kernel < 3.5, more recent
kernel versions already have a working version of the DMA shared
buffers.
The DMA shared buffers are only used by some media drivers, but non of
these media drivers, which are actually using this API, are compiled on
kernel < 3.5. The DMA shared buffer part would need some more attention
in the next backports version, because there are some bigger changes
and instead we removed it.
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean
/home/mcgrof/linux-next /home/mcgrof/build/next-20140409
Copy original source files ...
Apply patches ...
Modify Kconfig tree ...
Rewrite Makefiles and Kconfig files ...
Done!
real 1m30.186s
user 9m25.180s
sys 0m24.428s
mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.54 [ OK ]
4 3.3.8 [ OK ]
5 3.4.79 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.29 [ OK ]
12 3.11.10 [ OK ]
13 3.12.10 [ OK ]
14 3.13.2 [ OK ]
15 3.14-rc1 [ OK ]
real 26m54.859s
user 744m15.764s
sys 83m47.440s
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
We copy over the net/core/flow_dissector.c code from
the kernel through the backports Kconfig magic for
our backport of NET_SCH_FQ_CODE:
config BACKPORT_USERSEL_NET_SCH_FQ_CODEL
tristate "Fair Queue Controlled Delay AQM (FQ_CODEL)"
depends on m
depends on !BACKPORT_KERNEL_2_6_25
default m if NET_SCH_FQ_CODEL=n
default m if BACKPORT_USERSEL_BUILD_ALL
#module-name sch_fq_codel
#c-file net/sched/sch_fq_codel.c
#c-file net/core/flow_dissector.c
This pulls net/core/flow_dissector.c into the backports
module as compat/net-core-flow_dissector.c. We don't need
all the code there. Patches under patches/backport-adjustments/
can be used to adjust that type of code. Some changes have
been made to code we delete which means we need to manually
adjust the patch we carry. This is a hint as one area we could
look to enhance better to do more automatic backport work.
The wil6210 driver gets NETIF_F_GRO but not that we haven't
been backporting this feature, which was added as of v2.6.29
via commit d565b0a1a. The driver is only enabled on the
dependencies file down to 2.6.31 though so we simply reuse the
check against kernels >= 2.6.39 to use the netdev->hw_features.
mcgrof@ergon ~/linux-next (git::master)$ git describe --contains d565b0a1a
v2.6.29-rc1~581^2~181
--refresh /home/mcgrof/linux-next /home/mcgrof/build/next-20140320
Apply patches ...
Done!
real 1m59.391s
user 19m26.468s
sys 0m45.128s
mcgrof@drvbp1 ~/build/next-20140320 $ time ckmake --allyesconfig
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.79 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.29 [ OK ]
27 3.11.10 [ OK ]
28 3.12.10 [ OK ]
29 3.13.2 [ OK ]
30 3.14-rc1 [ OK ]
real 36m11.856s
user 994m29.360s
sys 124m49.936s
This seems to commonly be missing in the random kernels
people use, so just provide a backport.
manual changes were needed on these files:
* patches/backport-adjustments/flow_dissector.patch
* patches/collateral-evolutions/network/16-bluetooth/net_bluetooth_hidp_core.patch
* patches/collateral-evolutions/network/83-select_queue/mac80211.patch
* patches/collateral-evolutions/network/83-select_queue/mwifiex.patch
* patches/collateral-evolutions/network/85-hid_ll_driver/net_bluetooth_hidp_core.patch
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.79 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.29 [ OK ]
27 3.11.10 [ OK ]
28 3.12.10 [ OK ]
29 3.13.2 [ OK ]
30 3.14-rc1 [ OK ]
Instead of using an own version of sch_fq_codel.c make backports copy
that code from the kernel and use that. This ensures that we will
always use the latest version.
This also includes flow_dissector.c which provides a function used by
sch_fq_codel.c.
Instead of using an own version of sch_codel.c make backports copy that
code from the kernel and use that. This ensures that we will always use
the latest version.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.79 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.29 [ OK ]
27 3.11.10 [ OK ]
28 3.12.10 [ OK ]
29 3.13.2 [ OK ]
30 3.14-rc1 [ OK ]
Manual changes were needed in
== ckmake-report.log ==
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ OK ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ OK ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ FAIL ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m38.595s
user 808m49.549s
sys 127m31.602s
Commit 5a753a4 on next-20130410 extended the
dma-buf implementation to add debugfs support.
We backport support for this by adding its own
subsys_init() call as a helper to the backport
module (still called compat) respective subsys_init()
call, backport_init(). For kernels where this is
already supported this is a no-op.
This didn't make it to v3.9 but I see Linus has
already merged this as part of the merge window
what will be v3.10.
