path: root/patches/collateral-evolutions/media
2013-10-27backports: use sysfs api backport independent from kernel versionHauke Mehrtens
In struct class the new sysfs dev_groups member was added with kernel 3.11, but in other structs, like struct bus_type the new member was added with kernel 3.12. This backport is now needed on different kernel versions depending on the struct where is was used. With this patch ATTRIBUTE_GROUPS() will always be used with the new API and ATTRIBUTE_GROUPS_BACKPORT() will always be used used with the old API and the patch has to add a KERNEL_VERSION check to add the correct macro. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: refresh on next-20130830backports-20130830Hauke Mehrtens
== ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.98 [ OK ] 17 3.1.10 [ OK ] 18 3.10.14 [ OK ] 19 3.11.3 [ OK ] 20 3.12-rc3 [ FAIL ] 21 3.2.51 [ OK ] 22 3.3.8 [ OK ] 23 3.4.64 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: backport new sysfs api in mediaHauke Mehrtens
2013-05-17backports: refresh patches for next-20130430Luis R. Rodriguez
1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.76 [ OK ] 18 3.1.10 [ OK ] 19 3.2.44 [ OK ] 20 3.3.8 [ OK ] 21 3.4.43 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.10 [ OK ] 25 3.8.11 [ OK ] 26 3.9.0 [ OK ] real 30m45.327s user 814m25.678s sys 128m22.341s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-14backports: move vb2_mmap_pfn_range into patchJohannes Berg
There's only a single user of vb2_mmap_pfn_range() and at least on 3.2 having the function in compat-3.9.c is problematic if CPTCFG_BACKPORT_BUILD_DMA_SHARED_BUFFER isn't set, because on that kernel there's no dma-buf.h and then compilation can fail. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-08backports: refresh patches for next-20130405Luis R. Rodriguez
2013-04-15backports: dissolve backport.hJohannes Berg
We'll resolve all the other compat-*.h files next. To keep it compiling, we now also need to remove all the pr_fmt patches (they add printk.h which can't be included as the first header file any more.) I attempted to simply not include anything from the command line, but very old kernels (e.g. 2.6.24) don't include kconfig.h from the command line but include/linux/autoconf.h directly, and thus won't get our override. Thus we need to keep a very small backport.h. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-13backports: add media subsystem driversLuis R. Rodriguez
This adds backport support for all media subsystem drivers. This is enabled only for >= 3.2. Some media drivers rely on the new probe deferrral mechanism (-EPROBE_DEFER see commit d1c3414c), those are only enabled for kernels >= 3.4. Some media drivers only depend on the regulatory but since we only support backporting the regulatory on kernels >= 3.4 we only enable those media drivers for >= 3.4. This backports 433 media drivers. 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.65 [ OK ] 18 3.1.10 [ OK ] 19 3.2.38 [ OK ] 20 3.3.8 [ OK ] 21 3.4.32 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.9 [ OK ] 25 3.8.0 [ OK ] 26 3.9-rc1 [ OK ] real 39m35.615s user 1068m47.428s sys 155m55.657s Cc: linux-media@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
