1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ FAIL ]
19 3.11.3 [ FAIL ]
20 3.12-rc3 [ FAIL ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.2.45 [ OK ]
20 3.3.8 [ OK ]
21 3.4.46 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.13 [ OK ]
26 3.9.3 [ OK ]
real 33m18.960s
user 900m1.540s
sys 125m0.580s
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
== ckmake-report.log ==
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.85 [ OK ]
18 3.1.10 [ OK ]
19 3.10.0 [ OK ]
20 3.2.48 [ OK ]
21 3.3.8 [ OK ]
22 3.4.52 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.9 [ OK ]
i915 now uses swiotlb_nr_tbl(), but we can not backport it to kernel
version <= 3.2.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m50.520s
user 815m12.233s
sys 127m49.075s
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m46.042s
user 816m2.488s
sys 126m33.079s
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m48.875s
user 815m54.307s
sys 127m12.229s
The recent file shuffling on nouveau requires some
changes not upstream to get it to compile to ensure
some objects do get interpreted as requiring the
new search path.
Intorduced in next-20130429 and Linus has merged it
onto v3.10-rc1. We cannot backport remove_proc_subtree()
modularly [0] so just go ahead and revert this change.
The alternative is to go and review each procfs usage
for each driver we have issues and see if it makes
sense to replace procs with debugfs upstream.
commit 8ce584c7416d8a85a6f3edc17d1cddefe331e87e
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Sat Mar 30 20:13:46 2013 -0400
procfs: add proc_remove_subtree()
just what it sounds like; do that only to procfs subtrees you've
created - doing that to something shared with another driver is
not only antisocial, but might cause interesting races with
proc_create() and its ilk.
[0] http://marc.info/?t=136841961600002&r=1&w=2
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m52.106s
user 816m17.749s
sys 127m27.702s
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m38.751s
user 810m14.462s
sys 126m48.932s
We'll resolve all the other compat-*.h files next.
To keep it compiling, we now also need to remove all
the pr_fmt patches (they add printk.h which can't be
included as the first header file any more.)
I attempted to simply not include anything from the
command line, but very old kernels (e.g. 2.6.24)
don't include kconfig.h from the command line but
include/linux/autoconf.h directly, and thus won't
get our override. Thus we need to keep a very small
backport.h.
These are no longer needed.
These are no longer needed given that dma-buf is
now backported.
They can be named after the C files they apply to,
but they should still be named .patch.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
This splits all patches into per-file patches. I've added the little
tool I wrote as well (but it's hard to use).
I manually edited the patch but failed to test it...
The collateral evolution (CE) on the fb_info data structure
that added the skip_vt_switch element can be simplified
further by replacing the #ifdef hell with a static inline.
Furthermore, if the static inline is added upstream it'd mean
we can get rid of all these static inline replacements for
this data structure element CE.
Cc: cocci@systeme.lip6.fr
Cc: backports@vger.kernel.org
Cc: Julia Lawall <julia.lawall@lip6.fr>
Cc: Rodrigo Vivi <rodrigo.vivi@gmail.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Commit 3cf2667 as of next-20130301 extended the struct fb_info
with a skip_vt_switch to allow drivers to skip the VT switch
at suspend/resume time. For older kernels we can skip this
as all this switch does is call pm_vt_switch_required() with true
or false depending on this new flag and later
pm_vt_switch_unregister() would not have been made.
This patch cannot be broken down further so I'm pegging
this as the first one with 4 digits under the DRM folder
for collateral evolutions. This reflects its as atomic as
is possible. As we'll see on the next commit, these type
of collateral evolutions can best be backported not by
keeping ifdef's as below but instead by using a wrapper
caller, to help reduce with the amount of lines of code
we need. If a static inline is added upstream for these
changes, then no code is required for backporting, at all,
we'd just implement the static inline later upstream as
a no-op.
The tradeoffs to consider for this is if we can live with
these practices upstream, we may be able to support full
subsystems only with a compat module, and no need for
patches. This also means less code and likely less bugs
on the distribution front when backporting is required.
At least IMHO this may be worthy to consider at least to
support kernels listed as supported on kernel.org. We could
just leave the ifdef hell to older unsupported kernels.
Relevant commits below, starting with the first one that
added this new collateral evolution.
commit 3cf2667b9f8b2c2fe298a427deb399e52321da6b
Author: Jesse Barnes <jbarnes@virtuousgeek.org>
Date: Mon Feb 4 13:37:21 2013 +0000
fb: add support for drivers not needing VT switch at suspend/resume time
Use the new PM routines to indicate whether we need to VT switch at suspend
and resume time. When a new driver is bound, set its flag accordingly,
and when unbound, remove it from the PM's console tracking list.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 24576d23976746cb52e7700c4cadbf4bc1bc3472
Date: Tue Mar 26 09:25:45 2013 -0700
drm/i915: enable VT switchless resume v3
With the other bits in place, we can do this safely.
v2: disable backlight on suspend to prevent premature enablement on resume
v3: disable CRTCs on suspend to allow RTD3 (Kristen)
Reviewed-by: Rodrigo Vivi <rodrigo.vivi@gmail.com>
This refreshes the patches on next-20130227
Some of the drm patches needed manual editing.
Refresh patches on next-20130220
Refresh patches on next-20130218.
Refresh patches on next-20130213.
deactivated
Refreshes patches for next-20130108
The number of patch directories for the different life
cycle a patch can be on its way upstream had reached 4:
* pending-stable
* linux-next-pending
* linux-next-cherry-picks
* crap
Apart from this we also had the backport related patches.
In the future I see potential for other directories for
different categories of patches. Consider how we are
breaking down the backport patches into specific documented
collateral evolutions and of those type of collateral
evolutions there may be different types of collateral
evolutions which we could likely treat / document differently.
Another type of patch that I forsee us having to deal with
are patches for drivers that are not upstrea -- like crap,
but for drivers in a unified driver tree that is *designed*
from scratch to be targetting upstream Linux inclusion using
the same coccinelle technology I forsee us using for backporting
Since the number of patch directories can get out of hand
at the top level lets just stuff then all under patches/
and deal with patches there. This also places the backport
patches into a directory called collateral-evolutions/ to
help promote and educate on the nature of the changes
that we have to deal with when backporting.
Cc: Adrian Chadd <adrian@freebsd.org>