This also refreshes patches for next-20130410 and
I supply the refresh as part of this same patch
given that the only patch refreshed was the one
modifyin the drivers/base/dma-buf.c.
commit 5a753a49fb7e17fa83ea9cf39c7b1a902363d828
Author: Sumit Semwal <sumit.semwal@linaro.org>
Date: Thu Apr 4 11:44:37 2013 +0530
dma-buf: Add debugfs support
Add debugfs support to make it easier to print debug information
about the dma-buf buffers.
Cc: Dave Airlie <airlied@redhat.com>
[minor fixes on init and warning fix]
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
$ ckmake --allyesconfig
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m10.328s
user 797m1.841s
sys 125m15.978s
The patched backported dma-buf code uses the "current" macro
to determine task information, so it needs to include sched.h.
Instead of copying drivers/base/hdmi.c to just hdmi.c copy it to
drivers-base-hdmi.c as there can be multiple files with the same
name (e.g. "core.c"). While at it, also fix this mechanism for
modules -- before having more than a single file for a module
would have caused multiple modules which clearly can't work, now
it's needed to give a #module-name and it will be added to the
Makefile correctly.
dma-buf was added via commit d15bd7ee on v3.3 but completed
in a more sound fassion in later kernels, you should preferably
be at v3.5 a least, so we take the latest dma-buf implementation
and port it for usage on kernels [3.0-3.4].
This is implemented as a non modular solution upstream but
we can carry the implementation into our compat module.
Note that although commit f23513e8d was added on v2.6.23
that allowed the kernel to call get_unused_fd_flags(flags)
for O_CLOEXEC setting, this routine was not exported until
v3.7. dma-buf makes use of it, and since our backported
dma-buf implementation is modular it means we have to work
around the lack of get_unused_fd_flags() exported symbol
on older kernels. Due to the security concerns noted by
Ulrich on f23513e8 we need to ensure the operatin is
atomic so we fix this on our port of dma-buf for older
kernels by adding our own dma_buf_fd_set_flag() to be called
when dma_buf_fd() is used. This implementation is available
for usage on kernels >= 3.0. We disable it for v3.5 as
we're happy with that implementation.
mcgrof@frijol ~/linux-next (git::master)$ git describe --contains \
d15bd7ee445d0702ad801fdaece348fdb79e6581
v3.3-rc1~161^2~2
f23513e8d96cf5e6cf8d2ff0cb5dd6bbc33995e4
v2.6.23-rc1~894
mcgrof@frijol ~/linux-stable (git::linux-3.2.y)$ git describe --contains \
1a7bd226
v3.7-rc1~134^2~69
commit d15bd7ee445d0702ad801fdaece348fdb79e6581
Author: Sumit Semwal <sumit.semwal@ti.com>
Date: Mon Dec 26 14:53:15 2011 +0530
dma-buf: Introduce dma buffer sharing mechanism
This is the first step in defining a dma buffer sharing mechanism.
A new buffer object dma_buf is added, with operations and API to allow easy
sharing of this buffer object across devices.
The framework allows:
- creation of a buffer object, its association with a file pointer, and
associated allocator-defined operations on that buffer. This operation is
called the 'export' operation.
- different devices to 'attach' themselves to this exported buffer object, to
facilitate backing storage negotiation, using dma_buf_attach() API.
- the exported buffer object to be shared with the other entity by asking for
its 'file-descriptor (fd)', and sharing the fd across.
- a received fd to get the buffer object back, where it can be accessed using
the associated exporter-defined operations.
- the exporter and user to share the scatterlist associated with this buffer
object using map_dma_buf and unmap_dma_buf operations.
Atleast one 'attach()' call is required to be made prior to calling the
map_dma_buf() operation.
Couple of building blocks in map_dma_buf() are added to ease introduction
of sync'ing across exporter and users, and late allocation by the exporter.
For this first version, this framework will work with certain conditions:
- *ONLY* exporter will be allowed to mmap to userspace (outside of this
framework - mmap is not a buffer object operation),
- currently, *ONLY* users that do not need CPU access to the buffer are
allowed.
More details are there in the documentation patch.
This is based on design suggestions from many people at the mini-summits[1],
most notably from Arnd Bergmann <arnd@arndb.de>, Rob Clark <rob@ti.com> and
Daniel Vetter <daniel@ffwll.ch>.
The implementation is inspired from proof-of-concept patch-set from
Tomasz Stanislawski <t.stanislaws@samsung.com>, who demonstrated buffer sharing
between two v4l2 devices. [2]
[1]: https://wiki.linaro.org/OfficeofCTO/MemoryManagement
[2]: http://lwn.net/Articles/454389
Signed-off-by: Sumit Semwal <sumit.semwal@ti.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Dave Airlie <airlied@redhat.com>
Reviewed-and-Tested-by: Rob Clark <rob.clark@linaro.org>
